Old 12-21-2001, 04:03 PM   #856
Mopar's Avatar
Good luck Saturday Sherman. I won't make it up this week to So-Cal, got my order in today but no bumpers. And it came to late in the day (regular delivery) to go up tonight for off-road. So with next week's shipping schedule probably wont get to race for two more weeks. Merry Christmas to all!!!
Schumacher KF2se, Associated B5m CE (sold), Hot Bodies D413, Associated T5m, Axial Exo Terra, Schumacher Mi5, CRC 1/12, 3Racing FGX full suspension, Associated 18r
Mopar is offline   Reply With Quote
Old 12-21-2001, 05:50 PM   #857
Racer X's Avatar
Got my one-ways and some of them purplonium parts in today, so it's off to Stockton tomorrow to see how they work. Trying something new with the front bumper, too. We'll see how it goes!
Racer X is offline   Reply With Quote
Old 12-21-2001, 09:08 PM   #858
ottoman's Avatar
R/C Tech Charter Subscriber
Kevin... got my oneway today so it looks good for Sun at Trackside. You gonna be there?
ottoman is offline   Reply With Quote
Old 12-21-2001, 11:31 PM   #859
Mopar's Avatar
My Mission Pro set-up after 1 day of practice.
  • Front:
    #3 top shock
    #1 lower shock
    #1 inner upper arm
    #2 outer upper
    #2 steering
    0* deg inner toe
    1/2* deg outer toe
    8.5* caster
    1.5* deg camber
    55wt oil
    RPM Green pistons
    Blue springs
    0mm droop
    steel blades
    standard swaybar
    6mm ride hgt
  • Rear:
    #4 top shock
    #1 lower shock
    #1 inner upper arm
    #2 outer upper
    0* deg inner toe
    1.5* deg outer toe
    0* deg anti-squat
    1.5* deg camber
    middle pos wheelbase
    50wt oil
    RPM Yellow pistons
    Blue springs
    0mm droop
    plastic blades
    standard swaybar
    6.5mm ride hgt
I really like using the RPM two stage pistons, they give the car a differant feel that you just have to try. However, if you use the stock shock shafts, you must modify the pistons to fit the thinner profile of the stock pistons. I also use the Losi gold shafts to make a smoother ride and easier install on the RPM's.
  • GM3 stock motor
    33t pinion / 116t spur / 17t pulley
    Proline Stratus
    Sorex 36R w/ HPI green inserts
    Trinity Zip Grip 2 sauce
This set-up is for So-Cal's high bite track.
Old 12-22-2001, 12:46 AM   #860
Mopar's Avatar
Trying out a camera that i've had for over a year now.
Old 12-22-2001, 10:29 AM   #861
ottoman's Avatar
Has anyone installed the one way or the gray front belt yet? I am putting both in and I have a couple of questions. First, my grey belt is very tight, tighter than I would ever run it even with the adj all the way down. Do these belts loosen up a lot with use? Second, my one way has a lot of side to side movement when installed in the car, about .100. I dont think it will hurt anything but it doesnt seem right. Does Schumacher make shims I can put between the bearing and the outdrive?
Old 12-22-2001, 10:39 AM   #862
ottoman's Avatar
Sorry, after measuring the side clearance it is about .055. Still way more than I would like to see.
Old 12-22-2001, 11:12 AM   #863
cornerspeed's Avatar
ottoman-I don't know yet about the grey belt tightness, but the diff side-to-side movement I think is ok. It just means that the diff is free and not bound up in any way. On the Axis 2 I used to shim between the trans housings to make sure there was side-to-side movement and diffs were free. Made the drivetrain more free.
cornerspeed is online now   Reply With Quote
Old 12-22-2001, 01:40 PM   #864
ottoman's Avatar
cornerspeed.... the front ball diff had about .010 side play wich is great but .055 could let one outdrive on the oneway to move off of the inner bearing. I didnt measure the inner bearing yet but they didnt look very wide. If it does come off the inner bearing it could cause damage to the one way bearing. I tried TC3 diff shimms but the inside diameter is too small. I guess I will just have to hunt up some shims somewhere.
Old 12-22-2001, 03:34 PM   #865
Send a message via ICQ to MattW
I didn't check float when i had the one-way in the car and it's got a diff in now so can't check it.
The grey belts do generally loosen up quiet a lot, although mine is still a little tighter than the black one was.
MattW is offline   Reply With Quote
Old 12-22-2001, 03:52 PM   #866
Mopar's Avatar
My black belt was a little bit loose. But the new grey belt is way looser, with no run time on it. So I hope it doesn't stretch too much.
Old 12-22-2001, 09:25 PM   #867
ottoman's Avatar
Mopar... My black belt was pretty loose, I had to move my adj up about 1/4 way and I run my belts loose. My gray is very tight, I was thinking of removing the adj untill it loosens up. I guess there is a big variance in belts.
Old 12-22-2001, 10:39 PM   #868
Mopar's Avatar
Maybe Paul or Adrian can answer that question?
Old 12-23-2001, 12:53 AM   #869
tc3driver's Avatar
Send a message via AIM to tc3driver
Default YESSSSSS I MADE THE A MAIN WITHT HE MISSION!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
saturday @ socal!!!!...... YESSSSSSSSSSSSSSSSS
setups? setups ne one!!!!
front:
shock upper: #3
Shock lower: #1
shock oil : trinity 80 w
pistons:2
inner upper arm: #1
outer upper knuckle: #1
steering knuckle: #2
inboard toe: 0 deg
outboard toe: 0 deg
spring : gray
standard rollbar
caster: 2 spacers between rear of block and arm
camber: 2 deg
shock length: 66mm
droop: 3 mm
plastick drive shafts
ride height 5.0 mm
rear
shock upper: 3#
shock lower; 1#
shock oil: trinity 80w
pistons: 2
inner arm upper : 1
outer upper knuckle: 1
toe link: 1
inboard toe : 0 deg
outboard toe: 3 deg
spring: blue
standard roll bar
caster standard
camber: 2 deg
shock length: 66mm
droop: 3mm
plstic drive shafts
ride height 5.5mm:
tire:
sorex 36r
insert yokomo firm
motor: reedy MVP 24 deg stock
35/112
20 tooth drive gear
paragon groundeffex (black can)
this setup was a lottle pushy for me but, very easy to drive and I think a good base line for a high traction indoor "short" but fast course.... I am gonna try using the inner upper arm to hole #2 both front and back or mabey just front that should give me a little more agressive drive
tc3driver is offline   Reply With Quote
Old 12-23-2001, 12:56 AM   #870
tc3driver's Avatar
Default too bad
I got hacked in the A main.... and the setup that I just posted was my frst time out witht he car... and the first time that I have seen a track sence the roar nats... so a-main in sotck at socal aint bad
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
