Old 05-02-2005, 08:42 AM   #9526
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I'll just type it up this afternoon while I'm at lunch and post it for you. The setup sheet is an Excel file and has to be viewed with that (or some kind of spreadsheet program that supports .xls files.
Jon Kerr is offline   Reply With Quote
Old 05-02-2005, 08:50 AM   #9527
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Jon, export the XLS into HTM... that should do the trick
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 05-02-2005, 09:05 AM   #9528
Jon Kerr's Avatar
Good idea Tim. I've done it and sent it. We'll see if that works.
Old 05-02-2005, 09:15 AM   #9529
Send a message via AIM to Roberto Falcon
Hey Jon i didnt get it I think my comp email is messed up thats why i think it wont let me read it.
send it here
email: surf_pr_10@hotmail.com
Im sorry if this been a headache for you . If its a pain just nvm it
Roberto Falcon is offline   Reply With Quote
Old 05-02-2005, 09:26 AM   #9530
Jon Kerr's Avatar
It's not a problem. That's what we're here for. I want you to have a good setup so you enjoy driving this great car. Let me know if there's anything else I can help with.
Old 05-02-2005, 09:41 AM   #9531
Have you sent it . or you going to later on the day?
Old 05-02-2005, 09:45 AM   #9532
Jon Kerr's Avatar
Yes I did.
Old 05-02-2005, 10:15 AM   #9533
To surf_pr_10@hotmail.com ??? cause if that i havent recieved it yet.
Old 05-02-2005, 10:26 AM   #9534
Jon Kerr's Avatar
yup. I'll do it again with a different subject. It may be getting blocked for some reason.
Old 05-02-2005, 10:37 AM   #9535
Alright just let me know when you send it .
Old 05-02-2005, 10:48 AM   #9536
Jon Kerr's Avatar
about 10 minutes ago Dude, I hate to say it, but your Email sucks I'll just type it up and post it here for all to see when I go to lunch.
Old 05-02-2005, 10:52 AM   #9537
LOL thanks ,,, Its my damn comp forget it im throwing it out! Im buying a new one this weekend ! AHHH I hate computers!
Alright thanks Jon at least for trying lol
Old 05-02-2005, 11:36 AM   #9538
IslandBwoy's Avatar
I would have posted this had i know that you guys was going to have so much trouble. I too had problems with the file but i eventually noticed that when the file is downloaded that it would not save with a file extension. Thus i simple gave the file a new name when downloaded it the last time and appended the ".zip" extension. Once i did that the file opened fine.
~M.I. Jedi
IslandBwoy is offline   Reply With Quote
Old 05-02-2005, 12:13 PM   #9539
Jon Kerr's Avatar
OK. Here's The setup Donny and I run on most outdoor asphalt tracks out here. Obviously we make some small adjustments here and there for conditions, layout etc... If there's anything that doesn't make since let me know and I'll explain.
FRONT:
Hub Carriers: Plastic
Sway Bar: 1.5mm
Castor: 4 degree
Kick up/Anti dive: 0mm
Toe in/out: 1 degree out
Ride Height: 5mm
Camber: -1 degree
Front Arm position: Middle
Front drive shaft: TiR Worlds Aluminum
Front Roll center: 1mm shims
Shock Tower: Carpet Front
Shocks: TRF
Upper Shock Location: Outside
Lower Shock Location: Outside
Shock Oil: AE 40wt.
Spring: X-Ray White 17.5 lbs
Piston: Tamiya 3 hole
Front Camber Link: Top Row, Middle
Ackerman: Middle hole on bell cranks
Droop: 2.5mm True Droop
REAR:
Hub Carriers: Aluminum
Sway Bar: 1.5mm
Anti/Pro Squat: 0mm flat (Go to 1mm anti squat to square up coming out, we use this a lot)
Rear Toe: 1.5 degree
Ride Height: 5mm
Camber: -1 degree
Rear Arm Position: Middle
Rear Drive Shaft: TiR Worlds Aluminum
Rear Roll Center: Stock 2mm Riser Plate
Shock Tower: Carpet Rear
Shocks: TRF
Upper Shock Location: 3rd. out.
Lower Shock Location: 3rd. out.
Shock Oil: AE 35wt. (We also use AE 40wt. in the rear a lot)
Spring: X-Ray Yellow 14lbs. (X-Ray Teal 15lbs. is used if you need a slightly stiffer rear spring)
Tower Camber Link Location: Top Row- Middle
Hub Carrier Camber Link Location: Inside Hole- 1mm shim under ball stud.
Droop: 3mm True Droop
OTHER SETTINGS:
Body: Mazda 6
Front Diff: Spool
Chassis/Top Deck: Stock 2mm
ESC: Keyance Rapida
Cells: Fukuyama GP3300
Receiver: Spectrum
Servo Airtronics 94757
Cell Position: Middle, Inside
Motor: br00d 7x1 Ti Tear down
Brushes: CS Silver
Springs: Trinity Purple
Timing: 15
Pinion: 26
Spur: 128
Final: 8.86
Tires: Take Off CS27 (whatever tire is best on your track for the weather conditions.)
OK, what I mean by the Roll Center measurement is the spacing under the suspension mounts. 1mm in the front means take out the stock 2mm riser plate and replace it with 1mm shims. Anti squat is achieved by putting shims under only the front block of the rear suspension mount. And the droop is measured above ride height. Set the ride height first, then use the notch in the center of the carpet shock towers and lift the end of the car up just until the tires are barely touching your flat board, then measure the ride height again at the same point. If you're measuring the rear at 3mm of droop, your ride height should be 5mm at rest then lifted should be 8mm. Everything else should be pretty self explanatory. Like I said, this is pretty much where we start and just make small adjustments. Remember though, the whole setup needs to be followed. You can't just setup the shocks the way we have them and not the rest of the car and expect it to work right. We've spent months working this setup up and we're both really confidant in it now.
Old 05-02-2005, 12:20 PM   #9540
Alright thanks ALOT Jon!
everything there seems like what i got on it right now but with some differences
I will do everything on my car as what it says and i will let you know..!
BTW what do you mean by true drop? I use the ae or the hudy gauge . am i ok?
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
