Old 01-13-2005, 04:39 PM   #8626
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
No, adding anti squat will help the car square up coming out of the corner on power.
Jon Kerr is offline   Reply With Quote
Old 01-13-2005, 05:00 PM   #8627
cornerspeed's Avatar
Originally posted by AdrianM
None, I want to reduce camber change.
The car is really good at my locak track. Really good turn in and rear rotation. It is a bit loose on power exiting but this weekend I might lean in the rear shocks or add some anti squat.
Thanks AdrianM-Just curious. Heard your car is pretty good with that set-up. I tried it last weekend at SoCal. Car was a little undrivable. I want to try that set-up outdoor. Kind of leary though since I'm doing so well with Paul's set-up. I will set it up maybe on my spare car.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 01-13-2005, 05:01 PM   #8628
Hey Jon, you maybe have a spare rear diff pulley, stock one? I need it for my other car.
Donny Vinkemulder
TLR Driver
Old 01-13-2005, 05:05 PM   #8629
Jon Kerr's Avatar
I might, call me later tonight and I'll look through my part box. I'll be home around 6:30.
Old 01-14-2005, 04:31 AM   #8630
rcshark's Avatar
Send a message via Yahoo to rcshark
do i tighten down the sway bars so they dont move or do i leave them little loose?
rcshark is offline   Reply With Quote
Old 01-14-2005, 04:56 AM   #8631
CAR
CAR's Avatar
Use a small piece of shrink tube to fit between the mounts.shrink it on the swaybar this works great to take away side to side play without adding weight.
CAR is offline   Reply With Quote
Old 01-14-2005, 06:53 AM   #8632
Default spur +pinion
Now Im not asking for an exact number, just want to know where to start with a 10X1 in my Mi2 ?
cheers
Scottymi2b is offline   Reply With Quote
Old 01-14-2005, 07:41 AM   #8633
AdrianM's Avatar
On a somewhat tight 120'x70' track I run ~8.28:1 final drive with a 10T Mod. This is with 63mm Take Off CS27GL's.
Adrian Martinez
Old 01-14-2005, 07:51 AM   #8634
STLNLST's Avatar
Default Re: spur +pinion
cheers
It all depends on if you're using 64p or 48p
64p- 124/27
48p- 95/21
These are gearings that work for me at a couple of tracks in my area. Is your track open, tight?
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-14-2005, 03:56 PM   #8635
Default Track
Fairly tight at the moment. Using the 48p spur.
Old 01-14-2005, 07:20 PM   #8636
protc3's Avatar
hey adrian,whats gonna be the class of choice this weekend so i know which motors to bring.see ya sunday bro.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 01-14-2005, 07:27 PM   #8637
AZ_Ron's Avatar
Trader Rating: 16 (100%+)
Speaking of gearing... I'm running 48p in a Mission1... mid size carpet track, running stock motors, foam tires.... any idea on where to start on gearing?
Thanks!
R
AZ_Ron is offline   Reply With Quote
Old 01-14-2005, 10:44 PM   #8638
IslandBwoy's Avatar
Default Freeing the drive train
Now i'm torn as to where to be this weekend. Most of the guys here (orlando) sound like they are going space coast. And from what i'm reading you guys are going speedline :-(. Either way,
I'm trying to free up my drive train a litle more since i have to back in my spool for this sunday and was wondering what tricks can you guys recommened for freeing it up. Right now as you guys now the dt is pretty free out of the box but i'm looking for that extra edge.
So what do you say? trim teeth on the rear belt? Remove shield from all my bearings? what is the prefered method here?
R.
IslandBwoy is offline   Reply With Quote
Old 01-14-2005, 11:03 PM   #8639
AdrianM's Avatar
protc3 - It will be mod for Troy, Croy and I. PW might come too. Sean and your boy Joe B. will probably run stock
Adrian Martinez
Old 01-14-2005, 11:04 PM   #8640
Jon Kerr's Avatar
This is just my opinion. As long as the drivetrain isn't binding and is nice and smooth, I don't think making it spin like some of those shaft drive's you see that guys get to spin forever will really do much good. As long as there's nothing dragging and binding, I'd say you're fine.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
