Schumacher Corner
#7816
Re: low shock towers
Originally posted by Arjen
II was looking for some options for my mi2 for this winter.
I saw the spool would that work on most carpet tracks?
I also saw the low shock towers but aren't they only for tamiya shocks? Or do you need them also with the new shocks?
Can those towers be used with normal shocks? and what would be the effect?
Are there any other parts improving tha car on carpet?
Arjen
(ps PW can i order directly from schumacher usa from europe?)
Arjen
The lower shock towers are for the tamiya as far as im aware. not sure about for the new shocks but id presume so...
& a spool will work well on nearly every style of track.... dependin on how twisty it is .
Do the alloy susp arm mounts change the standard toe in of the rear?
#7818
1.5* & 2.5* i think it is... with the alloy hubs ive heard its possible to get o* toe on the back, not sure if its true tho'
#7821
Originally posted by brians11
one more question, did anyone else have to add a .5mm shim under the alloy susp mount block to keep the arm from hitting the chassis?
what will the allow susp blocks change the rear toe to?
#7823
Schumacher UK handles all european accounts.
#7824
Originally posted by DavidAlford
You have to forgive him PW, he's different
#7827
well, it was only on the first arm that needed the spacers, so lemme see whats up with that arm... but now one of the mounts is super tight... having trouble.. lol
#7829
stlnlst- You have been off for a while painting you should start slow!!!!!!!!!!! Like give the body to Noah or John!!
PW-sick paint job. By the way Stlnlst told me what you said and that was just wrong why didnt you tell me you were running a oneway!!!!!!! Dont worry about taking shots at me I can take it. Have you got a standard setup for carpet yet mo and I were running this past sat and we had our cars rockin!!! I had a few technical problems and didnt finish a heat and had to leave early so this sat should be better.
#7830
