Old 01-06-2005, 12:00 PM   #8581
IslandBwoy's Avatar
Default SETUP FOR SUPERIOR HOBBIES
Hey Guys,
Couple weeks ago PW or Adrian (I think) posted their setup sheets from the super regionals @ superior hobbies. Do any of you have that setup sheet still? Where do they normally store their setup sheets?
Different question: WHen running on a longer track versus a shorter track with the MI2. What changes do you guys usually make to compensate for either? BTWN each run what parts should i inspect for damage or shifting?
R.
IslandBwoy is offline   Reply With Quote
Old 01-06-2005, 12:06 PM   #8582
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Here you go
Jon Kerr is offline   Reply With Quote
Old 01-06-2005, 11:23 PM   #8583
STLNLST's Avatar
Default Re: SETUP FOR SUPERIOR HOBBIES
Originally posted by IslandBwoy
Hey Guys,
R.
The only thing you should have to change is gearing. I have run the same set up at four different tracks and one of them being carpet.
My gearing also pretty much stayed the same but sometimes I 'd adjust for a longer straight.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-07-2005, 06:36 AM   #8584
IslandBwoy's Avatar
THanks STLNLST, John.
Old 01-07-2005, 06:56 AM   #8585
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
I hear PW's car looks ballistic in 19t, my spy did not see his mod runs.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 01-07-2005, 02:17 PM   #8586
AZ_Ron's Avatar
Trader Rating: 16 (100%+)
Hey guys... I'm converting my front spool back to a diff thank to Jon Kerr... THANKS JON!!
Question i have is... What's the proper setting on the diff screw...
It's been a LONG time (Axis2) since I've done one of these...
I was thinking something along the lines of tightening all the way, then backing off 1/2 turn??
Thanks for the help guys... these forums rock!!
R
AZ_Ron is offline   Reply With Quote
Old 01-07-2005, 05:52 PM   #8587
AZ_Ron's Avatar
Well, I went off the exploded view, got it all together, and after tightening all the way down, backed it off 1/2 turn... feels really good, so unless I hear differently, I'll try it like that...
R
Old 01-09-2005, 12:43 AM   #8588
IslandBwoy's Avatar
Default Locked Diff
Hey guys,
I was taking a look at one of Adrian's setup and i noticed that he had a "locked diff". Now, this may sound stupid, but what exactly is a locked diff. I would imagine that when you tighten the diff until it does not work at all but then wouldnt that be the same as a one way or spool rather? And why would you want to do that versus actually using a spool? Likewise how much does that affect the setup if i used a regular diff versus a locked diff?
You help is appreciated.
R.
Old 01-09-2005, 06:18 AM   #8589
mo
mo's Avatar
"Locked diff", on the setup sheets, just means a spool.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 01-09-2005, 11:14 AM   #8590
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
looks like that BMI-2 is off to a great start.. PW took 2nd in the 19t B
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 01-09-2005, 11:51 AM   #8591
CAR
CAR's Avatar
Will Associated shock springs fit on Tamiya shocks? Thanks
CAR is offline   Reply With Quote
Old 01-09-2005, 11:55 AM   #8592
Send a message via ICQ to MattW
Yes they will.
MattW is offline   Reply With Quote
Old 01-10-2005, 12:07 AM   #8593
Speedie's Avatar
Yes and so will the new Schumacher springs.
I want to thank P-Dub for all of his help this weekend. He never hesitated once to drop everything and answer all of my questions. Class act people like Paul are what makes racing fun. I am very happy I switched this year to Schumacher cars. Thanks alot.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 01-10-2005, 12:24 PM   #8594
mo
mo's Avatar
I just uploaded my new setups for foam and rubber to my site (www.mo-net.ws) and to www.gearchart.com . I ran the Northwest Carpet Champs this weekend and TQ'd and won 19 turn rubber and won mod foam.
Old 01-10-2005, 02:02 PM   #8595
Fran's Avatar
Trader Rating: 130 (100%+)
Hey Mo,
Gongrats on your laying it down this weekend
I wanted to check out your setups, and I'm having trouble downloading the rubber set up either from your website or gearchart.com Mabey it's something on my end (although I was able to print out the mod w/ foam one) Thanks and keep up the good work on the Mi2!!!!
Fran
Fran is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
