Old 01-30-2005, 07:48 PM   #8836
rcshark's Avatar
Send a message via Yahoo to rcshark
that luck! I finely get my mi2 going and the the only track in houston is closed. what a week end. I put in a 10 d. just to try it out and it hooked up like a rocket out of the hole had alittle slippage and then the rear belt broke! Im glad that happen on a off weekend. My mi2 was hooked up for the few runs I made with the rear hooked tight. now I have to get a belt!
could someone give me the demetions of the two belts and see if I could mach them up with something else I thank I know the rear belt. but didnt want to count the front belt or take it off the car.
rcshark is offline   Reply With Quote
Old 01-30-2005, 10:34 PM   #8837
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Sure good to see Rob in here
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 01-31-2005, 05:30 AM   #8838
Rob Mincey's Avatar
Thanks, Dave. Just lurking about, reading up on the new car. See you at the track.
Good luck at the 'Birds. To quote your oh-so-favorite phrase, "GIT-R-DONE!"
Rob
Rob Mincey is offline   Reply With Quote
Old 01-31-2005, 07:28 AM   #8839
hyena boy's Avatar
i have the aluminum front nukles, and i was going to use the optional holes but it limmited the stearing one the car. is there a way around this? the servo saver arm was bumping into the stearing ti rod.
hyena boy is offline   Reply With Quote
Old 01-31-2005, 09:43 AM   #8840
Trader Rating: 57 (100%+)
Default finally
finally got all the oklahoma brahma drivers converted to the Schuie.....use the force guys....
gporta77 is offline   Reply With Quote
Old 01-31-2005, 10:18 AM   #8841
Default indoor track
thanks rob, i hope there still racing when i come down there from parkersburg west virginia in a couple of weeks
livewyer2003 is offline   Reply With Quote
Old 01-31-2005, 10:34 AM   #8842
John_S's Avatar
hey thanks guys ill try those things on friday
John_S is offline   Reply With Quote
Old 01-31-2005, 12:13 PM   #8843
Send a message via ICQ to MattW
john_s, pro bearing uses Tungsten Carbide balls, much better
MattW is offline   Reply With Quote
Old 01-31-2005, 11:50 PM   #8844
Default Shock rebound
I have just rebuilt my TRF shocks (how easy are they to do )
I filled the shocks with oil (35w schuey oil) to the top of the housing so there was no air in the shock, but although the shock feels very smooth I get full rebound from the shaft (shaft extends to it's full extension).
Is that wrong and if so Why?
What will it cause/
Also my front two shocks had a red damper rubber between the top of the bladder and the housing, but the rear did not, should I have put it back and why.
The shocks came on the car when i purchased it second hand, so it's the first time I have had them apart, so i'm not sure what normal should be.
Mick
ratter is offline   Reply With Quote
Old 02-01-2005, 01:37 AM   #8845
Ratter, re-bound can be adjusted depending on where the shaft is when you put the top bladder on. If you want less re-bound, push the shaft into the body a little before putting the bladder on and bleeding the excess oil out.
The pink foam increases rebound. Personally i don't use it in any of them.
Old 02-01-2005, 06:21 AM   #8846
AdrianM's Avatar
I push the piston all the way in then put the bladder on and close the shock.
Adrian Martinez
Old 02-01-2005, 06:26 AM   #8847
Trader Rating: 70 (100%+)
Send a message via AIM to TexRacer
Adrian-I push the piston all the way in???
Meaning you make sure the piston is at the bottom of the shock and the shaft is all the way out?
That would make for the most rebound correct?
*****Look me up on Ebay. I will have alot of stuff going up as 7/7/2016. User name is Dalracer.**** This is going to be a BIG ONE!!!!!!
Just wanted to say Thanks to RcTech for all these years of Great Information.
TexRacer is offline   Reply With Quote
Old 02-01-2005, 06:41 AM   #8848
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
Default Gabe..
ppsstt! You missed one! HAHAHA !
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 02-01-2005, 06:57 AM   #8849
AdrianM's Avatar
Tex - Pushed in as pushing the shaft into the body so the pistion is closest to the bladder.
Adrian Martinez
Old 02-01-2005, 09:23 AM   #8850
I've been meaning to try the 2 orings at the top instead of the foam piece in the TRFs. Anyone try it and like it?
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
