Old 12-28-2004, 05:49 PM   #8491
PW
PW's Avatar
Send a message via AIM to PW
Hey Gary...Yes and as for setups, I haven't run foam since carpet nats and I had major electronic issue there
The only setup info for foams is from our support drivers that race on medium to low-bite tracks.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 12-28-2004, 05:57 PM   #8492
RCGaryK's Avatar
Understood, but I still have some product orientated questions for you. I guess for setup I'll have to turn to Ottoman. Ohhhhhh Jiiiiiiiiiiiiiiiiiiimmmmmmmmmmmmmmmmm
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 12-28-2004, 06:24 PM   #8493
mo
mo's Avatar
I just updated my carpet setup on www.gearchart.com . It is on a medium/high bite carpet track. Just look for the one updated today.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 12-28-2004, 06:32 PM   #8494
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
does anyone have experience with the acer ceramic bearings for the Mi2? what are your thoughts and feelings...
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 12-28-2004, 07:14 PM   #8495
RCGaryK's Avatar
Mo, the black bar you listed up front, is that an HPI or Schi bar? Looks like no shims under the rear mounts and that you're using the kit inner suspension mounts and not the aluminum ones? What shocks were you using with which brand #4 pistions? A lot questions I know, and I'll have more, trust me Like what do you do to this setup when bite comes up?
HorizonHobby.Com
Old 12-28-2004, 09:04 PM   #8496
speedxl's Avatar
R/C Tech Charter Subscriber
R/c driver gary you call PW!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 12-28-2004, 09:08 PM   #8497
RCGaryK's Avatar
What should I call him?
I'll be there all week
HorizonHobby.Com
Old 12-28-2004, 09:21 PM   #8498
mo
mo's Avatar
It is the Schui black sway bar and no shims under the stock suspension mounts all around. The shocks are the stock schumacher shocks with 4 holes open, but stlnlst has also run this setup with Tamiya shocks with #3 pistons and the same oil. I have not really had to make any changes as the bite comes up. I'm still looking for a little more steering out of the setup which may be good on a really high bite track. Next time out I am probably going to try raising the reall suspension mounts a little or adding anti-squat. If the bite comes up really hard and the car starts to get really twitchy or wants to traction roll, the first thing I would probably do is change to 2 degree caster blocks.
Old 12-28-2004, 09:57 PM   #8499
speedxl's Avatar
gary PW has got everyone coverd best company rep ever.
But sit near him so you can save cell minutes!
Old 12-28-2004, 10:41 PM   #8500
STLNLST's Avatar
Trader Rating: 19 (100%+)
Mo's set up works killer. I'm also looking for a bit more steering but due to my driving stlye I'm looking for something a bit different than Mo. I think that Mo is looking for a bit more mid to exit steering while I'm looking for a bit more steering off power. If I can get the car to rotate a bit more in the corners without having it really dig in entering a corner I'll be happy. Try the set up out.....you'll be happy.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 12-28-2004, 11:11 PM   #8501
RCGaryK's Avatar
Have you guys tried adding a rear bar to free up the back end more or is it more of a front end not having enough bite problem than a rear having too much bite? I'm feeling lazy, is the black bar thicker or thinner than the stock one?
PW's up there. He and Hodge are two of the best class acts in any pits any where.
HorizonHobby.Com
Old 12-28-2004, 11:23 PM   #8502
speedxl's Avatar
stlnslt try drilling an extra hole above the front middle camber hole raising it will give you more camber gain .
Or add a 1/2 mm shim under the rear front arm pivot for anti dive it will make the car turn in quicker (opposite of kickup).
Old 12-29-2004, 02:50 AM   #8503
Send a message via ICQ to MattW
Gary, the black bar is thinner than stock - think it's 1.5mm from memory. I have some in a bag, but haven't taken them out yet!!
MattW is offline   Reply With Quote
Old 12-29-2004, 06:22 AM   #8504
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Yes, the black bar is 1.5mm and I tink the stock is 1.7mm.
Jon Kerr is offline   Reply With Quote
Old 12-29-2004, 06:43 AM   #8505
STLNLST's Avatar
I was thinking of adding anti squat to the rear but it's 2nd to try on my list. There's one camber change in the rear I'd like to try before I try that. So on the front camber positions you have that hole drilled creating a 3rd row of holes?
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
