Old 04-29-2005, 05:43 PM   #9496
Trader Rating: 17 (100%+)
Send a message via AIM to Roberto Falcon
I dont know his setup and doesnt he run mod ? ill just be running stock .
Jon if your setup works for stock too i want to see it if it isnt a problem with you!?
Awesomatix USA - Speed Passion - Superior Hobbies
Roberto Falcon is offline   Reply With Quote
Old 04-29-2005, 05:55 PM   #9497
Jon if you want to mail it to me mail me it to
Email: agonzalez15@cfl.rr.com
Old 04-29-2005, 05:57 PM   #9498
Jon Kerr's Avatar
A setup is a setup. Very rarely would I change the setup just for the motor. Sometimes in mod the car may feel a little more free because of the additional power. But if it's good in mod, it should be just fine for stock. Here's the standard setup we use outdoors on asphalt. I'll probably be running this exact setup to start at the Reedy Race in a few weeks. This is a setup sheet of my own so if there's anything on there that doesn't make since just ask. Like Donny said, you need to follow this setup to a T for starters for it to work right.
Jon Kerr is offline   Reply With Quote
Old 04-29-2005, 06:18 PM   #9499
IslandBwoy's Avatar
Do any of you guys have a setup that you find works particularly well on a sealed surface?
IslandBwoy is offline   Reply With Quote
Old 04-29-2005, 06:27 PM   #9500
speedxl's Avatar
R/C Tech Charter Subscriber
All of us run pretty much the same set up that we would run in mod for stock. Maybe if anything I would run less toe in on the rear for stock and 19t. If anything set up your car with a faster motor then run what everclass your race in.
I really havent found a track here in florida where I needed anti squat.
I will use anti dive in the front on occassion to get a little extra aggressive corner entry other then that everything stays flat.
Like jon no riser plate up front just a 1mm shim and in the rear the riser plate with 1mm shims on the front and rear pickup points!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 04-29-2005, 06:29 PM   #9501
speedxl's Avatar
Paul wynns Portland nationals set up will work at TQ. His set up is at gearchart.com. Or if you'ld like talk to tony padilla he races there everyfriday nite.
Old 04-30-2005, 05:26 AM   #9502
IslandBwoy's Avatar
I'll Take a look at that. I've been running a pretty basic setup that works well but was just wondering if we had one for sealed.
Old 04-30-2005, 05:33 AM   #9503
IslandBwoy's Avatar
Concerning the setups on Gearchart. I see that some of them specify an AE anti roll bar. Where you guys getting these? I have the set sold by schumacher. Are they the same or is their a comprable schu anti roll bar that i can use if i can not find the Associated?
Old 04-30-2005, 08:44 AM   #9504
speedxl's Avatar
That was before shuey released their own. They will work fine. If you insist on running the associated ones, it will require some bending to fit. Any hobby store will carry them. Superior and TQ will have them.
Old 04-30-2005, 09:33 AM   #9505
steveM3's Avatar
Default Stickum
So what do you recommend Steve? Different potion? or to wipe the tires after using Stickum?
I would put it on right before the race and just let it burn off, don't wipe.
Steve McNichols
Serpent- Desoto Racing
steveM3 is offline   Reply With Quote
Old 04-30-2005, 09:35 AM   #9506
protc3's Avatar
DONT WIPE!!!!!!EEEEEEEWWWWWWWW!!!
what up dude,you racing this weekend?
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 04-30-2005, 10:00 AM   #9507
Jon Kerr's Avatar
Oh, that's just wrong!
Old 04-30-2005, 07:57 PM   #9508
speedxl's Avatar
Jon these guys in tampa are a little wierd!
Old 04-30-2005, 09:07 PM   #9509
Jon Kerr's Avatar
Most of the people I know in Florida I think are a little off Oh wait, most of my sponsors are in Florida. Nevermind
Old 04-30-2005, 09:23 PM   #9510
tmunno's Avatar
Jon 3 out of 5 live in this area. And yes we are a little off!!!!!!!
Tony Munno
Munnograffix
CFX Paintworks,
tmunno is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
