Old 01-10-2005, 01:05 PM   #8596
mo
mo's Avatar
Thanks Fran. e-mail me or leave you e-mail address and I'll send it to you. [email protected]
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 01-10-2005, 04:13 PM   #8597
Mo did a great job this weekend, as did Dujan to put Mi2's first and second in a highly competitive Mod class at the Northwestern Carpet Champs this weekend. Both these guys deserve a hand!
Jay Dub is offline   Reply With Quote
Old 01-10-2005, 05:03 PM   #8598
Default 30mm foams
I was always told 30mm foams wont fit the rear of my Mi2 .
Well they fit, is there any reason i need to cut them down ?
Scottymi2b is offline   Reply With Quote
Old 01-10-2005, 08:18 PM   #8599
rcshark's Avatar
Send a message via Yahoo to rcshark
Good job guys but look what you was driving what do you exspect!!!!!
realy good job guys like to see schumacher up front keep it up!
they are going to let the 19 turn go at it in feb. here in houston for best 5 out of 6 weeks!
rcshark is offline   Reply With Quote
Old 01-11-2005, 05:07 PM   #8600
AZ_Ron's Avatar
Trader Rating: 16 (100%+)
Hey guys... we're getting closer... I got the shocks on the car today, and am setting the car up using Paul's Novak Race setup sheet... Weird thing though... I only have 4 holes for the upper shock position instead of the 5 shown on the sheet... I'm just assuming my tower is an older version.
Other issue I seem to have are the droop screws are not hitting the chassis when the shocks are on... I've unscrewed the ball cups about 4 threads, but the droop screws are still 3mm or so above the chassis... do I need to go with longer ball cups, or ????
Thanks!
I'm hoping to race either tomorrow night, or maybe saturday depending on how busy work is...
Ron
AZ_Ron is offline   Reply With Quote
Old 01-11-2005, 06:26 PM   #8601
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
If you don't have any limiters inside your shocks, yes, you need to put some longer ball cups on the shocks. That should fix the problem.
Jon Kerr is offline   Reply With Quote
Old 01-11-2005, 06:48 PM   #8602
Send a message via AIM to willdp
on the set up sheets that i have seen it says you are runing 2mm and 3mm is that with a droop gauge or are you measuring the suspension down travel after you set ride hight? thanks will
willdp is offline   Reply With Quote
Old 01-11-2005, 07:12 PM   #8603
IslandBwoy's Avatar
On the setup sheets where you see low values 2,3 they are most l ikely measuring the drope above ride hight. So after ride hight has been set. That is how PW and adrian's setup sheets look nowadays.
IslandBwoy is offline   Reply With Quote
Old 01-11-2005, 07:17 PM   #8604
IslandBwoy's Avatar
I only wish we had more guys running the shu's in orlando. I'm trying to hold down the fort as much as i can olong with tony. But thats it as far as regulars each week.
Old 01-11-2005, 07:22 PM   #8605
IslandBwoy's Avatar
I'm not sure why your droop screws are not touching. I use to use the long ball cups when i had the stock shock towers but now i'm using the short ones with the carpet towers. However if you are setting up for carpet i'm assuming you are using the inner on the shock towers which would make that distance a little longer than normal. So yeah use the long cups if nothing else works. or maybe one of the team guys will reply with some kind of reasoning for your issue.
BTW: Art J. got me going with the tamiya and we had to take aprx 1mm off the long ball cups when were using them because of how tall they were. Something to keep in mind.
Old 01-11-2005, 07:25 PM   #8606
IslandBwoy's Avatar
Is this also recommened when you are using the carpet towers? And where do you get the limiters from if your using the tami's?
Old 01-11-2005, 07:52 PM   #8607
Jon Kerr's Avatar
I think Ron is running a Mission, not the Mi2. I never had a chance to run that car but as far as I know they didn't have lower towers for that car. That's why he may need the longer ball cups.
As far as limiting the Tamiya shocks, it's not needed if you're running the carpet towers. However if you're running the stock towers with the Tamiya shocks, I think you'll need to use some longer ball cups to make length.
Old 01-11-2005, 08:04 PM   #8608
Super Moderator
Tony Rivas's Avatar
Trader Rating: 53 (100%+)
who are you? where do u race?
The "Dominican Assassin"
Sorry for the Spelling but you know what I mean.
Tony Rivas is offline   Reply With Quote
Old 01-11-2005, 08:08 PM   #8609
thanks jay-dub Mo and I worked hard to get the MI2 working. It felt pretty good getting back on the podium again! Its been to long!!!
LSR SPEEDWAY
R1 WURKS
Schelle Racing
MIP Racing
BN Racing
bigdog is offline   Reply With Quote
Old 01-11-2005, 08:20 PM   #8610
speedxl's Avatar
R/C Tech Charter Subscriber
tony rivas this is hector i will be at popi's friday (TQ hobbies)
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
