Old 04-11-2005, 11:29 AM   #9316
cornerspeed's Avatar
Thanks Jon.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 04-11-2005, 12:07 PM   #9317
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
No problem.
Jon Kerr is offline   Reply With Quote
Old 04-11-2005, 12:43 PM   #9318
STLNLST's Avatar
Trader Rating: 21 (100%+)
had the R12 looking good in practice then all of a sudden I brian farted for two qualifiers. Wound up in the B-main but due to computer issues they didn't get a chance to run the mains so I had to settle for the stupid B-main finishing position I will return for some more nitro action after the Reedy. Gotta get back on asphalt next weekend since I was unable to do so this weekend (electric car that is)
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 04-11-2005, 07:03 PM   #9319
IslandBwoy's Avatar
Hey King-G,
So you found that when it got hotter there was a need for the raiser plates AND 1 mill shims in the rear of the car? (Did i read that correctly?)
PS. State Race at Superrior coming up. Who's going to be there?
IslandBwoy is offline   Reply With Quote
Old 04-11-2005, 07:20 PM   #9320
Default screwed?
if you don't want me to have purple screws, then what type should i run? what r the sizes and syles i should order?
e money is offline   Reply With Quote
Old 04-11-2005, 07:32 PM   #9321
rcshark's Avatar
Send a message via Yahoo to rcshark
what is the diffrents then running with out a 1mm washer in the front and back or running with one I just took the front riser out and put my rear arams all the way back and front aarms middle and it works great just the right amount to do some good slidding around the turns when the tires cool down i like to slide to heat them up i can regulate now its realy fun this time of yr to play with my mi2
rcshark is offline   Reply With Quote
Old 04-11-2005, 09:18 PM   #9322
speedxl's Avatar
R/C Tech Charter Subscriber
Originally posted by IslandBwoy
Hey King-G,
the whole Florida team will be there!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 04-12-2005, 07:57 AM   #9323
IslandBwoy's Avatar
QUOTE]The whole florida team will be there[/QUOTE]
Good 'cause i would like to see these RDX guys eat their words. All of the superior guys are sponsored by corrally so they have been selling those damn rdx's by the case load. Be prepared to see LOTS of 'em.
BT W Your dancing fat guy is really disturbing
@speedxl [
Old 04-12-2005, 08:59 AM   #9324
speedxl's Avatar
BT W Your dancing fat guy is really distuhttp://www.rctech.net/forum/newreply.php?s=&action=newreply&postid=1511871#
http://www.rctech.net/forum/newreply...=1511871#rbing
@speedxl [
[/QUOTE]
thanks for the compliment!
Old 04-12-2005, 12:24 PM   #9325
Default Grip/setup problems
I have a bit of trouble with my MI2.
I am driving on a low grip track now and the rear of the car is unbelivable unstabel.
Even when i drive real slow a couple of meters straight and then i steer the back goes around.
My setup is:
Front
low towers/tamiya dampers
50 oil piston 3
asso gold (19.5)
second outer hole shock tower/ outer hole on arm
-0.5 toe in
-1.5 camber
4 degree castor
C/f arms
one way
Rear
45 oil piston 3
xray blue green (15)
third outer hole shock tower/ outer hole on arm
-3 toe in
-2 camber
C/f arms
alloy rear hubs
1mm anty squad
barttery is back in.
roll centre normal.
I even tried an roll bar in the front this helped a tiny bit but its still worse.
The track is an large outdoor tarmac track with real fine tarmac.
I have driven this car for 1.5 year now and never had this trouble at an track. Everything in the car seems to be right also tried different diffs.
I hope someone can help me out because the nationals are in 1.5 week and i hope to have the car right then.
Arjen
Arjen is offline   Reply With Quote
Old 04-12-2005, 12:46 PM   #9326
Jon Kerr's Avatar
First, I'd loose the one way. Also check and see if the drive train is bound up. Especially with the oneway, if the drive train is dragging, it can act like brakes and with a oneway, that'll cause it to spin. If you're on a low grip track, a oneway is the last thing you'd want in your car anyways.
Also, does it do it more one way than the other? The chassis could be severely tweeked, the suspension could be bound up badly, etc... There's a bunch of things that could be doing it. But I don't see anything i the setup other than the oneway that could be doing that.
Old 04-12-2005, 12:52 PM   #9327
mo
mo's Avatar
Also, move the battery forward. That will take away some turn in and make the car more stable. Also, make sure you have the inserts in the alloy rear hubs in properly. Otherwise your toe in could be really messed up.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 04-12-2005, 12:58 PM   #9328
Thanks for your help. I had no front diff with me so i couldn't try it.
Next time i will give it a shot.
But the grips keep changing there from good to bad.
ONe day the grip was good than my setup was good and fast.
but low grip as the last 3 times its horrible.
I was thinking of alot of adjustments for example wheelbase.
should the have more rear grip witch a longer or shorter wheelbase?
And i usually change the roll centre but i tried to put extra 2 mm on the back but no real difference.
should the car have more or less grip when i make the roll centre higher. i thought less but i wanna know sure.
arjen
Old 04-12-2005, 01:00 PM   #9329
The toe in is ok i checkt it in the setup board.
I will try to move the battery forward.
But still battery inside or?
Arjen
Old 04-12-2005, 01:06 PM   #9330
Jon Kerr's Avatar
Yes, battery inside is the best as far as I'm concerned. Having it moved back makes it act like a pendulum and makes the rear want to swing around. Having it too far out side makes the car transition too slowly.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
