Old 04-07-2005, 05:12 PM   #9301
protc3's Avatar
theres more Mi2's out there now adrian looks like 90% of the fast guys are running them at speedline.the car does really perform well. its gonna be nice to be able to run mine again once i get finished with the FK05 chassis kit.i miss the Mi2 and its only been 2or3 weeks.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 04-07-2005, 05:19 PM   #9302
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally posted by xxxkat
STLNLST,Would a spool work on a small tight track?? I just got one and the steel cvd's..yes I'm going to try the car ..again..
And what was the remark on Todd's thread a couple days ago about how fast can you make a Schumacher?
Yes, a spool will work on a small tight track. I use it all the time.
Jon Kerr is offline   Reply With Quote
Old 04-07-2005, 06:07 PM   #9303
mo
mo's Avatar
Yes, it will. I ran mine at Sheldon's once and it was pretty tight. The car worked well. I believe the setup from there is posted on www.gearchart.com if you want it.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 04-07-2005, 06:32 PM   #9304
IslandBwoy's Avatar
Thats good to know. I always thought i was the only MI2 at speedline when i fisited.. I'm going to have to look around next time and maybe introduce myself .
IslandBwoy is offline   Reply With Quote
Old 04-07-2005, 06:40 PM   #9305
IslandBwoy's Avatar
Hey STLNLST,
I noticed on one of your setups you said that you were using:
TAMIYA SHOCKS AND AE SPRINGS. LOWER INNER CAMBER LINK HOLE USING CARPET TOWERS. RASIED FRONT ROLL CENTER 0.78
How are you rasing yor roll center in those types of incriments? Are you just using not so standard washers under the lower arms or are you doing something else.
And what is the default castor setting on the MI2 is it 4 degrees? And if i wanted to change it do i need some sort of different caster blocks or something like that?
MI Jedi
Old 04-07-2005, 09:10 PM   #9306
Oasis's Avatar
Trader Rating: 36 (100%+)
Any others..I dont have the carpet towers or Tamiya shocks..or 6 deg. steering yokes..I guess I need to invest some $$ for tuning parts..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 04-07-2005, 09:15 PM   #9307
STLNLST's Avatar
Trader Rating: 19 (100%+)
question answered................
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 04-07-2005, 09:42 PM   #9308
STLNLST's Avatar
Originally posted by IslandBwoy
Hey STLNLST,
MI Jedi
I didn't have the take off washers back then and the AE plastic washers measured out to that uneven size.....lol I'd go with a .5 That is also after you remove the stock riser plate. The default caster blocks are the 4 degree. You will need some different blocks if you wish to try different caster.
Old 04-10-2005, 07:24 AM   #9309
IslandBwoy's Avatar
what do you do when you have the field down by a lap and then someone tries to race with you and takes you out in the main
Standings: 2nd in point series; down by one point.
Old 04-10-2005, 07:39 AM   #9310
pheyhoe's Avatar
R/C Tech Charter Subscriber
Push them off the drivers stand.
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 04-10-2005, 07:39 AM   #9311
Dirt-Racer's Avatar
Send a message via MSN to Dirt-Racer
Thats Easy!!!...Just move out the fucking way
Dirt-Racer is offline   Reply With Quote
Old 04-10-2005, 08:20 AM   #9312
IslandBwoy's Avatar
I made it a point not to see who the driver was because i would have been tempted to do something like pushing them off the stand.
But for now i'll just make sure this doesnt happen again
Old 04-10-2005, 04:34 PM   #9313
King-G's Avatar
Send a message via ICQ to King-G
Solid race day yesterday, My team Mate and I securing 2nd and 3rd in the Mod A. Car was very strong in the unusually hot conditions for this time of year (32c ambient). I was very pleased to get the car working so well in unfavoured conditions, some key changes really improving the grip and balance of the car.
I Set fastest single lap of the day, 14.02 and turned out to be the fastest lap to date on the existing layout for race day. I was running on t.q pace in my second qualifier, closely following eventual T.Q getter lap for lap, until a slight loss in concentration and blunder cost me 3 seconds, the eventual margin for t.q, and coincidentally track record.
Biggest gains were found by reverting back to a lowered front roll centre (no riser plate, with just 1mm shims under alloy pivot blocks)...rear r/c using riser plates and 1mm shims).
Also reverted to using 4 degree castor blocks with the spool, 2 degree was very good for initial steering, but 4 degree feels smoother and stronger mid corner for my liking.
Bring on the cooler weather, the Mi2's hunting ground!
Back in the Game!
King-G is offline   Reply With Quote
Old 04-10-2005, 07:05 PM   #9314
Default screws
does ne one know where to order purple chassis screws. i would like to replace all the screws on the bottom of the car, because they r hammered.
e money is offline   Reply With Quote
Old 04-10-2005, 08:50 PM   #9315
Jon Kerr's Avatar
In all honesty, purple chassis screws on the bottom will turn into silver ones fairly quickly as they get scratched.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
