Old 03-28-2005, 10:30 AM   #9211
Hey Hector where did you get the pic of the dancing fat guy
rangulo is offline   Reply With Quote
Old 03-29-2005, 07:03 AM   #9212
hyena boy's Avatar
Default 1mm shims
are using plastic or metal shims for the roll center? where can i get some? do you use those same shims on the new rear carriers?
hyena boy is offline   Reply With Quote
Old 03-29-2005, 07:06 AM   #9213
PW
PW's Avatar
Send a message via AIM to PW
Default Re: 1mm shims
Most of us use the TakeOff alloy colored spacers. They are offered from .5mm - 3mm
click here http://www.racing-cars.com/usa/main.asp Then type "washer" in the advance search box and select "TakeOff" in the manufacture field
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 03-29-2005, 07:13 AM   #9214
hyena boy's Avatar
thank you paul, i will try to order them soon.
Old 03-29-2005, 12:01 PM   #9215
Hixxy's Avatar
Hi
Would anybody be able to provide me with a starter setup for asphalt. im using a 27 turn.
Thx in advance
mr.hixxy@gmail.com - if you want to email me a set up
Hixxy is offline   Reply With Quote
Old 03-29-2005, 12:09 PM   #9216
PW
PW's Avatar
Originally posted by Hixxy
Hi
Thx in advance
Which car do you have...Mi2, Mission or older?
Paul Wynn
Old 03-29-2005, 12:16 PM   #9217
Crashmaster's Avatar
He's got a Mission Carbon PW. he's just logged off, so I'll fill in.
Cheers, and thanks in advance
Crashmaster
Crashmaster is offline   Reply With Quote
Old 03-29-2005, 12:35 PM   #9218
PW
PW's Avatar
Thanks crashmaster....Mail has been sent
Paul Wynn
Old 03-29-2005, 12:56 PM   #9219
Nice one mate
Cheers
Crashmaster
Old 03-29-2005, 04:58 PM   #9220
IslandBwoy's Avatar
Default MISSION SETUP
BTW. That setup really helped the car a lot Paul. Unfortunately before we could make 2 laps the rain came down at TQ so i wasnt able to fine tune any. The car felt good even without aditive on the tire. Was a little loose but i expected that since i got there only minutes before my heat started and didnt have time to stickum up. I think the major difference was that i was using a much softer oil than 40 and it made the car to soft. Once i up'ed the oil and use two holes for the shocks instead of three the car felt a lot better. Who would have thunk it because my MI2 rocks with the softer oil but i guess i have to keep in mind that these are two very differnt reacting cars.
Either way thanks again,
IslandBwoy is offline   Reply With Quote
Old 03-29-2005, 05:20 PM   #9221
Hey guys,
Fairly new to RC and just bought a second hand MI2. Wanted to know a good setup. I'll only be running in 540 and on a concrete surface.
Cheers,
Shags
shags_j is offline   Reply With Quote
Old 03-29-2005, 05:27 PM   #9222
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Paul Wynn's nationals setup would be a good place to start or if you'd like to give me your Email addy, I'll email you my base setup on an excell spreadsheet. It should be a good base setup on most surfaces.
Jon Kerr is offline   Reply With Quote
Old 03-29-2005, 06:40 PM   #9223
I've PM'd you.
Cheers,
Shags
Old 03-29-2005, 06:58 PM   #9224
Jon Kerr's Avatar
Email sent. Hope it helps.
Old 03-29-2005, 07:12 PM   #9225
scott_g's Avatar
Send a message via MSN to scott_g Send a message via Skype™ to scott_g
Shags_j
I have the setup we run at Brisbane's bayside track - I'm guessing that's possibly the concrete track you'd be running on? If you want that setup pm me with an e-mail address and I'll send you the setup.
Cheers
Scott
scott_g is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
