Old 11-21-2004, 08:11 AM   #8131
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I hate rain!!! Randy and I got Rained out today. Woke up to a thunder storm. Oh well. Next weekend.
Jon Kerr is offline   Reply With Quote
Old 11-21-2004, 09:08 AM   #8132
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally posted by HarshGuy
STLNLST --- how many times do I have to tell you, the motorhomes you sell ARE NOT TECHNICALLY HOUSES.
I just sold my house for 295,000 (could have gotten 315,000 if I held out longer but this was a divorce sale) I have a motor home on the lot for 425,000. Do you know how many MI2's I can buy after that sale
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 11-21-2004, 10:39 AM   #8133
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I finally get a sunday off of work and this happens... might just do SoCal on tuesday now that I want to race.
Old 11-21-2004, 11:06 AM   #8134
Jon Kerr's Avatar
Do they race off road at SoCal on Wednesdays? I was thinking about going there for some on road practice since I've never run the Mi2 on that track and I've got the day off.
Old 11-21-2004, 12:32 PM   #8135
Speedie's Avatar
Does anyone know the pitch and teeth number of the Mi2 belts?
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 11-21-2004, 02:33 PM   #8136
STLNLST's Avatar
are you trying to use other belts besides the stock equipment? I have never counted the teeth on the belts before.
Old 11-21-2004, 02:44 PM   #8137
Yep, off-road is wednesday. Play hookie on tuesday and I'll drive.
Old 11-21-2004, 03:03 PM   #8138
Speedie's Avatar
No I would like to shorten the wheelbase and move the motor more forward to add steering. I am more concerned about getting the right pitch.
Old 11-21-2004, 07:42 PM   #8139
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
you want to ADD steering?! this thing seems to have crazy steering... what setup are you running? maybe we could just make some tweaks to it and save the belt hunt...
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 11-21-2004, 08:13 PM   #8140
Speedie's Avatar
Racing on carpet ever since I started using foams I have had trouble getting enough steering. Wich isnt too hard to believe as most cars are designed to run on asphalt with rubbers. I had the same trouble with my TC3. I modified the battery tray and it is tight up against the steering mount and I can only get 51% front percentage. What I was looking to do is move the motor forward about a half an inch and shorten the wheelbase 6-8 mm I have it as short as it can go now. The car is handling well as is but I think it would be easier to tune with a few drastic change as I think its almost as loose as I can get it. I found a place for belts I just want to be sure of the pitch. I am more of the wrench type than a driver as anyone who races against me can tell ya. I would like to get the weight percentage closer to 53%.
Old 11-21-2004, 08:18 PM   #8141
well, before you do the work involved in moving the motor, have you tiried putting some lead wts near the front end to help simulate the 53% front wt? What about moving the front arms back some. The first time I ran my car on carpet, I had TOO much initial turn in actually and had to tone it down.. what compound of tires are you running?
Old 11-21-2004, 08:35 PM   #8142
Speedie's Avatar
IM running TRC cyans and magentas in low bite situations and purples and plaids in med to high bite. My wheelbase is short on both ends. It took 63g of weight up on the front bumper to get 53%. The car felt better turning in but not at the apex with the swing weight in front of the wheels it was unstable and liked to push in the middle randomly. With the wweight behind the front tires it would take over 100g to get the percentage. The one thing I am thinking might help would be able to get 0 toe in the rear instead of 1.5. I havent figured out how to do that yet tho.
Old 11-21-2004, 08:40 PM   #8143
RCGaryK's Avatar
Speedie, if you shorten up the wheelbase by moving the rear arms forward, you'll place more weight over the rear axle and it will push more. BUT if you move the front arms back you'll place more weight over the front axle which will improve handling.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 11-21-2004, 08:50 PM   #8144
if you get the u2741 alloy rear hub carrier, it makes it easy to change the rear toe with the inserts
Old 11-21-2004, 09:01 PM   #8145
Speedie's Avatar
Thanks Brian I didnt know the alloy carriers had the inserts in them. Ill put them on my list of things to try.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
