Old 04-12-2005, 01:11 PM   #9331
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally posted by Arjen
Thanks for your help. I had no front diff with me so i couldn't try it.
Next time i will give it a shot.
But the grips keep changing there from good to bad.
ONe day the grip was good than my setup was good and fast.
but low grip as the last 3 times its horrible.
I was thinking of alot of adjustments for example wheelbase.
should the have more rear grip witch a longer or shorter wheelbase?
And i usually change the roll centre but i tried to put extra 2 mm on the back but no real difference.
should the car have more or less grip when i make the roll center higher. i thought less but i wanna know sure.
arjen
I've found a higher roll center will give less grip on that end of the car. If you're raising the rear 2mm higher than stock, you're way too high. I usually run mine with the stock plate in the rear and only 1mm shims in the front. I like lower roll centers. Longer wheel base in the rear seems to smooth the car out and make it easier to drive. I'll usually leave it in the middle and if the car is fast but sketchy, I'll lengthen it to fine tune it.
Jon Kerr is offline   Reply With Quote
Old 04-12-2005, 01:21 PM   #9332
An old teamdriver of Schumacher "Niels Koenekoop" gave me his setup and that was also with 2mm extra roll centre. that's why i tried it.
Indoors it worked well.
But since a month or 2 Niels is not a teamdriver anymore so there are no reral good drivers with an MI2 in holland any more.
Arjen
Arjen is offline   Reply With Quote
Old 04-12-2005, 01:30 PM   #9333
What i also thougt about is what do you guys do with droop.
Do you run low droop or high droop.
i ran now fron 6.5mm rear 7.5mm(up travel from ride hight)
in generaly the more droop the more grip or?
Thanks,
Arjen
Old 04-12-2005, 01:31 PM   #9334
Jon Kerr's Avatar
Indoor carpet setups are Greek to me. I'm not sure if they prefer high roll centers on those setups or not. (I guess I should learn them since I'm going to the Vegas race )
Old 04-12-2005, 01:35 PM   #9335
Jon Kerr's Avatar
Thanks,
Arjen
An additional 6.5mm from ride height! That's a lot. I run 2.5mm in the front and 3mm in the rear. The more droop, the more weight can transfer to the opposite side. Too much rear droop will let the car transfer too much weight forward and make the rear too light off power.
Old 04-12-2005, 01:39 PM   #9336
Ok so that could be also a bit of the problem.
Tomorrow I will build my car up again and i will make a lot of changes like u told to me and i hope that i have time at the end of the week to test it.
Arjen
Old 04-12-2005, 01:41 PM   #9337
Jon Kerr's Avatar
Yes it could. Tell you what, give me your Email and I'll send you a good outdoor asphalt setup. Do you have Excell on your PC?
Old 04-12-2005, 01:42 PM   #9338
Send a message via ICQ to MattW
I would maybe try the rear shock mounted one hole further in on the wishbone and the mount. Where you are running with the spring that you are using is quite stiff overall. In that hole i used to use an associated silver, and often a silver with it mounted one in if traction was real low.
Try 1mm more droop all round. Should give a little more grip.
Didn't know Neils had made the change
MattW is offline   Reply With Quote
Old 04-12-2005, 01:43 PM   #9339
xcel/word/acrobat.
What i most of the time do is make an setup in acrobat.
then click on the camera and select it en past it in word so you can save it.
Really thanks for your help.
Ajpotharst@hotmail.com
its an large hotmail account.
Arjen
Old 04-12-2005, 01:44 PM   #9340
Actually didn't read that droop setting properly, if that is over ride height then it is too much. Jon''s suggestion is about right.
Old 04-12-2005, 01:51 PM   #9341
Niels stopped with driving much. only sometimes for fun.
I have ordered athe AE spring set so i can test a bit moer springs because i thing xray and AE combined isn't that good.
Droop:
Yes it was an 7.5mm additional to the ride height.
so i will change that.
Arjen
Old 04-12-2005, 01:51 PM   #9342
mo
mo's Avatar
John, if you want that setup put on a .pdf setup sheet, send it to me and I'll do it for you. jmo@mo-net.ws
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 04-12-2005, 02:01 PM   #9343
PW
PW's Avatar
Send a message via AIM to PW
Arjen....Matt is correct about the shock position on the lower rear arm. That and the droop are the 2 major things I see wrong.
YGM
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 04-12-2005, 02:02 PM   #9344
Jon Kerr's Avatar
I've got my own setup sheet I made up It's pretty dialed. A lot more detail and it's really easy for me. I have every setup sheet on my hard drive from the last 3 years. I'll send the blank to you. I know Donny liked it a lot.
Old 04-12-2005, 02:14 PM   #9345
I would like to thank you all for your help with the setup.
I have now a lot of things to test and i will lett you know how it went.
Arjen
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
