Old 10-05-2004, 06:42 AM   #7576
STLNLST's Avatar
Trader Rating: 19 (100%+)
I had to hack my Mazda wing at the reedy race and that made the car terrible to drive. The rear end wasn't the same anymore. Going by roar rules the caddy that Mo has been running is legal. That's the body that I have been using and I really like it. We'll see how the tech is once we get down to the track.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 10-05-2004, 07:53 AM   #7577
mo
mo's Avatar
The ROAR Rule book does not specify a wings max. or min. dimension for touring cars in their diagram on page 67 of the rule book. It only shows that the roof must be at least 117mm high and on page 47 (Touring car class specifications) it states that the wing must not extend more than .4" off the rear of the body and may not extend above the roof height.
Originally posted by HarshGuy
How can you do that? ...at the nats we had to meaure the wing from one corner of the side dam to the opposing corner and it had to be a certain size (don't remember the size but I had to hack the hell out of my wing as did others), then the mesured from the front of the wing to the back of it, same thing, chad to be a certain size ...mounting lower wouldn't help that.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 10-05-2004, 08:03 AM   #7578
HarshGuy's Avatar
Nice ...they had a ROAR guy and everything there the where measuring like I said from corner to corner on the side dam of the wing then the length from the front of the wing to the back ...PW was there ...did you have to hack your wing?
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 10-05-2004, 08:53 AM   #7579
Hi, has anyone got a good set-up for a indoor carpet track which is very (and i meen very) tight track.
Chazz
Chazz is offline   Reply With Quote
Old 10-05-2004, 11:17 AM   #7580
mini-dub's Avatar
Trader Rating: 16 (100%+)
My wing ended up super small at nats. They were measuring the "wing chord". It had to be 40mm from the top rear corner of the side dam to the lower front corner of the side dam. Atleast thats how they measured mine. Then the wing could also only be 20mm tall. I don't think anyone's wing stuck above their roof height once they cut their wings down to that size . After the wing was small enough it looked wierd sitting on the back of the car.
-WR
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 10-05-2004, 02:02 PM   #7581
Send a message via AIM to Adam Hartzell
The same thing happened to a lot of guys at the 2003 asphalt nats in NC. R.O.A.R. really needs to build a tech stand.
Adam Hartzell is offline   Reply With Quote
Old 10-05-2004, 02:08 PM   #7582
edseb's Avatar
I'm having trouble getting parts. I'd like to purchase carpet rear shcok towers and a front spool. I tried the web site without luck. Can someone help here? I posted this on another thread, so diregard if you've already seen this, but this is where it belongs. Its for the Mi2 BTW.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 10-05-2004, 02:14 PM   #7583
mo
mo's Avatar
You can call or e-mail Billy at Speedworld Raceway (916) 783-8864, speeddog@mindsync.com or try www.speedtechrc.com
Old 10-05-2004, 04:02 PM   #7584
RCGaryK's Avatar
Ok guys, here at the track with foams and having a problem. The car is hopping the rear end a bit from the middle out, costing me some exit speed. I am using 80wt front, 60 wt 60 wt rear oil with ae copper fronts and 20.91lb rear springs. I am thinking about giving the car more negative camber and possibly dropping the rear spring down 1 rate. any ideas?
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 10-05-2004, 04:35 PM   #7585
With Foams i found the rear to hop when it had too much rear grip, make sure you run enough camber so that the tires cone slighly inwards, also try lengthening the camber link i found this to free up the car on foams. I also found that going to the second outer hole on the rear arm kept the car much flatter and more stable through fast changes of direction.
It might also be an issue of too heavy oil combined with too light a spring. I am finding the car likes light oil (35wt) with firmer springs with foam on asphalt.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 10-05-2004, 04:44 PM   #7586
Gary-- I have been using 30lb front springs w/60wt and 3 hole pistons. 28lb w/50wt in the back. The car just seems to work better when its stiffer.
Old 10-05-2004, 06:56 PM   #7587
PW
PW's Avatar
Send a message via AIM to PW
Your oil is WAY to heavy for the springs being used (heavy spring is ok, but not oil) You should never have to go more than 50 or 60wt in the front! Here is a quick story....One day some guy told Paul Lemieux his oil was to light for carpet/foam. So Paul poured out all the oil from his shocks and then layed down some of his fastest laps of the day
E-mail me for a setup paul@schumacherusa.net
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 10-05-2004, 07:08 PM   #7588
PW
PW's Avatar
Just give me a call at Schumacher or shoot me an e-mail paul@schumacherusa.net Speedtech R/C is always on top of things as well www.speedtechrc.com
Great hobbyshop is www.hobby101.com
Paul Wynn
Old 10-05-2004, 07:08 PM   #7589
Trader Rating: 74 (100%+)
Default hopping
Gary,
I have experienced the "hop" you are having trouble with. First, take out the riser plate. I have my mounts 1 mm spaced up from chassis. Then no spacer on the ball stud, for the alloy rear hub inner hole, upper center hole on tower for camber link. -2 deg camber, 0 toe in(you need the alloy arm mounts to reach this) or .5 with the plastic should still be ok. Unlike what Paul Wynn says, I am going to try a heavier setup for a techical track, and will keep you posted. Our cars are getting faster every night we run them. My sponsor and I run Mi2's and try a little different stuff and compare. I started with a hop, my hop has gone, now I am concentrating on going faster.
Serpent USA www.serpentamerica.com, King Max Servos, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 10-05-2004, 10:04 PM   #7590
Oasis's Avatar
Trader Rating: 36 (100%+)
My Mi2 is just not working..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
