Old 10-12-2004, 12:23 PM   #7726
Dragonxmx's Avatar
Default Carpet car
Pic of our Mi2.
Mi2 FW-06
Dragonxmx is offline   Reply With Quote
Old 10-12-2004, 12:40 PM   #7727
Also if anyone has a good starting setup for the Mi2 with a spool in, 27t, Low grip i would be very gratefull
Thanks Steven
Smart Cartridge Racing - Think Smart...Recycle & Save
PaintingRoly
2000 carpet nats
167 Posts since Dec 2003 10-10-2004 at 03:38 AM Report | IP: Logged
neveo- do you have stock or TRF shocks
Yeah im still running the stock shocks. Any news on the shocks from schumacher ?
neveo is offline   Reply With Quote
Old 10-12-2004, 12:50 PM   #7728
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
Default Re: Carpet car
Originally posted by Dragonxmx
Pic of our Mi2.
Mi2 FW-06
I thought the smaller black belt went on the right side of the car...
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 10-12-2004, 01:06 PM   #7729
I was thinkin that ... Also up front looking at the steering assembly there only appears to be 1 long screw.
Also ariel mount on the top deck. Interesting ....
Old 10-12-2004, 01:15 PM   #7730
Crashmaster's Avatar
Originally posted by ottoman
on a medium sized carpet track with rubber tires and a monster and the 86 spur start with a 20 or 21 tooth pinion. I recomend going with the 64 pitch spur... the monsters, binary and Epic ROAR legal motors are very touchy about gearing and a one tooth pinion change is a big change with 48 pitch
Cheers mate. Time to burn some carpet
Cheers
Crashmaster
Crashmaster is offline   Reply With Quote
Old 10-12-2004, 03:14 PM   #7731
speedxl's Avatar
R/C Tech Charter Subscriber
chattering usually happens when you have to heavy of a spring rate and too lite of a shock oil.
Does the front end roll too much (as in plowing/nose diving) in the front going thru the corner? That can cause that!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 10-12-2004, 03:29 PM   #7732
Dragonxmx's Avatar
Default Project Mi2
The servo saver is bolted to an aluminium standoff, on the follower side the standoff is one piece with a small button head cap screw to hold it in place. This assembly is far more rigid than the standard version.
Yes the belts have been reversed and the motor mount is closer to the centerline of the chassis.
FW-06_2
Old 10-12-2004, 03:55 PM   #7733
Whats the reasoning behind moving the belts then. I noticed u havent got any tensioners on... dont they catch on the decks ?
Old 10-12-2004, 04:06 PM   #7734
Dragonxmx's Avatar
The belts were switched to get the motor mount close to the centerline. The tensioners will go on when the belt stretches out a bit more. Since this chassis is ultra stiff the belt is just right as it is.
Old 10-12-2004, 04:15 PM   #7735
What do u gain from having the motor mount more central ?
And have u dont any other adjustments to the chassis ?
Old 10-12-2004, 04:38 PM   #7736
Racer X's Avatar
Great results and congrats to Mo, BigDog, Stlnlst, and, of course to Cornerspeed. Wishing I could have been there, but work and hunnydo's have been tough lately (still paying back for the Nats and the Reedy Race). The tab there should be taken care of and I plan on preping for the upcoming Carpet Regionals by running this Sat. The Cop also said that Soccer season will be ending soon and he'll be back out too. Hope to see you this weekend...
man, I am in need of a racing fix!
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 10-12-2004, 05:03 PM   #7737
Send a message via Yahoo to nomaak
dragon...what size foams do you like? what is your absolute race minimum?
nomaak is offline   Reply With Quote
Old 10-12-2004, 05:24 PM   #7738
Default Re: Project Mi2
FW-06_2
Quite a few interesting changes there. I like the bridged top deck ends, and the blue belt guides. My only question, why dont you have battery slots to lower the batteries?
When will the kit be available and how much will it be?
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 10-12-2004, 05:44 PM   #7739
Trader Rating: 240 (99%+)
Nice chassis design.
Still not sold on the Belt switching and the motor placement but nice.
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Race Ready Products, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 10-12-2004, 05:51 PM   #7740
PW
PW's Avatar
Send a message via AIM to PW
I always thought it was the other way around...LOL To heavy of oil for the spring
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
