Old 02-20-2005, 08:31 PM   #8986
LoSi xXx S
I am not a Team driver nor do I play one on TV
But....
Having owned other Schumacher TCs and now owning the Mi2 I have never had an issue with building the shocks. While I cannot argue that Tamiya shocks are much easier to build, the Schumacher shocks are not a problem and when built properly perform just as well as any others.
Given that, if you search for AdrianM on the Schumacher thread he once gave a step by step sure fire way of building the shocks. Follow those steps and you should not have any problem.
If you still want to get rid ofyour Schumacher shocks, I will give you a FedEx shipping account and you can mail them to me.
LeadFoot is offline   Reply With Quote
Old 02-20-2005, 08:47 PM   #8987
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally posted by LoSi xXx S
ok i just got done building the kit and man its sweet! i instaled my tc4 shocks on it cause those schumacher shocks are a pain in the @ss ! i only got to build one and i gaved up to me forever! but anyways i was trying to set my droop with the ae droop gauge. with the droop screw all the way out the car had like 6=9 in droop , is that right ? im so lost ! thats the only thing thats bugging me .
tony whats a good starting setup for TQ? should i go with 1.5 toe in on the rear or stick to 3.0 ? right now the setup is stock with out locked front diff or anything. should i go locked and what ride hieght ? i set it up to 4.5 all around , is that normal that the front feels softer than the rears and im useing 40w oil in the front and 30 i think in the rear and the front end feels way softer than the rear?
Thanks,
Roberto
The way I measure droop is to set your ride height (say to 5mm) at both ends. Then lift the car up by the notch in the center of the shock tower to unload the suspension on that end. Set the car back onto your pit board but just barely. Let the tires touch but don't let the suspension on the end you're lifting compress at all. Then measure the ride height again in the same spot and figure the difference. If the second measurement is 8mm and your ride height is 5mm, you've got 3mm of droop. I run 3mm in the rear and 2 or 2.5mm in the front usually on outdoor asphalt. After I set it this way, I'll pull the wheels off and use the new Schumacher droop gauge to check and make sure both sides are perfectly equal. Just use small adjustments to equal them out so you don't make a major change to the actual droop setting and you should be good to go.
Jon Kerr is offline   Reply With Quote
Old 02-20-2005, 08:48 PM   #8988
Jon Kerr's Avatar
Here's a link to the Schumacher gauge I use.
http://www.racing-cars.com/usa/produ...ecnumber=64932
Old 02-21-2005, 11:24 AM   #8989
Super Moderator
Tony Rivas's Avatar
Trader Rating: 53 (100%+)
Thanks,
Roberto
Hey Roberto i used integy gauges try this
FRONT:
SPOOL
oil 40 3 hole piston
silver ae springs
droop:3
sway bar 1.4mm
4 caster block
ride height 4
outside on shock tower middle top hole tower
-1 on camber
lower wishbone middle
stock riser plate on capet shock tower
REAR:
green ae springs
droop:4
no sway bar
2.5 rear blocks
ride hight 4.5
3rd hole in on sock tower
1.5 on camber
lower wishbone to the rear
ae rear hubs
carpet shock tower
this set up works for me there for stock try it and let me know
The "Dominican Assassin"
Sorry for the Spelling but you know what I mean.
Tony Rivas is offline   Reply With Quote
Old 02-21-2005, 12:01 PM   #8990
Send a message via AIM to Roberto Falcon
i was at the track today and this car is awsome! everything went well and is car is the bomb lol . right now im runing stock and runing the stock setup with tc4 shocks as i stated before i think im runing 45w sch stock oil in front and 40w ae oil in the rear with blue springs up front and silver in the rear . and the car kinda dives in the front when taking a turn but you could hardly feel or notice it
my question is should i go with 50w oil blue springs up front ? and why does the rear feels stiffer than the front are all cars like that? my tc4 was like that too but my pro 4 isnt you could feel which end is softer .
Tony should i lock my front diff up for TQ? is it worth it im just going to run stock and maybe 19t
Roberto Falcon is offline   Reply With Quote
Old 02-21-2005, 12:05 PM   #8991
oh didnt see your post Tony . Thanks i will let you know what happens
Old 02-21-2005, 03:58 PM   #8992
Super Moderator
Tony Rivas's Avatar
Old 02-21-2005, 04:34 PM   #8993
Default 2005 ROAR ON-ROAD CARPET NATIONALS
Is anyone from Team Schumacher going to be running at the 2005 ROAR ON-ROAD CARPET NATIONALS @ Hobby Chambers in West Haven, CT?
This is my home track and am wondering if anyone will running at the race.
Old 02-21-2005, 04:54 PM   #8994
rcshark's Avatar
Send a message via Yahoo to rcshark
hay how do I adjust this new spool that I got?
its there any pics of the cars at the snow birds posted yet?
and is there set ups online yet?
just wanted to see if i could make someone laugh today!!!!
how do adjust this thingy?
the car is faster then my eye also, but it sees for me! but would like to get a look at some more ideals!
rcshark is offline   Reply With Quote
Old 02-21-2005, 09:37 PM   #8995
Losi XXX S- The reason that the front end of your car feels "lighter", is that it is. The leverage on the shock absorber is greater on the front end because the bottom of the shock has been moved in on the suspension arm to provide clearance for the wheel/ tire assembly as it turns. This means that with the same spring combo front and rear, that the wheel rate will be less in the front.
As for the oil, I have found that a front to rear split is usually necessary (for the reason stated above). 50wt will "tame" down the front of the car, and in most cases hold the weight over the front end slightly longer in a turn- giving you more exit steering and less initial (because it won't transfer weight to the front end as quickly when decelerating). The associated sping combo works well (blue/silver front, silver rear) on every track I have run on, so it is a good starting point.
Jay Dub is offline   Reply With Quote
Old 02-22-2005, 09:59 AM   #8996
do you guess think that schumacher will release a new car soon as the competition is making new cars ? i think they are working on somthing though !
Old 02-22-2005, 11:42 AM   #8997
Jon Kerr's Avatar
No new car in the works for Schumacher right now. There are always new parts etc. being tested but as far as a new car goes, nothing in the works right now.
Old 02-22-2005, 12:10 PM   #8998
jon kerr how tight should i run my belts ?
Old 02-22-2005, 12:13 PM   #8999
Jon Kerr's Avatar
What class are you running? Mod or stock?
Old 02-22-2005, 12:16 PM   #9000
stock and somtimes 19t
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
