Old 01-16-2005, 12:22 PM   #8656
Send a message via ICQ to MattW
Arjen, I'll try and find the part number for the parts that i use.
PW, yeah i think you're right, the bumper on my car is starting to look a little suspect.
MattW is offline   Reply With Quote
Old 01-16-2005, 12:31 PM   #8657
Dragonxmx's Avatar
Default Tamiya shocks
Hey guys, we use TRF shocks interchangably with the Schumacher shocks. All you need to do is order the HPI pro 4 plastic ball ends, there like the Associated but the inside hole is 3mm. Cut the flange off with an exacto knife and voila! Pop it in the shock and you're in business.
wrench
Dragonxmx is offline   Reply With Quote
Old 01-16-2005, 12:31 PM   #8658
Arjen
Fairly sure this is the part that i used for the top mounting
TAM53598
Tamiya
FLUORINE COATED 5MM ALUM BALL CONNECTOR (10)
It's an internally threaded 5mm ball nut.
Old 01-16-2005, 12:42 PM   #8659
Thanks for your help.
Arjen
Arjen is offline   Reply With Quote
Old 01-16-2005, 02:31 PM   #8660
rcshark's Avatar
Send a message via Yahoo to rcshark
pw thanks! Now what do I use (stop) fuel tubing?
what do you thank about the set up it works with the rear litttle loose even on low traction at the b-ball court its driveable
rcshark is offline   Reply With Quote
Old 01-16-2005, 02:54 PM   #8661
PW
PW's Avatar
Send a message via AIM to PW
I use schumacher kwik-clips on the outside of the shaft. Not sure about the setup, check www.racing-cars.com for setups.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 01-16-2005, 05:37 PM   #8662
protc3's Avatar
hey paul,give me a ring tommorow buddy.
adrian,that car of yours was hooked today bro.thanks for letting me take it for a spin.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 01-16-2005, 05:52 PM   #8663
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
I got to see Brians MI2 with the new BMI chassis last night and I got to say that is one sweet looking car. Very nice work. Looks as good as the 350
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 01-16-2005, 06:03 PM   #8664
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Leaning toward a Schumacher David? I think We'll get you turned over to our side soon
Jon Kerr is offline   Reply With Quote
Old 01-16-2005, 06:05 PM   #8665
I just said Brians car looked nice. BMI stuff makes every car look good.
Old 01-16-2005, 06:08 PM   #8666
AdrianM's Avatar
Thanks...Protc3...I wish I had put Troy's setup on my car before the main
The setup I was running throughout the day was good on the previous layout but the current layout brought out its flaws...too much body roll and lazy response.
McNichols tried Troy's setup and liked how sharp it it was...he was right...it was way better
If you need any help with your 1/12th car when you get it let me know! I'm glad everyone had fun running that class. I better work on my skills. You were really getting around good with Lynn's car!
Adrian Martinez
Old 01-16-2005, 07:11 PM   #8667
rcshark's Avatar
Adrian can you post that set up ( the second one) please!
Old 01-16-2005, 07:40 PM   #8668
IslandBwoy's Avatar
Hey all,
Just wondering how the races went down at speedline today? Did you guys race at all? We had some good races at space coast surprisingly enough. My Schu was up to par however due to the fact that no traction compound was laid on the track every race was a bit different from the first. Ben Griffin TQ'd in the 19T class wtih 20 laps. We had 5 cars in that class. First and second place were a 10th of a second apart and 3 & 4 was only a hundreth of a second apart. I placed 4th due to my unability to figure out the track but it was a great race all the same. To sum it all up, I think Dave Franklin took 19T and Ben almost took stock but James Solomon stole it when ben broke half way through the mains. I didnt keep up with the nitro classes but there was even a monster truck and mini T exehibition.
I'm going to capture some of the video onto my computer from the races tonight and hopefully post 'em tomorrow.
See you guys later.
R.
IslandBwoy is offline   Reply With Quote
Old 01-16-2005, 08:28 PM   #8669
Default The weakest link?
For the most part I am happy with the Mi2 but I am having a problem with a persistant broken part.
Part U2759 Steering Bell Crank
I have gone through 4 of the left side crank (looking at the car from the rear; the one with the servo saver spring). My last spare broke today when I was hit by another car going through a turn. In the last three weeks two broke from me hitting corners and two others broke from being hit by other cars.
Is there a way to bullet proof this part? Is there something I should be doing with the servo saver spring tension?
Is there another car's bell crank that will work in the Mi2 in case I am at a race and find myself without spares as happened today?
I have gone through more steering bell cranks than I ever could imagine. I can accept the castor blocks as I have been racing enough to know they will break, but this is the first car which I have had so many steering bell cranks break.
at $11 a pop this is becoming a very expensive break!
Besides not hitting anything and asking everyone around me to please not to hit me, what can I do about the steering bell crank?
FYI -- The P-Dub Bumper has kept me from breaking arms on a regular basis!!
LeadFoot is offline   Reply With Quote
Old 01-17-2005, 06:18 AM   #8670
Hey guy's, MI-2's finished first and second A-main at our carpet track in N.C. My 11 year old son finished second, and the winner was a 14 year old that does all his own building and wrenching! Of course we all help him out some, but he and my son did outstanding. Very impressed with this car so far, just need to get one for myself on the way soon!
Thank's Mo, for the set-up info. Might try your latest set-up and see how that does. Later!
HENRYJ is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
