Old 03-23-2005, 09:33 AM   #9181
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
can somone help me out with a good stock setup for Superior Hobbies or Tq Hobbies? im using the lowerd shock towers and tamiya shocks! Thanks
Roberto Falcon is offline   Reply With Quote
Old 03-23-2005, 09:55 AM   #9182
AdrianM's Avatar
This is the standard starting team setup fpr asphalt:
http://www.gearchart.com/setup/setup...w_2004nats.pdf
Thanks to www.gearchart.com for posting it!
Adrian Martinez
Old 03-23-2005, 02:54 PM   #9183
PW
PW's Avatar
Send a message via AIM to PW
Tony...YGM
Sup mini-dub!!!!!!!!!!
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 03-23-2005, 04:31 PM   #9184
R/C Tech Charter Subscriber
VIRUS?
Is there a problem with the email system at schumacherusa.net? Today I received 3 emails saying that 3 different orders have shipped. But i have not ordered anything from schu for a few months (gotta love that durable mission )
tadmj is offline   Reply With Quote
Old 03-23-2005, 04:37 PM   #9185
PW
PW's Avatar
Default Re: VIRUS?
Sorry for any confusion with the online e-mail. We discovered that the automated e-mail was turned off for the last few months and when reactivated, it mailed responses to the last 900 plus orders
Paul Wynn
Old 03-23-2005, 05:58 PM   #9186
IslandBwoy's Avatar
Whats your e-mail? I will send you the setup we used on our Mission to dominate the Florida State Series
[email protected]
Thanks for the help
IslandBwoy is offline   Reply With Quote
Old 03-23-2005, 06:06 PM   #9187
IslandBwoy's Avatar
The one adrian posted i know works well. Thats what i use and superior and it was a good base when i first tried it at tq.
Old 03-23-2005, 06:08 PM   #9188
IslandBwoy's Avatar
Hey, when you guys find a good working setup for the BMI chasis please share. I'm planning on getting me one and wouldnt mind further testing your setups ;-)
Old 03-24-2005, 07:36 AM   #9189
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I just finished building my BMI car. As soon as I get a good setup on it I'll let everyone know what I found.
Jon Kerr is offline   Reply With Quote
Old 03-24-2005, 08:27 AM   #9190
PW
PW's Avatar
Originally posted by IslandBwoy
[email protected]
Thanks for the help
Sorry, but that e-mail didn't work
Paul Wynn
Old 03-24-2005, 09:25 AM   #9191
IslandBwoy's Avatar
Hmm, I got an email from Schumacher USA about the Eroneous emails today at that address so it SHOULD be working. Either way feel free to send to any of the following.
[email protected]
[email protected]
[email protected]
Thanks again P.
R.
Old 03-24-2005, 02:27 PM   #9192
Super Moderator
Tony Rivas's Avatar
Trader Rating: 53 (100%+)
Originally posted by PW
Tony...YGM
thank pw
The "Dominican Assassin"
Sorry for the Spelling but you know what I mean.
Tony Rivas is offline   Reply With Quote
Old 03-25-2005, 12:34 AM   #9193
bender's Avatar
Hey guys,
I will be getting an Mi2 in a couple of weeks, and I'm relatively new to touring cars so i've got a few questions about the car.
I have noticed on various setup sheets that some drivers either raise the plate that the suspension mounts are on or remove the plate altogether. What does raising and lowering the suspension mount height do?
I assume it changes the rate of camber change as the hub carrier is moved and it also changes the roll center but could someone explain what each change does ie: Lower mounting block = lower/higher rollcentre = X handling.
Secondly, what are differences/reasons behind running the different drive pulleys (17T & 20T). I have a lot of theories as to the effects these have but I would like to hear what everybodies experiences are with the different drive ratios.
cheers,
Jason
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 03-25-2005, 07:34 AM   #9194
Jon Kerr's Avatar
Raising and lowering the suspension mounts raises and lowers the roll center. As a general rule, lowing the mount will lower the roll center and get you more grip on that end. For instance, if I needed a lot more steering going into the corner, I would lower the front suspension. If the rear is too free, I'd lower the rear. We also angle the suspension as well by using anti/pro squat in the rear and kick up/anti dive in the front. I haven't needed to use kick/anti dive yet but adding anti squat helps the car a lot if you're too free coming out of the corners on power.
Different pulleys will give slightly different drive ratios. That's it.
Hope this helps
Old 03-25-2005, 04:54 PM   #9195
IslandBwoy's Avatar
Default one way -> spool
Does anyone know how i can conver my one way into a spool? I would prefer stomething that is reversable but if not thats ok.
Thanks,
R.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
