Old 02-17-2005, 08:26 AM   #8941
Trader Rating: 17 (100%+)
Send a message via AIM to Roberto Falcon
Thanks Tony
can some one answer that question about if i can use tc4/tc3 shocks on this car with out buying the lowered shock towers? What do you guys think, is it better in buying the lowered towers and buying the tamiya shocks ? but thats like almost $100 ! its like buying a new RDX again .
Roberto Falcon is offline   Reply With Quote
Old 02-17-2005, 08:39 AM   #8942
Jon Kerr's Avatar
Personally I'd never put AE shocks on a car. I can't stand them. As long as you can get them to the right length and get them mounted, I don't see a problem.
Jon Kerr is offline   Reply With Quote
Old 02-17-2005, 08:47 AM   #8943
Alright thanks,
Jon, do you know where or someone who has them lowerd shock towers that they will want to get rid of them or just dont need them that they could sell to me?
Old 02-17-2005, 09:41 AM   #8944
Jon Kerr's Avatar
Sorry. I don't. You can probably order them from Schumacher direct or if your local hobbys ship stocks Schumacher, have them order them for you.
Old 02-17-2005, 10:10 AM   #8945
Send a message via ICQ to MattW
TC3 shocks are exactly the same length as Schumacher std ones, so they will fit straight on the std mounts. They have a little more travel than the std ones, but they are nothing special when it comes to shocks really.
They are ok, and probably have a few benefits over std ones, but i wouldn't go out and buy a set specially.
MattW is offline   Reply With Quote
Old 02-17-2005, 10:26 AM   #8946
i should rather go with tamiya shocks and lowered shock towers right?
Old 02-17-2005, 10:41 AM   #8947
IslandBwoy's Avatar
Islandbwoy, It may be as simple as replacing you spur gear. That is about the only thing that makes my car loud.
Hmm. I recently went to 64 pitch gears so the spur is fairly new (one maybe two events new). When does it becoem necessary to replace the spur gear other than when it gets sripped? Im running the robinsons btw.
IslandBwoy is offline   Reply With Quote
Old 02-17-2005, 12:02 PM   #8948
Jon Kerr's Avatar
That's what I do. TRF shocks are simply the best on the market right now. They're smooth, easy to build and honestly, they look quite nice too. Different shocks aren't really something you absolutly HAVE to do. But it is nice to have them on the car because if the ease of use and consistancy.
Old 02-17-2005, 12:06 PM   #8949
OH! um so the good ones are good ? cause everyone at my track has the tamiya ones , does the regular shocks can i fit ae springs ?
Jon Kerr thanks alot for your help .
Old 02-17-2005, 12:24 PM   #8950
Jon Kerr's Avatar
Not a problem. That's what we're here for.
As for the AE springs on stock shocks, I think you have to use spacers in addition to the threaded collars to get the ride height correct since the AE springs are shorter than stock ones.
Old 02-17-2005, 01:25 PM   #8951
LoSi xXx S:
I have XRay and AE Springs and they work fine as long as you use spacers.
I simply use 1 large spacer and that compensates for the difference
LeadFoot is offline   Reply With Quote
Old 02-17-2005, 01:28 PM   #8952
Send a message via AIM to kabttu
are the TRF Shocks a straight install or is any modification needed?
[edit] I'm using a Mission by the way. Will they even work on a Mission?
kabttu is offline   Reply With Quote
Old 02-17-2005, 02:17 PM   #8953
Jon Kerr's Avatar
I'm not too sure on a Mission. I never ran that car.
Old 02-17-2005, 03:14 PM   #8954
They will fit a mission, just need a slightly longer than std TRF bottom joint. Think i ran assiciated bottom joint from memory.
Old 02-17-2005, 03:57 PM   #8955
Super Moderator
Tony Rivas's Avatar
Trader Rating: 53 (100%+)
[QUOTE]Originally posted by LoSi xXx S
[B]OH! um so the good ones are good ? cause everyone at my track has the tamiya ones , does the regular shocks can i fit ae springs ?
hey i still run the regular shocks but i cut 2mm of the bottem of the shock shaft and cut the ball cup 1mm on the top to get full ride hight with the lower shock tower. I got this from mo
The "Dominican Assassin"
Sorry for the Spelling but you know what I mean.
Tony Rivas is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
