Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 10-14-2004, 10:24 AM
  #7771
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
His car was dialed and his driving was on. He just had some tough luck with traffic or else I think he could have given Greg a run for his money. He was running Greg down in one of the mains and hit a lapper that was on it's lid in the middle of the lane. Things like that happend to both of us.
Jon Kerr is offline
Old 10-14-2004, 11:26 AM
  #7772
rocketron's Avatar
Trader Rating: 16 (100%+)
Originally posted by HarshGuy
So am I reading correctly, the JRXS took the top 3 in mod?
no they took 4 of the top 5 with an xray third
rocketron is offline
Old 10-14-2004, 11:51 AM
  #7773
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally posted by PW
I just noticed this, Donny was the only car to go 19 laps in the 19 turn class during the mains at the Region race!!!!!!!!!!
That shows what Donny is capable of... Thats what made the off-road series we were racing in so much fun.
Randy Caster is offline
Old 10-14-2004, 01:36 PM
  #7774
cornerspeed's Avatar
PW- Just wondering if you got my set up sheet I faxed to you?
Also forgot to tell you what made a difference in the last round of mains was what sauce I used.
cornerspeed is offline
Old 10-14-2004, 03:42 PM
  #7775
Fran's Avatar
Trader Rating: 212 (100%+)
Default Mi2 upper deck problems
Hey guys, has anyone developed slop in the holes in the upper deck where the flat head steering screw goes into it? The side closest to the servo, the screw head rotates in the upper deck and has reamed out the hole its in. This is magnified at the front left hub. Do I need to replace the top deck, or has someone come up with a fix?
Fran is offline
Old 10-14-2004, 04:50 PM
  #7776
King-G's Avatar
apply some C.A to a cotton bud, and seal the carbon, as you would the edge of the chassis. the glue will fill it out a little, and remove the slop...dont get it too tight, as it may add force to the topdeck and cause tweak
King-G is offline
Old 10-14-2004, 05:28 PM
  #7777
protc3's Avatar
hey guys,just wanted to see what you think of my prototype Mi2 chassis.any input is appreciated
protc3 is offline
Old 10-14-2004, 06:59 PM
  #7778
Trader Rating: 264 (100%+)
Can I have one now?
Fred Perkins is offline
Old 10-14-2004, 07:26 PM
  #7779
protc3's Avatar
if all testing goes well,i will have them available within 2 weeks.i made a few changes on this chassis over the stock set up that i need to test.i moved the batteries extremely close to the centerline of the car.if all goes as planned,it will let the motor and electronics counterbalance the battery weight very well.being that the motor is off center on this car really helps this out.i also made the chassis 5/8 inch more narrow than stock to eliminate chassis drag.the changes to the top deck were visually noticable.the chassis is made from 2.5mm quasi isotropic carbon fiber(fibers are layed at 0,90,and 45 degrees)for excelent torsional strength.this made the car extremely rigid.flex can be added by using the stock deck if desired.i will keep you posted on test results.
protc3 is offline
Old 10-14-2004, 07:40 PM
  #7780
STLNLST's Avatar
Trader Rating: 32 (100%+)
how about another pic with a little more light. What's different about it and how thick is it?
STLNLST is offline
Old 10-14-2004, 08:19 PM
  #7781
King-G's Avatar
love teh motor milling, and the topdeck!...
how thick is the topdeck?..looks good for foam tires, nice and stiff.
King-G is offline
Old 10-14-2004, 11:46 PM
  #7782
Fran's Avatar
King-G,
Thanks for the reply. As it stands, I cried wolf The bearing in the left side bound up, ant loosened up the side. The CA on a Qtip will solve the problem...
Fran is offline
Old 10-15-2004, 12:52 AM
  #7783
Must admit that chassis looks cool. Moving the cells as far in as poss is a good idea, then making the chassis as narrow as possible. I much prfer the balence of the car when running like that.
Agree with Gav, the unter motor milling is good, have you lowered the motor mount as well???
MattW is offline
Old 10-15-2004, 03:18 AM
  #7784
protc3's Avatar
the upper and lower deck are 2.5 mm.the differences are the batt location is as close as possible to the centerline and moved forward(still need to test the forward position,its location may change from front to rear),chassis is much thinner,i removed some through pockets and replaced with partial pockets,and i smoothed the corners of the chassis so it was not so squared off.the upper brace is closed in the front and rear to eliminate bulkhead compression or pinching that causes tweak.here is a front side pic of the car.there is a funny glare on the upper brace pocket in the pic that i cant explain.in person you can not see it.
protc3 is offline
Old 10-15-2004, 02:03 PM
  #7785
arn671's Avatar
Default Mi2 Chassis Price
ProTc3, Already own one of your Xray chassis kits, and am very impressed with the quality; Glad to see you're working on the Mi2. Wondering about estimated price and whether or not you are going to offer color options or just black? Thanks
arn671 is offline
