Old 12-05-2004, 03:17 PM   #8296
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
That's all that was there when I got the car. Remember I'm still running a car I didn't build. Am I missing something?
Jon Kerr is offline   Reply With Quote
Old 12-05-2004, 03:46 PM   #8297
Send a message via ICQ to MattW
That is the kit std front block, and it only has one screw in it. The other block has 2 screws, but the alloy one that replaces it only has 1.
MattW is offline   Reply With Quote
Old 12-05-2004, 06:40 PM   #8298
I just wanted to say thanks to Schumacher USA (Paul, Troy, and Adrian) for the support this weekend. My MI2 was unbelievable this weekend. Thanks for letting some speed rub off on me guys!!
Art Jensen is offline   Reply With Quote
Old 12-05-2004, 07:04 PM   #8299
STLNLST's Avatar
Originally posted by HarshGuy
Great to see you guys back out again, and you even smelled better than last time we raced together (5 days w/o a shower really "showed" ;-) ) ...STLNLST, what's the website for Brahma, I gotta get me some stock ponies, I'm good with 19T but I just can't seem to find a good stock motor
www.brahmaracingproducts.com If you can't get one before the next time you race just let me know and I'll hook you up. You saw Aaron's car yesterday right???
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 12-05-2004, 07:19 PM   #8300
STLNLST's Avatar
Originally posted by Racer X
Got to give props to STL and Mo. Finally dusted off the Mi2 and went racing yesterday and the setup that STL (with help from Mo) hooked the Cop and I up with was awesome! Nothing better than going racing with a dialed setup...of course then all the blame falls on the driver. Thanks as always.
No problem. That car is soooooo dialed. It's very easy to work on and works flawlessly. Hopefully you guys come out next weekend too. I have a set of 28/24 with the insert combo the seems to work better than the take off 27/22 combo you were using.
Old 12-05-2004, 07:31 PM   #8301
RCGaryK's Avatar
Why didn't you build it?
Yeah, there's supposed to be 2 screws in each of the blocks.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 12-05-2004, 07:32 PM   #8302
HarshGuy's Avatar
Which motors should I get? I figure I'll get 2 of each of whatever you suggest.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 12-05-2004, 07:33 PM   #8303
Speedie's Avatar
Gary there is only one screw in each of the outer blocks the inner ones have 2.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 12-05-2004, 07:47 PM   #8304
STLNLST's Avatar
Get the demon blue printed versions.
Old 12-05-2004, 08:00 PM   #8305
AdrianM's Avatar
Default Regarding sway bar mounts...
I have seen a few guys using sway bar mounts off of the XXXS. There are 2 sizes of tabs. A .078/.055 and a .063/.045. Those are pretty much spot on for our new bars.
Adrian Martinez
Old 12-05-2004, 08:47 PM   #8306
Speedie's Avatar
Now you say that Adrian. Now that I spent an hour whittling out my mounts for the bigger bars I made.
Old 12-05-2004, 09:47 PM   #8307
STLNLST's Avatar
We also played around with the 17tooth pulley and I think that it give a slight bottom end advantage. Other than that it felt the same. Mo ran a 108 spur and I went with a 105. Using these spurs allowed us to use the same pinions we were using with the 122 and 124 spurs and the 20 tooth pulley.
Old 12-05-2004, 09:50 PM   #8308
Harsh get the Demon and the Vision motors both have really good rpms. The springs come alittle soft so go with heavier springs and the bottom end will be alot better. Any time Aaron wants a win in stock or the t
LSR SPEEDWAY
R1 WURKS
Schelle Racing
MIP Racing
BN Racing
bigdog is offline   Reply With Quote
Old 12-05-2004, 09:51 PM   #8309
win he just comes over and says I need power and I hand him the Brahma power. Sorry I hit enter to soon
LSR SPEEDWAY
R1 WURKS
Schelle Racing
MIP Racing
BN Racing
Old 12-06-2004, 04:01 AM   #8310
rcshark's Avatar
Send a message via Yahoo to rcshark
Adrain.
Your the best i put eveyone to shame i put to laps on the rest of the field! with your help the other day in 19 t set the track record by almost 2 seconds but i used a oneway and didnt use the breaks at all and it just pulled me around the track i never looked back! except in the main there was this on joker that was onfire he was almost as fast but i just out drove him!!!
thanks alot for your help!
like always!
rcshark is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
