Old 04-28-2005, 07:32 PM   #9481
Trader Rating: 17 (100%+)
Send a message via AIM to Roberto Falcon
when ever i use stickum i put it on a piece of paper and then wipe it on my tires right before the heat . and it works ..
Roberto Falcon is offline   Reply With Quote
Old 04-28-2005, 07:53 PM   #9482
Send a message via ICQ to piorc
Default Mi2
Hi guys, im from Brazil, here we have an outdoor asphalt track, and a indoor carpet track.
I just got my mi2 last week and need some advices.
The original diff are great? or should i buy the newest one ways and spools?
Which spurs and belts to use?? please, part number if possible.
Which shocks?
Thanks a lot, but here in Brazil just me have an mi2, hehe!!
Thanks a lot.
Marcelo.
piorc is offline   Reply With Quote
Old 04-28-2005, 09:02 PM   #9483
Jon Kerr's Avatar
Most of us don't use a one-way. Spools are preferred for asphalt tracks. You can either get the alloy spool part number U2729, or just use the front diff. Take the balls out and use header cards and glue them to the diff rings and tighten it down all the way until it's locked. You can also make out drive savers by taking an old set of bearings, cut the outer ring off and pop the inner ring out and slide the race onto the outdrive. Use the diff in the front on carpet.
Belts: use the stock rear belt and you can get the R12 front belt and use that. U2601
Shocks: Most of us team guys use the Tamiya TRF shocks. To use those, you'll need to get the lowered carpet shock towers. Front U2714 and rear U2715. I just use the Tamiya mounting hardware but you can get the BMI upper mounts that will work. Click the link in my sig to go to the BMi site and and call Jason.
Spurs, I like the RW 64 pitch spur gears. They're very thin and perfectly round. Part# RW64128 for a 128 tooth.
One other thing you should also pick up is the P-Dub front bumper PD010. If you have any other questions, feel free to ask.
Jon Kerr is offline   Reply With Quote
Old 04-29-2005, 12:16 PM   #9484
what degree toe in are you guys using?
and whats this about using ae rear hubs? whats the difference?
Old 04-29-2005, 12:28 PM   #9485
Jon Kerr's Avatar
Rear toe I use 1.5 degree. I use the Aluminum rear hub carriers with the 0 degree inserts. Some of the guys were using AE hubs for a while but since the Aluminum hubs came out, I don't think I know of anyone using them.
Old 04-29-2005, 12:47 PM   #9486
But should i go 1.5 ill just be running stock or somthing times 19t
Old 04-29-2005, 12:50 PM   #9487
Jon Kerr's Avatar
It all depends. If you're on a really low grip surface and the car wants to spin going into the corner with 1.5 degrees, go to 3. I like the car to be good and free going into the corner so I always run 1.5.
Old 04-29-2005, 12:57 PM   #9488
Alright thats Jon .. both the tracks here are high to mid traction tracks
Old 04-29-2005, 01:10 PM   #9489
Hey Jon do you use anti squat on your car? or kick up or anti dive?
Old 04-29-2005, 01:41 PM   #9490
Jon Kerr's Avatar
I haven't played around with kickup and anti dive yet but I do use antisquat as a tuning option a lot. Adding anti aquat will help the rear end square up and grip on power coming out of the corner.
Old 04-29-2005, 01:45 PM   #9491
what should i use then for anti squat 1mm washer? im not useing the stock riser plates btw
Old 04-29-2005, 01:54 PM   #9492
Jon Kerr's Avatar
Yeah. I use the stock plate in the rear and then put 1mm washers under the front mounts for the rear arms. This will give a little over 1 degree of anti squat. I've never needed more than that and I'm not sure I'd try and go with more. It may cause the suspension to bind up with that much of an angle.
Old 04-29-2005, 02:17 PM   #9493
should i put the riser plated back on the front?
Old 04-29-2005, 02:24 PM   #9494
Jon Kerr's Avatar
I don't run the front plate most of the time. I usually just use 1mm shims under the front suspension mounts.
Old 04-29-2005, 04:40 PM   #9495
cornerspeed's Avatar
Try Jon and my set-up that we have been working on. Works awsome outdoors. If you don't have the set-up, I believe he can make it available. If you try it, everything on the set-up needs to done for it to work at its full advantage.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
