Old 09-30-2004, 10:30 AM   #7456
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by jkerr0043
Randy, call Ridout Plastics. 858-560-1551
They in Kearny?
Old 09-30-2004, 10:49 AM   #7457
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Yup. On Ruffin Rd. Tell them Jon from Harrington sent you.
Jon Kerr is offline   Reply With Quote
Old 09-30-2004, 11:28 AM   #7458
I'll give em a call next week, not going to be able to make it out there today or tomorrow.
I did a trick job of mounting my transponder, cut a sleeve in the back of the foam bumper and slid it in, used a little shoe goo to keep it secure, but it looks really clean.
Old 09-30-2004, 12:06 PM   #7459
Jon Kerr's Avatar
I'll call the guy I know over there and see if they even have it. you're looking for .5mm and 1mm thick lexan, right?
Old 09-30-2004, 12:37 PM   #7460
That would work... I just picked up the EZ off, I'm going to see if I can get a good polished finish on the parts first, if not, it's time for black anodizing.
Old 09-30-2004, 01:10 PM   #7461
Jon Kerr's Avatar
Ridout didn't have it. They said Polycarb (lexan) isn't done in metric thicknesses. Everything I'm going to have access to through work is going to be standard sizing too, not metric. I'll do a little more digging and see if I can come up with someting.
Old 09-30-2004, 01:20 PM   #7462
It's not that huge of an issue if you cant find anything, maybe we could find CF in those thicknesses.
I stripped the anodizing off the little "20" block so far, came out really good, I dont know what Mark was using, but it seemed to look a lot better than what his came out like. It was polishible, but damn that was gonna take too much time, went over it with scotch brite to get a brushed finish and I'll have it anodized black.
Old 09-30-2004, 01:46 PM   #7463
Trader Rating: 28 (100%+)
I am having Taps Plastics make me some riser plates out of 1/16 or .020 inch polycarbonate. It converts to .508mm so if you need 1mm then you just stack 2 on top of each other. Just a thought since .020 polycarbonate is pretty common.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 09-30-2004, 02:11 PM   #7464
Jon Kerr's Avatar
I just got that suggestion from another guy I talked to. How much are they charging you to make the plates?
Old 09-30-2004, 02:38 PM   #7465
The 2ft by 2 ft piece of lexan cost me $6.00
I'm actually gonna cut it myself.Very simple.They called me back wanting too much for them to cut it.
Team I'm Over It
Old 09-30-2004, 02:54 PM   #7466
Jon Kerr's Avatar
I'll see if I can get some .020" from a friend of mine and have Randy mill them out.
Old 09-30-2004, 03:18 PM   #7467
AdrianM's Avatar
Remember that technically Lexan is not a true solid and that it will flow/compress under pressure over time. After you run your spacers a few times pull them out and measure them. I learned this with lexan spacers on my com lathe.
Adrian Martinez
Old 09-30-2004, 03:20 PM   #7468
The Evicerator
Is it an animal, mineral, or vegitable?
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 09-30-2004, 03:26 PM   #7469
This is very true, but the ones Donny showed me looked like they were made from rubbermade plastic, didnt take much to crush em apparently. I've made them from lexan in the past, and as long as I didnt crank down the screws it held its shape pretty well.
Old 09-30-2004, 03:32 PM   #7470
Jon Kerr's Avatar
Is there a material you suggest that we can get that thin that's not going to do that. All the materials I have access to would be way too soft. They'd deform right away when the screws are tightened.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
