Old 11-02-2004, 10:36 PM   #7981
Matt Howard's Avatar
Originally posted by STLNLST
another reason for the chit chatter is because the car is working pretty good so not too many people are asking the usual questions. A basic set up works just about everywhere. What type of surface are you running on? We are now into our carpet season so most of our testing out in the Sacramento area will be all rug until March/April.
so stlnstl, what are you doing tonight? Did you watch the pistons game today? They look good this year. Are you gonna run 1/12 at the regionals? chit-chat with you later LOL People need to take it easy here, it's all good Go Yokomo!
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-02-2004, 11:39 PM   #7982
STLNLST's Avatar
Trader Rating: 19 (100%+)
You're a nut for that one.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 11-03-2004, 04:23 AM   #7983
Speedie's Avatar
There is a a reason Shane set up reginal threads on here. Chit chat is one thing but to carry on conversations in a thread that it is not meant for is inconsiderate.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 11-03-2004, 06:49 AM   #7984
STLNLST's Avatar
TOASTY!!!!!!!
Old 11-03-2004, 07:00 AM   #7985
Speedie's Avatar
Maybe you could direct these people to your local threads and help promote your area tracks and help out the newbies at the same time. I hope what I said wasnt taken as sarchasm.
Old 11-03-2004, 07:58 AM   #7986
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Since half my team drives for Schumacher can I post here?
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 11-03-2004, 09:32 AM   #7987
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Not unless you want to strictly talk about Schumacher and nothing else.
Old 11-03-2004, 09:37 AM   #7988
Brian and Gabe have their cars dialed. There is ya some schumacher talk lol
Old 11-03-2004, 10:21 AM   #7989
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
they come dialed from the box... it's fixin' to be supa-dialed
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 11-03-2004, 10:46 AM   #7990
Speedie's Avatar
What should I look for with a new car. Hop ups? Fixes? Any weak parts needing attention? Going to be running an Mi2 on carpet with foams. Thanks
Old 11-03-2004, 10:50 AM   #7991
mo
mo's Avatar
The only hop-ups I would say are needed are the lowered shock towers and steel or Ti cvd's. The only parts I've broke are the front arms and caster blocks. Another really good hop-up is the alloy rear hubs. They make the car more adjustable and give more steering by freeing up the rear end a little.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 11-03-2004, 11:04 AM   #7992
I've taken some big hits, and so far all I've broke is a caster block, havent bent any hinge pins, or cracked any other pieces.. I like the alum spindles because it makes it easy to ensure the kingpin angle is straight and not off any when threading into the stock spindles.. Otherwise, like mo said, towers and some cvd's... should be all ya need
Old 11-03-2004, 11:07 AM   #7993
Yep, I've seen him hit some stuff. Seen some stuff hit him too LOL
Old 11-03-2004, 11:18 AM   #7994
Default alloy rear hub Qs
I just purchased the alloy rear hubs and also the inboard mounts.
I have a few questions:
1) It looks like you can have inboard toe and outboard toe. What is the difference?
2) With the alloy rear mounts, it looks like you set wheel base by positioning the the plastic insert and using the set screw. Problem is, its impossible to find the exact same position each time. Maybe its something I am doing wrong. I am unclear to how this adjustment is suppose to work.
3) Is the point about adding a spacer under the ball joint on the top a way of tuning roll center? Adding more spacers lowers roll center? Is that right?
The paper instruction that comes with the rear hub is unclear.
4) One last question, which belt tensioner can I remove to loosen up the belt? I will be running Stock and 19T if it matters
Some help will be greatly appreciated
LeadFoot is offline   Reply With Quote
Old 11-03-2004, 11:18 AM   #7995
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
If you're going to be running a spool, I'd make sure to get a good supply of the CVD blades. Spools tend to beat them up pretty bad in the front and they need to be raplaced fairly ofthen. But again, this is only when running a spool.
Jon Kerr is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
