Old 01-28-2005, 07:23 AM   #8821
AdrianM's Avatar
Not at the moment. For some reason Schu UK is out of them. I would imagine we would have them here in a week or two.
Adrian Martinez
Old 01-28-2005, 07:23 AM   #8822
IslandBwoy's Avatar
Thanks again adrian for your tips. I finally had the time to rebuild my shocks lastnight and your method works great. I had one shock that gave me a hell of a fight but after i realized taht i didnt put the piece with the foamies in it worked. Long night! :-(
IslandBwoy is offline   Reply With Quote
Old 01-28-2005, 09:35 AM   #8823
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
I'm gonna run the car on rubber tires for the first time tomorrow. Just trying to stay fresh for the birds. Really looking forward to running this car again. Its just awesome.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 01-28-2005, 09:41 AM   #8824
Rob Mincey's Avatar
Where you running, Dave?
Rob
Rob Mincey is offline   Reply With Quote
Old 01-28-2005, 10:04 AM   #8825
Comp or Enid, not sure yet. You get your car?
Old 01-28-2005, 10:53 AM   #8826
Rob Mincey's Avatar
Not yet. Chris is sending it out 2nd day FedEx today.
Rob
Old 01-29-2005, 12:41 PM   #8827
STLNLST's Avatar
Trader Rating: 17 (100%+)
TTT
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-29-2005, 12:53 PM   #8828
Matt Howard's Avatar
Originally posted by STLNLST
TTT
Toasty!
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-30-2005, 12:14 PM   #8829
John_S's Avatar
hey guys i was just wanting to ask for some setup advice. My car is over rotating on corner exit from slow corners, what would you suggest?
1 more thing what is the difference between the thurst bearing and pro thurst bearing
John_S is offline   Reply With Quote
Old 01-30-2005, 12:22 PM   #8830
STLNLST's Avatar
How is the rear end of your car set up right now? Are you using softer oil/spring in the rear than the front?
Old 01-30-2005, 01:31 PM   #8831
John_S's Avatar
yeah i have grey springs on rear and blue on front with 40 oil front and rear and 2 hole on the pistons, all other rear settings are standard
Old 01-30-2005, 03:32 PM   #8832
I have found, that too soft a rear spring will make this happen, the car will roll over to far and will make the rear end like a pendulum.
I raced the mission again for the first time in a few months, i went back to near kit, and started going in new directions re roll center etc, asphalt on foam i always preferred short low links, i started going the other way, and i got rid of the mod corner push it had, i think the front end is pretty good now, just need a little work on the rear. Still looking forward to the release of the BMI chassis, as my kit one is getting worse for wear.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 01-30-2005, 03:50 PM   #8833
mo
mo's Avatar
If it is spinning out on power, try adding some anti-squat or standing up the rear shocks to give you more forward traction. These will also give you more off power steering at the same time.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is online now   Reply With Quote
Old 01-30-2005, 08:34 PM   #8834
Default indoor racing
Big i need and i really would like to know if there is any in door tracks for 1/10th and 1/12th scale on road cars, around leavenwoth ks or lawrence ks or topeka ks.?
livewyer2003 is offline   Reply With Quote
Old 01-30-2005, 08:39 PM   #8835
Rob Mincey's Avatar
Live - check out Hutchinson, KS. The track is at High Performance Hobbies. Indoor carpet, and they run 1/10th rubber (Novice), 1/10th foam, and 1/12th foam.
Website is www.hphobbies.com
Not TOO far from Lawrence/Topeka.
Rob
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
