Schumacher Corner
#7441
Originally posted by TimPotter
PW, do you guys have a good Rubber carpet starting setup ?
#7443
Thats awesome Tony
Here are a few things that I would probably do for carpet/rubber racing.
Next rate stiffer spring all around (gold fr & blue r).
Stiffer oil: 50 or 60wt front & 10 weight less in rear.
#7444
Hey guys, I talked with PW today and something he mentioned today that just made soooo much sense that I wanted to share it. If you use the Aluminum hub carriers, it can be hard to make sure the hubs are spaced properly left to right with the plastic inserts. Trim the plastic insert down so it is flush with the sides of the hub and just use shims to get the wheelbase set right. with this setup you don't need to use the setscrew anymore too. I need to head to the HS tonight and get some shims and I will post some pics. Thanks again for the tip PW.
#7445
Hey Matt,
Your points have been noted. Must get purple shock nuts. Black would suffice also and they are coming
As for the blue spacer, I normally run a silver 1mm one there. Last thing I did before the photo was put the blue 0.5mm one in. Typical!
Are you on ICQ ever these days? Been a while since we chatted. Have some Vantage questions aslo as I might get the new one in the next couple of weeks.
#7446
Hey Randy- Will you make me some Lexan .50mm and 1.00mm riser plates. Need them for the region 12 race. I take it the Teemu chassis was a virgin.
#7449
Adrian
I just wanted to thank you again for your help with my missing part and the setup advice you gave me today on the phone. I have ran alot of different cars in the past few years, but with customer service like that I know without even having run my Mi2 yet that I have found a car/company that I will stick with for quite a while.
Thanks again
David
Thanks again
David
#7452
#7453
R/C Tech Elite Member
#7454
Chris, yeah an on a bit - i guess just not when you are!!! Drop me an e-mail if you like. Time difference doesn't become such an issue that way!! We're back at W London this weekend - looks like it might live up to it's other name though "Wet"
