Old 02-28-2005, 01:01 PM   #9046
Wicked's Avatar
Originally posted by Jon Kerr
Any Carbon Fiber plate chassis should be sanded on the edges and sealed with CA glue. You do this for a couple reasons. One is to keep it from splintering from any impacts. Also, CF is highly conductive. If you allow the ends of your cells to touch raw, un-sealed graphite, it will short out your battery.
Do I do everything? chassis, upper deck, shock towers, battery bar
Baja 5B Flux, Baja 5T, HPI Savage Flux XL, Brushless Erevo, Summit, X Maxx, Arrma Big Rock, Tamiya Bruiser, & Hi lux, Slash, Skully,
Blade 200qx, Inductrix 200, Nano qx2 fpv, Cx, Proto X SLT
Wicked is offline   Reply With Quote
Old 02-28-2005, 01:27 PM   #9047
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I do it all. Makes sure everything is sealed and not going to split. Besides, it give the car a nice finished look when it's done right.
Jon Kerr is offline   Reply With Quote
Old 02-28-2005, 01:47 PM   #9048
Wicked's Avatar
Hey thanks mann. You got any pointers for me before I do this?
Old 02-28-2005, 02:22 PM   #9049
Jon Kerr's Avatar
Sand the edges down lighly, use thin CA and put a little on a Q-tip and run it accross the edge quickly. You don't want gobbs of CA all over the chassis.
Old 02-28-2005, 03:34 PM   #9050
Fran's Avatar
Trader Rating: 147 (100%+)
Hey Jon,
In the pic of your car where your showing the added weight, I noticed your usung different ball cups. Are those Losi or RPM? Do they fit tighter than the "ball grippa's"? Thanks..
Roadrunnersrc.com
Team Associated 12R5.2
Team Associated 10R5.1
Team Associated TC5
Team Associated F6
Fran is offline   Reply With Quote
Old 02-28-2005, 04:17 PM   #9051
Jon Kerr's Avatar
Those are Losi and they have since been replaced by RPM. I like the fit of the RPM ones much better.
Old 03-01-2005, 04:02 PM   #9052
Prototype CAT 4K
Arn0 is offline   Reply With Quote
Old 03-01-2005, 05:16 PM   #9053
hyena boy's Avatar
Default new cat
that looks cool...when will it be avallable? what parts will it share with the mi2? it would be good to have a new 4wd.
hyena boy is offline   Reply With Quote
Old 03-01-2005, 10:07 PM   #9054
speedxl's Avatar
R/C Tech Charter Subscriber
I use the RPM ones aswell they fit snug without binding and just about as tight as the grippa stock ends! They eliminate the slopp!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 03-02-2005, 07:04 AM   #9055
Super Moderator
Tony Rivas's Avatar
Trader Rating: 53 (100%+)
ya i go with the rpm too!!
The "Dominican Assassin"
Sorry for the Spelling but you know what I mean.
Tony Rivas is offline   Reply With Quote
Old 03-02-2005, 11:14 AM   #9056
Fran's Avatar
Thanks guys, that's what I wanted to hear... no more slop
For those using the Tamiya shocks, has anyone else switched to the black O-ring, over the clear ones? And do you also find that the "teflon?" washer that extends out of the botton of the shock, where the shaft slides through, tends to open up a bit. After a race day, the oil in the body is still fairly clean, but the shafts are"wet" and atract dirt. Just curious how often, or when you guys put in new seals and o-rings (the "kit" from Tamiya @ Speedtech is under 5 bucks). Thanks
Roadrunnersrc.com
Team Associated TC5
Team Associated F6
Old 03-02-2005, 11:57 AM   #9057
Jon Kerr's Avatar
The only time I've seen the seals at the bottom of the TRF shocks do that is when the shocks aren't perfectly upright (front to back, not angled side to side.) they tend to wear a little. But mine have been fine for 6 months now with no problems.
Old 03-02-2005, 12:35 PM   #9058
Fran's Avatar
are you using the clear O-ring or the black one? I've got the black one in, and it seams to seal better.
Roadrunnersrc.com
Team Associated TC5
Team Associated F6
Old 03-02-2005, 12:37 PM   #9059
Jon Kerr's Avatar
I'm using the clear one.
Old 03-02-2005, 12:50 PM   #9060
speedxl's Avatar
I got the black ones but my shocks dont leak at all. Thats odd. I will usually get some tire dust on the bottom of the shafts but they are dry.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
