Old 12-13-2001, 05:29 PM   #796
STLNLST's Avatar
Trader Rating: 19 (100%+)
Adrian- Are those Schumacher rims on your car? If so do they come in black? They are 24mm right. I'm looking for black rims (I'm tired of yellow and white) Any help that you can give will be greatly appreciated.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 12-13-2001, 08:00 PM   #797
Sweet thanks agian Adrian I was scared I was gonna have to buy a set of HPI shocks...... 29 days left.......
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 12-13-2001, 09:19 PM   #798
ottoman's Avatar
R/C Tech Charter Subscriber
Well I ended up using the asc. copper springs and just got it together in time to take it along to the track tonight, just to make some laps before the race to check it out. It felt so good that I ran it in one heat and TQ'd . It had a slight push but I drove with out changing anything in the main and won the A by two laps. This is on carpet with rubber tires, a very tight and short track. I cant wait to spend some time with the setup but this thing flys!!! It has the snap of a TC3 and carries a lot of corner speed. So far I love it. I did notice that my rear diff feels pretty rough yet but the front one smoothed out nicely I hope I dont have a problem.
ottoman is offline   Reply With Quote
Old 12-13-2001, 11:11 PM   #799
Is there a page that has pictures of the diff schumacher tires where you can see the tread designs? I'd like to see what tread styles the yellow compound comes in. Thanks
Keyz28 is offline   Reply With Quote
Old 12-14-2001, 12:02 PM   #800
Dragonxmx's Avatar
Default Mission
Should finish my Mission tonight! Can't wait, looks sweet!
Dragonxmx is offline   Reply With Quote
Old 12-14-2001, 01:23 PM   #801
Trips's Avatar
Trader Rating: 16 (100%+)
Originally posted by Oasis2001
Can I just say how free this transmission is! Mine is just nuts! Its like there is nothing in the transmission. It seems to spin forever. Im loving the increased runtime! hehe
Just let me echo that thought... I was simply amazed at how free the drivetrain of the Mission is. Without even degreasing the bearings it was much freer than my XXX-S which has had the bearings degreased and oiled with Royal Oil every race day. My XXX-S is well broken in and as free or more so than any Losi I've seen, but it doesn't come close to the Mission.
I can't wait to run this weekend!
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 12-14-2001, 04:17 PM   #802
cornerspeed's Avatar
I rebuilt my rear diff after 2 race days. It was feeling a little rough. Now it is like glass. Give it a try. Nice diff design also.
cornerspeed is offline   Reply With Quote
Old 12-14-2001, 04:24 PM   #803
Oasis2001's Avatar
Send a message via ICQ to Oasis2001
Personally I think Losi has gone overboard with the one belt design and had to sacrifice too much just to say they use one belt. Schumacher have used common sense and used the best parts of the Axis and then incorporated this great design transMISSION.
Oasis2001 is offline   Reply With Quote
Old 12-14-2001, 04:27 PM   #804
Ty
Ty's Avatar
Trader Rating: 29 (100%+)
Trips,
Let me know how the Mission compares to the Losi after you race it this weekend. I will definitely try this Mission if my Losi is not to my liking after I receive the complete graphite kit and do some testing with some new setups. Did you use the Orion motor tester to check amp draw to figure that the Schumacher was more effecient? What were the numbers like? Thanks.
AndrianM,
How much are the titanium turnbuckles and hingepins and does Schumacher make a gear adapter for the Mission so I could use 64 pitch gears? Your car looks sweet. How would you compare the Keyence to a Cyclone TC or TC2? Thanks.
Ty is offline   Reply With Quote
Old 12-14-2001, 04:44 PM   #805
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Ottoman where did you race it? if your rear diff feels gritty it might be that you were lifting a rear tire in tight corners and that will cause it to get gritty quicker. Im glad that the car worked well for you. Be sure to stop by and see me this weekend.
Kevin K is offline   Reply With Quote
Old 12-14-2001, 05:57 PM   #806
Send a message via AIM to SpeedRacer16
cornerspeed- I was wodnering if you wre going racing tom at SoCal
Reguarding other things i just tried the 20 tooth pulley and like it way more than teh 17 tooth pulley.
I WANT MY ONE-WAY
SpeedRacer16 is offline   Reply With Quote
Old 12-14-2001, 06:01 PM   #807
Oasis2001's Avatar
At my local track I have found the 20t to be better. With the same overall ratio the 17T just revved out way to early. Maybe I have to keep gearing up though? 20T seems to be right on par with other cars though
Old 12-14-2001, 08:15 PM   #808
AdrianM's Avatar
Ty-The Ti turnbuckle/hinge pin kit is L1000 and sells for $29.99. We source all of our Ti from Lundsford so it is the best.
The Gear adaptor is U2252. You can use any brand of 48, BK or 64 pitch gears on it.
On the final drive issue. Seems like the factory drivers in England prefer the 17T pulley. We have a lot of testing to do regarding this. I think the 17 will be best on most tight tracks and the 20 will be better on very high speed flowing tracks. The best way to be certain which is better is to go to your track with a known good set up and test the internal ratios back to back with no other changes to the car. I'll be doing this a week from this Sunday.
Adrian Martinez
Old 12-14-2001, 08:20 PM   #809
Trips's Avatar
Originally posted by Ty
Trips,
Let me know how the Mission compares to the Losi after you race it this weekend. I will definitely try this Mission if my Losi is not to my liking after I receive the complete graphite kit and some test some new setups. Did you use the Orion motor tester to check amp draw to figure that the Schumacher was more effecient? What were the numbers like? Thanks.
Ty,
Using the same ratios (final rollout ratios, not just the same spur/pinion) the Mission pulled between 3.5 and 3.9 amps on the Orion motor checker at 4 volts, while the XXX-S was pulling around 5.1-5.5 amps at the same voltage. I was using a stock armature in a mod can at 0 degrees timing to run the drivetrains.
Trips
MARSHAL!!
Old 12-14-2001, 08:53 PM   #810
ottoman's Avatar
Kevin.... We race in Sheboygan at Hobby Town on Thursday nights. The diff felt rough when I got it and it still feels rough, the front one has smoothed out nicely. I havent had time to try your setup yet but maybe if we get to trackside early enough I can. I will make sure to stop and talk with you on Sunday. I won the stock A main last time I was there with my Losi but I know I can go faster with the mission. I also cant wait to get my oneway for the car since it really suites my driving style. Thanks for the help.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
