Old 12-15-2004, 02:10 PM   #8371
PW
PW's Avatar
Send a message via AIM to PW
I've been told the end of next week
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 12-15-2004, 02:26 PM   #8372
AZ_Ron's Avatar
Trader Rating: 16 (100%+)
Hey guys...anyone have a spare set of springs they'd like to sell? I've got the four yellow kit springs...I'd like at the least a full set of greysm but a full set would be nice!
Thanks!
Ron
AZ_Ron is offline   Reply With Quote
Old 12-15-2004, 02:28 PM   #8373
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Ron, I can send ya a full set if you want.
just email me
[email protected]
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 12-15-2004, 02:54 PM   #8374
Default Stock Spur
Can any of you learned gentlemen point me in the right direction for a spur to suit a stock motor running a fairly open track with a couple of long straits.
I have the kit 95t in right now, it's ok but not as quick as some.
Scottymi2b is offline   Reply With Quote
Old 12-15-2004, 03:07 PM   #8375
Default F/R Diff Setting?
Can anyone tell me how to check to see if my front and rear diffs are correctly tightened? And, how should the front diff be tightend in relation to the rear (e.g. looser, tighter, the same)?
LeadFoot is offline   Reply With Quote
Old 12-15-2004, 05:24 PM   #8376
Super Moderator
Tony Rivas's Avatar
Trader Rating: 53 (100%+)
Default diff
leadfoot-I used a front spool. My rear diff it pretty lose. I would have the front diff pretty tight if i ran a diff and the rear diff lose.Its pretty hard to describe how to adjust the diff without trying out myself,hope this helps.
The "Dominican Assassin"
Sorry for the Spelling but you know what I mean.
Tony Rivas is offline   Reply With Quote
Old 12-15-2004, 06:50 PM   #8377
AdrianM's Avatar
Scottymi2b - I used to run a lot of stock. I generally ran the biggest gear I could fit in the car. A 95 48p or a 128 64p. I am an old pan car racer and I was always told to run the biggest gear that fits as its more efficient than the same ratio with a smaller gear.
Adrian Martinez
Old 12-16-2004, 01:15 PM   #8378
Default Diff Redux
tony rivas:
Thanks for the reply.
I guess I will play and see what happens. I am an old off-road buggy racer and the way that you checked in a buggy was to hold the spur and the motor side wheel and see how easily you could turn the other wheel forward. the proper adjust was when you could just barely slip the diff without chewing up the hand the held the spur.
I was just wondering if there was a similar trick for touring car.
Old 12-16-2004, 01:48 PM   #8379
PW
PW's Avatar
Default Re: Diff Redux
Originally posted by LeadFoot
tony rivas:
I set the rear the same way as you described and slightly tighter for the front
Paul Wynn
Old 12-17-2004, 06:57 AM   #8380
PW:
Thank you for the response -- that is what I was looking for.
Old 12-17-2004, 05:30 PM   #8381
ShadowAu's Avatar
Can anyone give me an unbiased (good AND the bad) comparison between the Mission and the Mi2?.... performance, reliabilty, ease of setup etc
I dearly love my Mission but its time to upgrade for a serious crack at modified racing... I've found, with the sort of tracks I primarly run on, that the mission is a touch difficult to setup so that I am confident in pushing hard using a modified...
in Stock it is an absolute weapon
I am quite content with doing what I do
Don't mistake not being happy for unhappiness - its not the same thing
ShadowAu is offline   Reply With Quote
Old 12-17-2004, 07:03 PM   #8382
AdrianM's Avatar
The best description I have heard for the difference is that if you drive your butt off to turn 12.0 sec laps (for example) with a Mission you can turn 12.0 sec laps all day with the Mi2 while having a casual conversation . It is faster and safer. It also seems to be very consistent in setup. We run close to the same setup on 4 different continents. This means the car works well in a variety of places without the need for radical setup changes.
I'm sure some other guys will chime in soon...but they are probably either racing right now or wrenching for Sunday morning...lol!
Adrian Martinez
Old 12-17-2004, 08:06 PM   #8383
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Having not run the original I can't comment on the difference, but I can comment on the Mi2 compared to other cars I've driven. Adrian is dead on. You feel confidant driving this car. And adjusting it. When you make a change to the car it does what it's supposed to do. I have confidence in making adjustments on this car that I never had before. I'm still learning the fine tuning of the car to get that extra .1 or .2 out of it but that'll come with time. Don V. and I have pretty different driving styles, yet our setups usually end up almost identical. Radio preferences tend to be the only thing different about the two.
Jon Kerr is offline   Reply With Quote
Old 12-19-2004, 05:47 PM   #8384
Super Moderator
Tony Rivas's Avatar
Talking mi-2 wins at tq's
What a victory at tq's in longwood with a field of X-rays,I was the only one with an mi-2.I lap the hole field and run some 19 turn laps and bet the tq by one lap.In all the years racing i have never fell so confident with any car. I love this car. thanks pw and Adrian M for your support I am glad to be part of this team.
Old 12-19-2004, 06:25 PM   #8385
AZ_Ron's Avatar
Wow! Kick a$$ Tony... Congrats!!
BTW... anyone know if associated or losi upper shock bushings will work with the Schuie shocks?? I got a car, and i'm just missing the bushings...
Thanks!!
Ron
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
