Old 01-26-2005, 08:04 AM   #8806
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
2nd? i dont think so... i got the farthest... pay attention in class.....
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 01-26-2005, 08:11 AM   #8807
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
I got a BMI chassis now, bring on the birds lol
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 01-26-2005, 08:33 AM   #8808
speedxl's Avatar
R/C Tech Charter Subscriber
Hi Adrian. whats up dog!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 01-26-2005, 09:16 AM   #8809
Fran's Avatar
Trader Rating: 147 (100%+)
Who's going to be mindin' the store?
Adrian, you have a pm
Fran is offline   Reply With Quote
Old 01-26-2005, 02:57 PM   #8810
I heard that Brian is going to be buying drinks monday night during the OU/OSU basketball game for the whole team.
Old 01-26-2005, 03:08 PM   #8811
yeah... all the water you can drink
Old 01-26-2005, 06:10 PM   #8812
rcshark's Avatar
Send a message via Yahoo to rcshark
how can I id the type of caster yoke when there were thrown in the same box with the others?
rcshark is offline   Reply With Quote
Old 01-26-2005, 06:44 PM   #8813
very carefully... if you look at the mold around the hole, you might be able to tell which holes are at a bigger angle...
Old 01-26-2005, 07:04 PM   #8814
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
When I get them in and they're just coming out of the package, I mark them with a silver Sharpie so I don't have to try and Eyeball them.
Jon Kerr is offline   Reply With Quote
Old 01-26-2005, 07:32 PM   #8815
rcshark
I had the same problem. I ended up using my car and an integy setup station and figuring out which one was which. I then marked them as Jon Kerr said.
Hopefully someone at Schumacher will mold in the number in a future release of the part.
LeadFoot is offline   Reply With Quote
Old 01-26-2005, 07:58 PM   #8816
rcshark's Avatar
thanks guys i used a hex driver and sliped them on two at a time and mached them up and then put what i thought would the stock ones and what ever I have it works now! I got the car already put together and it had two diffrent ones on it. Man this car rocks its realy planted! I can see why the spool is so talked about!
today I put a mod 10/t in it and it felt as good as my axis did with a stock motor in it!!!!
I missed out on the 19t serise but hopfuly I will win the mod. series next month.
Old 01-27-2005, 06:25 AM   #8817
IslandBwoy's Avatar
Default Shock rebound
Hey Guys,
After being spoiled with the Tamiya shocks and how easy they are to put together I kinda realized that i've been building my shocks wrong all this time. My understand or misunderstand was that you shoud fill the schock with as much oil so that when the piston is compressed (without the spring) that it would rebound all the way out which made my orignal configurations really really really hard. I mean to the point were i had to realy try to compress the damn thing just so it comes all the way out when I let it go. Eitehr way, what is the proper proceedure for building the schu shocks? Do you guys have a trick that i can use to get them just right? I surely wish schu would come out with a new blader type shock like the Tamiya's :-(
R.
IslandBwoy is offline   Reply With Quote
Old 01-27-2005, 07:28 AM   #8818
AdrianM's Avatar
Building Schu Shocks:
1. I fill up my schu shocks all the way to the top of the body with oil.
2. Put a couple of drops of oil on top of the cartridge and pull the piston back into that oil puddle. This keeps air from getting trapped behind the piston.
3. Keep the piston pulled against the cartridge and out it into the shock body. Oil will be pushed out as you start to screw it in.
4. When the cartridge is in so that the seal o ring is 0.5mm from the body push the shock shaft all the way in. More oil will flow past the threads and out of the shock.
5. While keeping the piston pushed all the way in finish tightening the shock cartridge.
6. Check your shock rebound. They should all rebound ~5mm....if you are lucky...lol!
7. To equalize the shocks pick the one with the most rebound and side load the shock shaft and push it in all the way. You can use moderate force. You are trying to release tension from one side of the seal o-rings to allow a small drop of oil to burp past them. This reduces the internal oil volume and will reduce the rebound.
8. Burp all of you shock using this method until they all match the shock with the least rebound.
I do not like building shocks with lots of rebound. If one shock leaks a tiny bit of oil it will lose some rebound and you car will feel tweaked due to the mismatch. This is a real pain to spot on a race day. Like I said if you have ~5mm or less of rebound this will not be a problem.
Adrian Martinez
Old 01-27-2005, 11:33 AM   #8819
IslandBwoy's Avatar
Ahh!,
Good techniques.
Thanks.
Oh. PS. Before i forget. I have the alloy steel housings and it seems that is much more difficult to get the larger o-ring to snap into the housing than the plastic ones. Is it ok to just force it in or do i not need to worry about it since the piece with the sponges will rest on top of it?
R.
Old 01-28-2005, 06:05 AM   #8820
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Adrian do you guys have spools in ?
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
