Old 10-15-2004, 02:48 PM   #7786
Post
Mark Barden .
mb racer is offline   Reply With Quote
Old 10-15-2004, 05:06 PM   #7787
Roll Centers
With the stock chassis we are running no front riser plate. We use 1mm or 1.5mm spacers from TakeOff. The lower you go the more steering you get.
In the rear we are using 1.5mm to 2mm spacers on top of the riser plate. The higher you go the more free your rear will be.
The problem is that the front has too much bite in the mid and exit of a corner & leads to the rear getting loose on power when transistioning and i have to back off the power a bit. Lowering the front RC will make this worse surely ??
Raising the rear RC takes grip off the rear in mid and exit and that's the opposite of what i'd need as well.
Correct me if im wrong tho' but thats my understand from what ive been told by ther top guys at the club. Unless the Mi2 is completeley different to what i no or im wrong .......
Also when u lowered the front RC & raised the rear's ... was this on a high grip track .... ?
TIA Steven
neveo is offline   Reply With Quote
Old 10-15-2004, 07:05 PM   #7788
protc3's Avatar
im shooting for the chassis and upper deck kit to sell for $89.99.i will announce the official price once kit is finalized after testing.as of right now,the colors i have in stock are black,satin black,titanium,gold and blue.right now i think that i will offer black,satin black and titanium colors for this kit.if anyone feels that any of the other colors would be nice on this car,please let me know.
thanks,
jason
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 10-15-2004, 07:20 PM   #7789
Trader Rating: 240 (99%+)
PURPLEONIUM!!!!!!!!!!!!!!!!!!!!!!!!!
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Race Ready Products, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 10-16-2004, 07:26 AM   #7790
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
will the top deck alone be available?
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 10-16-2004, 07:57 PM   #7791
Super Moderator
Tony Rivas's Avatar
Trader Rating: 53 (100%+)
Originally posted by protc3
the upper and lower deck are 2.5 mm.the differences are the batt location is as close as possible to the centerline and moved forward(still need to test the forward position,its location may change from front to rear),chassis is much thinner,i removed some through pockets and replaced with partial pockets,and i smoothed the corners of the chassis so it was not so squared off.the upper brace is closed in the front and rear to eliminate bulkhead compression or pinching that causes tweak.here is a front side pic of the car.there is a funny glare on the upper brace pocket in the pic that i cant explain.in person you can not see it.
looks good to bad i cant try it out!
The "Dominican Assassin"
Sorry for the Spelling but you know what I mean.
Tony Rivas is offline   Reply With Quote
Old 10-16-2004, 08:12 PM   #7792
STLNLST's Avatar
Trader Rating: 19 (100%+)
Another great day of racing. The carpet season is underway and the MI2 was well represented in the main. 4 MI2's with the MI2 taking the Tq and the win. The spool once again proved to be faster than the oneway. I know more about the car for this carpet season compared to last year when I first received the car.
Mo has a killer set up for foams and I have a killer set up for rubber tire's. With the regionals coming up in about two weeks we are looking to have the MI2 turn some heads if they aren't already looking our way.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 10-16-2004, 08:17 PM   #7793
Matt Howard's Avatar
oh they'll be looking your way,...but thinking "what's that smell?" LOLOLOL Did you get that email I sent you?
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-16-2004, 08:31 PM   #7794
STLNLST's Avatar
I just replied to it. Oh.....and that's the smell of a playa baby.....yeah man!!!
Old 10-16-2004, 10:19 PM   #7795
ottoman's Avatar
R/C Tech Charter Subscriber
Mo can you post your setup for carpet foam?
ottoman is offline   Reply With Quote
Old 10-17-2004, 07:25 AM   #7796
STLNLST
Can you post your setup for carpet w/rubber tires? Thanks
dway100 is offline   Reply With Quote
Old 10-17-2004, 10:44 AM   #7797
STLNLST's Avatar
Originally posted by dway100
STLNLST
I'm putting it to a set up sheet as we speak and will have it posted shortly
Old 10-17-2004, 11:02 AM   #7798
mo
mo's Avatar
My foam setup is now posted on my webite, www.mo-net.ws and on www.gearchart.com
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 10-17-2004, 12:30 PM   #7799
STLNLST's Avatar
STLNLST
My carpet set up is on www.gearchart.com also. It's listed under Clint Riley
It was real stable and easy to drive. You can drive it hard into the corners and dive in on guys running a oneway. Play around with it and let me know what you think. It's basically what we run on asphalt with two changes.
Old 10-17-2004, 02:37 PM   #7800
STLNLST
On the setup - I see that you used the front riser plate, but it doesn't say anything about the rear. Did you use the stock plate on the rear too?
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
