Old 10-09-2004, 12:11 PM   #7666
PW
PW's Avatar
Send a message via AIM to PW
If you are using the carpet/lower towers front & rear, then you will remove that amount front and rear.
Yes, longer screws with locknuts.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 10-09-2004, 07:01 PM   #7667
Originally posted by AdrianM
[B]Roll Centers
With the stock chassis we are running no front riser plate. We use 1mm or 1.5mm spacers from TakeOff. The lower you go the more steering you get.
In the rear we are using 1.5mm to 2mm spacers on top of the riser plate. The higher you go the more free your rear will be. You may also mix up the spacers to get .5mm of anti-squat. This helps the rear rotate off power entering corners and really helps the car square up and exit the corner.
If you run the Teemu Chassis subtract .5mm from all the above spacers as that chassis is 2.5mm thick.
Dont suppose you know where i could get some from in the UK ? CML dont seem to have them listed ....
neveo is offline   Reply With Quote
Old 10-09-2004, 07:10 PM   #7668
Also if anyone has a good starting setup for the Mi2 with a spool in, 27t, Low grip i would be very gratefull
Thanks Steven
Old 10-09-2004, 08:38 PM   #7669
PaintingRoly's Avatar
Trader Rating: 56 (100%+)
neveo- do you have stock or TRF shocks
follow me @RC3grafix on Instagram for pictures of my paint work.
PaintingRoly is offline   Reply With Quote
Old 10-09-2004, 08:57 PM   #7670
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
Just ran the first race with my Mi2, oh wow, this thing has some crazy turn in... TQ'd 19t class and love this car... Even had some people talkin about switchin after seeing the 1st day of it running @ the track
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 10-10-2004, 01:02 AM   #7671
Send a message via ICQ to MattW
Neveo, I'm not sure how much of the take off hardware that CML have. Must admit i haven't ever seen the spacers either, which is a shame as i wanted some. I believe a lot of the anodised small bits that are labelled as "Fastrax" are probably the same as the Take off bits.
That said, i have got some labelled up as "Powers/Pentagon". I think these also come from CML, and came in a pack with 4 each of 1,1.5,2,2.5.
MattW is offline   Reply With Quote
Old 10-10-2004, 01:25 AM   #7672
Default Riser plates ?
Are the riser plates the carbon plate that the control arms sit on?Does any one have a pic of when they have been made into straps for support?
Mick
ratter is offline   Reply With Quote
Old 10-10-2004, 08:47 AM   #7673
I've seen those alum spacers in the take off line..
Old 10-10-2004, 09:34 AM   #7674
Default Front Support Brace
ratter:
Yes, the riser is the U-Shaped thin piece under the front arms.
Here is a picture of my brace. I used a piece of carbon fiber from an old shock tower I found in the "old parts bin" at the local hobby shop. The piece cost me only $1. I wanted to keep the riser plate as is in the kit.
However, I used the riser as a template.
Here is the picture of the brace before I installed it on the car.
LeadFoot is offline   Reply With Quote
Old 10-10-2004, 04:53 PM   #7675
Send a message via Yahoo to nomaak
sry to bring up old stuff but....i just aquired mission 1 and i have a question. what is the roll-center mod for the front end? and what's with the fusion bulkhead mod? i've bee searching these pages for 5 hours and i'm spent. any other "old" advice would be great "new" news to me.
nomaak is offline   Reply With Quote
Old 10-10-2004, 06:17 PM   #7676
PW
PW's Avatar
Forget about the Fusion bulkhead on the Mission 1...LOL Never worked very good!
The roll-center mod was using the alloy suspension mounts on the front so you could run the stock or raised hinge-pin. Go to www.schumacherusa.net and the part #U2575 Roll Centre Mod Kit - Mission
Paul Wynn
Old 10-10-2004, 06:18 PM   #7677
forty6's Avatar
PW, is your office closed tomorrow for the holiday? Thanks.
forty6 is offline   Reply With Quote
Old 10-10-2004, 06:22 PM   #7678
PW
PW's Avatar
Nope...Office is open
Paul Wynn
Old 10-10-2004, 10:18 PM   #7679
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally posted by RC Driver Gary
Did anyone warn Donny about Jon's spooning at night in the hotel room? Don, be afraid, be very AFRAID!
Gary you're not supposed to tell anyone about that! Shhhhhh!
Jon Kerr is offline   Reply With Quote
Old 10-10-2004, 11:17 PM   #7680
RCGaryK's Avatar
Well, blame Hodge, he told me. But what I want to know is how the heck did he know??
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
