Old 01-05-2005, 02:43 PM   #8566
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
i think you can specify a post author in your search...
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 01-05-2005, 04:53 PM   #8567
Mo, TimPotter:
Thank you both for the replies. Are they only available for the team drivers? Using the search on the Schumacher site none of the U2822 thru U2828 part numbers for the new springs show up.
I think the CVDs are cool but I will stick to the plastic CVDs because I will never be able to afford the $80 for those trick pieces. It has not been a problem with Stock and 19T. When I use a spool outside in the spring I may have skip a few meals to save up for something on the front.
Mo:
On your setups, are you using the Teemu Chassis for Carpet w/Foams? The reason I ask is because I seem to do great without the thicker chassis except when the traction starts to come up and then I actually start to traction roll. I am not sure if that is from the chassis flex or just my poor setup.
LeadFoot is offline   Reply With Quote
Old 01-05-2005, 07:14 PM   #8568
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Leadfoot, call Schuie USA, the website is a little behind sometimes.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 01-05-2005, 07:37 PM   #8569
mo
mo's Avatar
Leadfoot, I believe the springs just came in last week or so and the website hasn't been updated yet.
I have run both the Teemu and 2.5mm version of the stock chassis and both work great. My setup has also been run by another driver at the same track with the stock 2mm chassis with no problems. What setup are you running? You may be too stiff on the springs or need to lay down the front shocks. Also, we have found that reducing caster can reduce traction rolling also. Make sure you run a bead of glue around the outside edge of your front tires too.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 01-05-2005, 07:43 PM   #8570
hogdaddy77's Avatar
Mo
Quick Q....
for speedworld....should I run low cg shock towers, or stocks....and stock chassis, or the Teemu Chassis
thanks..and one day when it warms up, Ill have to get with you or another schui guy at speedworld and get the run down on how to set up the car properly....I think that would really help me understand some of the basics in getting a car dialed in...never did that with my TC3..and I believe that is one of the main reasons I was un-satisfied with it////but the Mi2 is just to sweet a ride to not learn the basics for
hogdaddy77 is offline   Reply With Quote
Old 01-05-2005, 07:44 PM   #8571
Super Moderator
Tony Rivas's Avatar
Trader Rating: 53 (100%+)
Default set-ups
mo-If u can send your set when u guys get a chance thanks. Good luck to all schumacher drivers
The "Dominican Assassin"
Sorry for the Spelling but you know what I mean.
Tony Rivas is offline   Reply With Quote
Old 01-05-2005, 08:09 PM   #8572
mo
mo's Avatar
Tony, my current setup is posted on www.gearchart.com . Look for the one updated on 12/28/04 or here is a direct link http://www.gearchart.com/setup/setup...20Foam%202.pdf
If it doesn't work for you, leave your e-mail or e-mail me (jmo@mo-net.ws) and I'll send it too you.
Hogdaddy, I would stick with the stock chassis for asphalt and it even works just fine on carpet. The low towers are a better but you'll also have to alter the stock shocks or get tamiya ones. If there is something you are wanting the car to do better, post your setup and tell me what you are looking for and I'll give you some suggestions.
We will definately get together once the weather warms up and I'll help you get super dialed. We will be at Stockton both Saturday and Sunday this weekend if you can make it down. It is 1 big race but it's run as two seperate races and then totaled so you don't have to be there both days. If you can make it down, even if you don't race, bring you car and we can look it over.
Old 01-05-2005, 08:27 PM   #8573
hogdaddy77's Avatar
cant do it this weekend..going to take my little girl up into the snow...plus I have a few busted parts on the front..waiting for Billy to get them in..hopefully in the next day or so
Old 01-05-2005, 09:34 PM   #8574
AdrianM's Avatar
Default Race Report...
PW is at the S&N Trackside Novak Race this week.
The fist day of practice went very well. PW says he is surprised by how good his car is right off the bat. He can turn consistant lap times that would put him in the top 4 at the event. PW says Lemieux is fastest followed by Francis then PW and Ralph Burch.
After the race PW will post his setup. It's a little diffrent than what most Mi2 Foam racers have been running.
Adrian Martinez
Old 01-05-2005, 11:35 PM   #8575
hogdaddy77's Avatar
wow..the wife says I may be able to play on Sunday...
what time does the race start at Stockton???.....if I can get the c- hub for my schui in time I will definatley give my best to try to make it down there to race!
Old 01-06-2005, 12:02 AM   #8576
mo
mo's Avatar
If all you need is a caster block, I will hook you up if Billy doesn't get them in, in time. The track opens at 7am and racing starts at 10am.
Old 01-06-2005, 09:42 AM   #8577
IslandBwoy's Avatar
Do any of you guys have a scan of the sticker sheet for the MI2? I dont think superior have an seperately but i'm thinking that since most of it is black and white i would be able to print it out on sticker paper (which i have) if i had an image.
R.
IslandBwoy is offline   Reply With Quote
Old 01-06-2005, 10:55 AM   #8578
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
So I take it PW is liking the BMI2 chassis.
Jon Kerr is offline   Reply With Quote
Old 01-06-2005, 10:58 AM   #8579
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
He told Brian it was super dialed.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 01-06-2005, 11:39 AM   #8580
yeah, he said it feels really good after only 3 runs the first day.... so lets hope it stays that way for the rest of the week!
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
