Old 03-30-2005, 08:53 PM   #9241
PW
PW's Avatar
Send a message via AIM to PW
Default Re: set up
Originally posted by hyena boy
i am looking for a good place to start with my mi2 this summer. the track can be high grip, usually tight, and is ashfalt. i think i will be running mod. the track is about 180' x 75'. i have most of the chassis hop ups, like temmu chassis, alluminum front knukles and rear hubs, and the lowwer shock towers.
the car was good last year but i would like to try something new this year.
Sorry for the non-sense
Here is my reply incase you missed it:
hyena boy.....We have several setups posted at http://www.racing-cars.com/usa/searc...e1=prodvalue14
You can also visit www.gearchart.com
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 03-31-2005, 07:04 AM   #9242
hyena boy's Avatar
thank you paul. i checked both sites for some ideas. it looks like i need to get a spool. does the spool come with a gear? or should i just lock up the normal dif?
is there something wrong with the site? i tryed twice to get on but it comes up page not found.
hyena boy is offline   Reply With Quote
Old 03-31-2005, 07:16 AM   #9243
PW
PW's Avatar
hyena....Yes, the spool comes with a machined pulley.
I just clicked on the link and it worked for me
Paul Wynn
Old 04-01-2005, 05:24 AM   #9244
The Teacher's Avatar
Trader Rating: 45 (100%+)
Question, for anyone who might know. I just got a set of the Tamiya shocks for my Mi2 and I have run into a problem. How are you guys mounting the top of the shocks??? What hardware are you guys using??? I thought the TR titanium shock mounts would work but they don't fit....I'm I doing something wrong???
Thanks in advance....
Teach
The Teacher is offline   Reply With Quote
Old 04-01-2005, 06:01 AM   #9245
Send a message via ICQ to MattW
Personally i use the Tamiya "Ball nut". Then use an M3 screw through the tower, some nice purple spacers, and the ball nut. The shock then clips to the ball.
MattW is offline   Reply With Quote
Old 04-01-2005, 07:11 AM   #9246
PW
PW's Avatar
Teach
The Titanium Racing purple mounts are for the stock Schumacher shocks, but the ball can be sanded or polished to allow the Tamiya shocks to fit. The other option is the new BMI Racing shock mounts Give them a ring www.bmiracing.com
Paul Wynn
Old 04-01-2005, 07:29 AM   #9247
Thanks PW/MattW looks like I'll be doing some sanding. I'll call BMI on monday, I need to order a chassis anyway....
Old 04-01-2005, 11:55 AM   #9248
PW
PW's Avatar
One of the guys here chucked them up in a drill and sanded them that way; worked well and it's only a very small amount Measure the tamiya ball-end to make sure you don't go to far.
Paul Wynn
Old 04-01-2005, 01:28 PM   #9249
mo
mo's Avatar
You can also use Yokomo upper shock bushings. They snap in but move freely and you don't have to worry about losing them when you remove your shocks.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 04-02-2005, 07:25 AM   #9250
bender's Avatar
Well I just finished building my Mi2 and thought that the way the steering bellcranks are set up is a bit odd.
With the centre track rod at kit length the steering bellcranks angle inwards, instead of facing straight ahead as is seen in most cars.
Is this right? What length should the centre track rod be and has anyone tested the effects of making it longer or shorter?
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 04-02-2005, 09:07 AM   #9251
To mount my tamiya shocks I just opened up the hole in the plastic part of the shock so I could still use the sch. mount. Why, because it was the cheapest way of doing it...
Just measure the sch. ball and drill.
mark barford is offline   Reply With Quote
Old 04-02-2005, 09:29 AM   #9252
PW
PW's Avatar
We all run the link at 40.8mm (bellcranks pointed forward) from end to end. The kit setup will make the car more forgiving.
Paul Wynn
Old 04-03-2005, 04:52 PM   #9253
IslandBwoy's Avatar
Default MAJOR BEEF
Whats up with the world cvd's beeing a different size that the stock/steel cvd's??????? The axle on my CVD was broken (ball seperated from the rest of the axel...I'm sure you've seen this) a few weekends back by a driver taking a hot lap. While i was upset because the race hadn't even started and disappointed because he really didnt hit me that hard I was able to get over it because i had plenty of axles left over from other bent and bruised joints. After finishing the day with one of my spare stock cvd's i though nothing of having to rebuild my brand new purple cvd's that had only 1 run 'em. Low and behold today i get to the track and proceeded with the first order of the day (rebuilding my world cvd's). When i attempted to fit my spare axel into the cup of the joint i was shocked to see that it was too big. So i tried another, then another. I even borrowed a steel cvd axle from Tony to no avail. Then it sunk in. THIS JOINT FITS NOTHING BUT THE WORLD CVD. wtf???? The LHS said that they were not aware of a rebuild kit for the WORLDS CVD's and was also shocked to be informed that the stock rebuild kits would not work. So now i'm left with 3 pretty purple cvd's and a bunch of extra parts including a brand new rebuild kit that i can not use!
Are you guys planning on providing a rebuild kit for the worlds or know of where i can get get an axle that will work or am i SOL??? :-(
In other news: Paul thank for the Mission Setup, It worked perfecty. I took second place in 19T A on Saturday after trying the setup for the first. Now that i have confidence in the setup i'm sure i'll be pulling the trigger a little harder so i'm hoping for 1st in the second round of the point series.
Thanks again.
IslandBwoy is offline   Reply With Quote
Old 04-03-2005, 07:34 PM   #9254
STLNLST's Avatar
Trader Rating: 17 (100%+)
Default Re: MAJOR BEEF
Thanks again.
if you have the world's cvd's then they are an upgraded type hop up so I would assume that you still have your old parts....or am I wrong in assuming this? Until this problem is taken care of can you switch back to the normal cvd's and axles?
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 04-03-2005, 07:47 PM   #9255
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
The Ti racing, Titanium CVD stub axles will fit in the Worlds bone.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
