Old 01-12-2005, 06:06 PM   #8611
IslandBwoy's Avatar
who are you? where do u race?
I'm the one that asked you about your setup on Sunday. Asked if you were setting it up to be a little looser in the back on purpose because you liked it, or if you were having trouble with the car. Ran the white body, MI2 of course.
R
IslandBwoy is offline   Reply With Quote
Old 01-12-2005, 06:12 PM   #8612
CAR
CAR's Avatar
What's the best ackermen postion and linkrod length running a spool with rubber tires on a tight carpet track ? Has anyone tested this running with a spool? Thanks
CAR is offline   Reply With Quote
Old 01-12-2005, 09:37 PM   #8613
King-G's Avatar
Send a message via ICQ to King-G
I find the outer hole to give the most initial steering for tight tracks..but I run the middle position, gives good mid corner feel. most drivers are currently using the middle poisitions on the bellcranks, I am currently running a centre link length of 38mm from end to end, and am using a spool.
my car has tons of initial steering, very aggressive.
to get the most out of the spool, try running lighter front oil (5-10 wt lighter than rear), softish front springs, and fairly low droop...1-2mm
having said all that, im not sure many are running spools on carpet...most opt for a differential.
King-G is offline   Reply With Quote
Old 01-12-2005, 10:31 PM   #8614
STLNLST's Avatar
Trader Rating: 17 (100%+)
take a look on www.gearchart.com for what Mo and I have run on carpet. I ran a spool on carpet and the car was dialed. I'm sure that I posted the set up I ran the last time out on the rug.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-13-2005, 09:28 AM   #8615
IslandBwoy's Avatar
There was a new 19T motor that i got a glimpse of over the weekend but i'm not sure who made it. The can was green but thats all that i saw. Anyone aware of a new 19T green motor hitting the streets latley? Any thoughts on that motor in comparison to the reedy quad? Supposedly everyone has been talking bout it however i didnt get the chance to ask around.
Old 01-13-2005, 10:07 AM   #8616
AdrianM's Avatar
Its probably the Peak Dynasty.
Is this it?
If it is the motor is very fast. From what I hear you have to gear it to the moon like the Reedy.
Adrian Martinez
Old 01-13-2005, 10:24 AM   #8617
speedxl's Avatar
R/C Tech Charter Subscriber
This motor has been out for awhile. I am the one who's motor you were looking at!
The white bodied Mi2.
Its made by peakperformance, orion has one called the element!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 01-13-2005, 11:26 AM   #8618
Super Moderator
Tony Rivas's Avatar
Trader Rating: 53 (100%+)
hector-whats up's ok i will be at tqs too if it dont rain
Islandbwoy i no who u are know.
The "Dominican Assassin"
Sorry for the Spelling but you know what I mean.
Tony Rivas is offline   Reply With Quote
Old 01-13-2005, 12:15 PM   #8619
speedxl's Avatar
see ya tony!
Old 01-13-2005, 02:27 PM   #8620
IslandBwoy's Avatar
Ah haaa! I'm going to have to research this motor now. I'm always looking for more horses especially now that my car is drivable. I have a few things i can do with my car to drop seconds but a more powerful motor is always appreciated.
If any of you guys see any test results for this motor please let me know.
R
PS. Any of you guys planning on going out to the coast or speedline this weekend?
Old 01-13-2005, 02:54 PM   #8621
AdrianM's Avatar
Troy and I will be at Speedline this weekend.
Adrian Martinez
Old 01-13-2005, 02:59 PM   #8622
Jon Kerr's Avatar
Adrian, Donny and I will be doing some outdoors testing on RP's this weekend. I'll call you and let you know how it goes.
Jon Kerr is offline   Reply With Quote
Old 01-13-2005, 04:03 PM   #8623
cornerspeed's Avatar
Adrian-How much shim are using under ball stud for rear camber link on hub?
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 01-13-2005, 04:09 PM   #8624
AdrianM's Avatar
None, I want to reduce camber change.
The car is really good at my locak track. Really good turn in and rear rotation. It is a bit loose on power exiting but this weekend I might lean in the rear shocks or add some anti squat.
Adrian Martinez
Old 01-13-2005, 04:32 PM   #8625
add some anti-squat?? wouldnt you reduce anti squat to keep the rear more planted coming out of the corner on power?
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
