Old 04-03-2005, 07:32 PM   #9256
PW
PW's Avatar
Send a message via AIM to PW
IslandBwoy....The World's CVD's are manufactured by a seperate company (Titanium Racing) and not Schumacher. Titanium racing parts ony fit titanium racing cvds and Titanium Racing does make a cvd rebiuld kit for the World's CVDs.....BTW,I think it would be more productive to call Schumacher when you have an issue like this instead of have a "Major Beef" title thread.
Happy to hear the Mission setup worked and congrats on your finish!!!
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 04-03-2005, 11:46 PM   #9257
highwayman's Avatar
Originally posted by Jon Kerr
No prblem that's what we're here for.
The stock plate is 2mm. Taking it out and putting 1mm shims will only lower it half way. You can try and lower it to the chassis but I've always found the to give it too much turn in. Way too agressive. Only dropping it 1mm is where I'd start. Make fine adjustments to see what happens. If it's not enough, go all the way to the chassis. The only time I like to make drastic changes and go to the extreme on an adjustment is if I'm not sure what it will do to begin with. That way I can really tell what it's done to the car easily and back off from there to fine tune it.
i tried out the mi2 last saturday, and personally, i prefer lowering the the front arms to the chassis, i really like the turn-in and mid corner steering; however, i think i have a bit too much exit steering that coming out of the corners the it causes the car to be a bit slow, like the front tires are scrubbing too much...
highwayman is offline   Reply With Quote
Old 04-04-2005, 05:35 AM   #9258
IslandBwoy's Avatar
Hey guys,
I wasnt trying to send a flaming Post or antyhing like that nor was i trying to offened anyone by titling it major beef i just wanted to be sure that everyone became aware that these parts are not compatible with the stock cvds. When the LHS and the team guys that i spoke assumed that they were the same size but turned out not to be i figured i would let everyone else know about. Take no offense to my post nor the title. My so called beef with this one part has makes no reflection about how i feel about the best car i've ever driven.
R.
IslandBwoy is offline   Reply With Quote
Old 04-04-2005, 07:49 AM   #9259
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
One thing you may try then is adjusting the rear roll center. Are you using the aluminum hub carriers? If so, I normally run either 1-2mm shim under the ball stud in the inside hole. You can lower that and that will lower the rear roll center and get you a little more rear grip. You could also try lengthening the rear camber links.
Jon Kerr is offline   Reply With Quote
Old 04-04-2005, 09:38 AM   #9260
ouch!!!
rangulo is offline   Reply With Quote
Old 04-04-2005, 10:20 AM   #9261
PW
PW's Avatar
It's all good IslandBwoy
Paul Wynn
Old 04-04-2005, 11:49 AM   #9262
mo
mo's Avatar
Hey PW, did you get my e-mail?
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 04-04-2005, 12:14 PM   #9263
turbodog's Avatar
He didn't, but I did.
Troy Schafer
turbodog is offline   Reply With Quote
Old 04-04-2005, 12:24 PM   #9264
AdrianM's Avatar
PW will be out this week helping Reedy drivers at the Losi Off road race in Tampa.
Adrian Martinez
Old 04-04-2005, 01:21 PM   #9265
mo
mo's Avatar
Cool. As long as someone got it.
Old 04-04-2005, 01:50 PM   #9266
PW
PW's Avatar
Sup Mo....If you sent in an order, Troy will take care of it. If you got any questions, you can reach me at [email protected]
Paul Wynn
Old 04-04-2005, 03:48 PM   #9267
IslandBwoy's Avatar
ON a lighter note does anyone know where i can get an 1/8 inch reemer? I've been to harbor freight, sears and yet noone knows what i'm talking about or only have graduated reemers. I'm willing to pay the price of shipping if you guys know where i can get one for sure. I like to CA the holes in the arm links regularly and reem them out so that are perfect size but it is so cumbersom doing this with an exacto.
Old 04-04-2005, 03:51 PM   #9268
mo
mo's Avatar
I know Dynamite used to sell one. I think Racers Edge also has one. Don't know what shops carry them though.
Old 04-04-2005, 04:09 PM   #9269
hyena boy's Avatar
Default reemer
you could try a machine shop supply house. i know they had a 3mm drill bit that i could not find any where else.
hyena boy is offline   Reply With Quote
Old 04-04-2005, 08:40 PM   #9270
IslandBwoy's Avatar
K. Thanks. I'll try those.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
