Old 12-01-2004, 07:02 AM   #8266
PW
PW's Avatar
Send a message via AIM to PW
Default Re: Loose off power
Originally posted by IslandBwoy
I know that a lot of you guys have since moved on but i'm still have a small problem with my original mission. I took the car out to TQ last Friday and it took me the full 3 days of the races to get the car driveable. My issue is that the car is loose off power (coming out of the corner as i hit the throttle). I've tried just about everything to get the rear planted and even have a wopping 4 degrees of camber on the rear end. Now the car is driveable but i want the rear to stay flat out of the corners like my MI2 ;-). One thing i was thinking about is raising the roll center in the front with a couple of 1 mil shims but that would mean that the stearing block that the lower hing pin plugs into would be raised, which would then mean that the servo arm by the spring would be raised which means that my top deck would be out of lined because of the already tightened spring. How can i go about raising the roll center without screwing everything up?
I'll post my setup tomorrow.
R.
E-mail me and I will send you the winning setup from the last visit at TQ hobbies with the Mission 1 (TQ'd & Won every state race that year). By design, the Mission always had tremendous rear traction and many drivers would only modify there car (roll centers etc) to reduce traction. It sounds as if something is not in proper working order....binding, rubbing etc?
paul@schumacherusa.net
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 12-01-2004, 01:12 PM   #8267
Originally posted by AdrianM
ba57ard - First of all...thats a very clever screen name....nice work! Sway bars can be deceptive in how the car feels. Our 1.2mm (Silver) bars are so thin that they do nothing when you cycle the suspension on the bench. However, you can certainly fee a difference on the track with and without the bars. The effect of the sway bars have a lot to do with spring rate and damping. If you are too stiff, bars will have less of a perceived effect.
What surface do you run on? Asphalt or Carpet, Rubber or Foam?
Thanks, lol
At the moment im running on carpet using a stock motor, with schumacher carpet dragons and 24mm revlite wheels, i pretty much have a great set up, (geting into the A finals at the moment) but i want to make full use of the bars, but i dnt seem to be feeling any effect. im using the Kit yellow bars if that helps.
cheers
ba57ard is offline   Reply With Quote
Old 12-01-2004, 02:45 PM   #8268
Send a message via ICQ to MattW
I generally use 1.5mm bars indoors with carpet dragons.
MattW is offline   Reply With Quote
Old 12-01-2004, 04:24 PM   #8269
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
PW has a good point about the bars moving back and forth. I've noticed that on my car as well. I'm going to get a hold of some retainer collars with set screws and put them on the bars, inside the mounts to keep them from moving side to side.
Jon Kerr is offline   Reply With Quote
Old 12-01-2004, 04:41 PM   #8270
IslandBwoy's Avatar
Hey King-G,
Thanks for the suggestions. I didnt realize that would be able to get the mi2 servo harware to work with mission. I'm going to try that as i'm lery about moding and screwing up my car. I considered using the lower arm position on the front but that would leave such a difference in setup between the front and the back that i was scared of creating a hole new problem. what you came up with is just what i was looking for, a way to shim the arms rather than changing uper arm position.
I'll try what you said and get back.
Thanks again,
R.
IslandBwoy is offline   Reply With Quote
Old 12-01-2004, 06:41 PM   #8271
Jon Kerr's Avatar
Here's a couple pics of what I was talking about with the retaining collars.
Old 12-01-2004, 06:41 PM   #8272
Jon Kerr's Avatar
one more
Old 12-01-2004, 07:44 PM   #8273
Jack Smash's Avatar
Trader Rating: 29 (100%+)
You just like posting pics of your rear end.
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 12-01-2004, 08:52 PM   #8274
Jon Kerr's Avatar
Can't tell a rear end from a front end.
Old 12-02-2004, 01:15 PM   #8275
PW
PW's Avatar
Product Update
We just received the new Schumacher Droop Gauges!
Part #H1027
Retail $39.99 with carrying case.
Paul Wynn
Old 12-02-2004, 01:17 PM   #8276
Dont suppose you know if they will be availible in the UK will they?
Old 12-02-2004, 02:09 PM   #8277
Yes, they are available from Schumacher UK - or stockests of.
Old 12-02-2004, 02:46 PM   #8278
Jon Kerr's Avatar
Mine's on the way Thanks for the call PW
Old 12-02-2004, 03:11 PM   #8279
King-G's Avatar
Send a message via ICQ to King-G
Jkerr, you need to get the bar retainers in purple!...I got some Purple ones from Square when I was in Japan last year...
very nice, and work well when using thinner bars...the other trick is to angle the plastic bar mounts inwards or outwards, to the mount kinda pinches the bar stopping it moving up and down in teh mount...
King-G is offline   Reply With Quote
Old 12-02-2004, 03:36 PM   #8280
There is a bar mount out there that is made from alloy with a grub screw in it to nip up onto the bar.
Jonas A had some when he came over for the UK Reedy race. I asked him about them. He thought (but wasn't totally sure) they were made by Square, origionally for the HPI Pro3. I had a look on their site and couldn't find them and haven't ever seen them anywhere else.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
