Old 01-14-2005, 10:07 PM   #8641
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Damn Adrian, what is it 1 AM out there?
Jon Kerr is offline   Reply With Quote
Old 01-14-2005, 10:11 PM   #8642
IslandBwoy's Avatar
This is just my opinion. As long as the drivetrain isn't binding and is nice and smooth, I don't think making it spin like some of those shaft drive's you see that guys get to spin forever will really do much good. As long as there's nothing dragging and binding, I'd say you're fine.
You may have saved me some work there. I didnt fancy removing my shields because it could cause the amounto time i need to do maintaining the car to go up but i've seen some drive trains like the hpi and i beleive what was troy's car and an grew green with envy. If this is the consensus not to over do it then i'm fine. What do the rest of you think?
And is anyone going to SpaceCoast?????? :-(
IslandBwoy is offline   Reply With Quote
Old 01-14-2005, 10:11 PM   #8643
speedxl's Avatar
R/C Tech Charter Subscriber
yeah its 1am He probably got a turn on the computer!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 01-14-2005, 11:37 PM   #8644
AdrianM's Avatar
Now, its 2:30...lol! I just finished building an R/C airplane for a friend of mine from my R/C plane club. Promised I would have it for him on Sat
Adrian Martinez
Old 01-15-2005, 07:24 AM   #8645
IslandBwoy's Avatar
Default Setup Question (AdrianM)
I noticed on Adrian's setup sheets he has an entry that says "Trinity Purple bent to 180 degrees". What does this mean? Are you wrapping the sring around the pole one more time or ????
Another thing: I know you guys said that you stoped removing the spacer place to put in shims for anti dive and kickup. but then you said you might add anti dive in your next setu adrian. How are you planning on doing that?
AND: alloy rear hub 0 degrees block. Ball stud in inner holes. What part number are you refering to as the alloy rear hub and how does moving that ball stud around affect the car? I was told before that moving the stud to the OUTER holes make the care a little more predictable. Is this correct? What is the reason for movign 'em in?
R.
Old 01-15-2005, 10:11 AM   #8646
hogdaddy77's Avatar
Default pinions
which is better in stock????..48 or 64 pitch
hogdaddy77 is offline   Reply With Quote
Old 01-15-2005, 12:05 PM   #8647
rcshark's Avatar
Send a message via Yahoo to rcshark
is there a sight where i can send in my set up and get opinion?
rcshark is offline   Reply With Quote
Old 01-15-2005, 12:35 PM   #8648
Default miya shocks mounting
I was looking at others car to see how i have to mount the tamiya shocks on the Mi2.
I saw teemu was using an purple mount on the shock towers but Paul Wynn was using an other way to mount them.
Wich way is the best and can u give me some part numbers of what i have to get so i can mount them properly.
i hope someone can help me with this.
Arjen
Arjen is offline   Reply With Quote
Old 01-15-2005, 03:33 PM   #8649
AdrianM's Avatar
The best way to do it is to ream out the top of the Tam shocks to fit the stock top Schu ball, Ti Schu Shock mount or TiR Alloy Shock mount.
Adrian Martinez
Old 01-16-2005, 08:17 AM   #8650
Send a message via ICQ to MattW
Everyone's got their own method. I know some that have used Adrian's method, some that have used the Associated top plastic ball (perfect fit) and some that have used the Tamiya parts.
Personally i have used Tamiya hardware with what they call a "ball nut" i think for the top mounting, then spacers between this and the shock mount.
I think you should be able to see it on this pic.
MattW is offline   Reply With Quote
Old 01-16-2005, 09:50 AM   #8651
PW
PW's Avatar
Send a message via AIM to PW
Good looking car Matt, but it looks like you could use a P-Dub bumper.....LOL
I also use the tamiya hardware to mount the shocks
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 01-16-2005, 09:59 AM   #8652
rcshark's Avatar
with the stock chassis, I have a problem when I load the car in the turns. It rubs the chassis under the batteries on the edge. Its a realy sharp turn and the traction is up. I had this problem and thought that it was that the camber links to low but when I moved them up and used stronger shocks. It still happened. I try to load the out side of my car in the turns, so that I can spring out of the turn! I know this is hard on the drive train but its realy a great way to move inside of the other driver, that is just driving around the track like its sunday and Its alot of fun to drive hard into the turns like that!
other then changing my driving what can I do to not rub the chassis? I fill that the car has to hard of springs and the car is twitshy! but with aggresive driving its okay! just down the straight its little hard unless there is know one around me. could toe out for this.
roll bars yellow stock
front castor 4 degree
toe 0
ride hight 6.0
camber 1.0
front wishbone forward
front shocks 2 hole
camber on hub bottom
camber on towor top inside
oil 40
spring gold front red rear
3 hole
a arm inside front #3 outside rear
short steering rode
anti/pro sguat 0
rear toe 1.5
ride height 6.5
rear camber 1.0
rear wish med.
all shocks 62.0
rear shock towor 3 hole
camber med top and low hub
hubs are raised
plastic drives
batts are med med
Old 01-16-2005, 10:12 AM   #8653
HarshGuy's Avatar
I saw that P-Dub bumper last weekend, it ROCKS ....you gonna make one for the jrxs? or xxx-s?
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 01-16-2005, 10:45 AM   #8654
Default tamiya shocks
Pw do you know the part numbers of the tamiya mounting?
So i can order those i don't know exactly wich i have to take.
thanks
Arjen
Old 01-16-2005, 11:31 AM   #8655
PW
PW's Avatar
Harshguy....Yes, the JRXS bumper will be done in a couple of weeks.
Arjen....I used the hardware that came with the shocks.
Rcshark....A shorter link will reduce roll and up-stops on the shock shafts might help. On foams we normally have the stops hit at the same time the chassis hits the surface.
Paul Wynn
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
