Old 09-29-2004, 10:24 AM   #7426
Shane Reinink's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Shane Reinink
well i don't know if anyone else has had my problems but my MI2 is just having way to much flex on carpet, I have tried everything to stiffin it up but to no avail, i will be shelving the mi2 and going back to my mission untill i figure this car out. I'm also thinking about buying BMI's chassis for it as soon as its available. Now i will say im not the ggreatest mechanic in the world but i never had any problems like this with my mission. i built the mission and went out and won races. I will be crying in my mi2 soup until i get her tunned in right.
Shane Reinink is online now   Reply With Quote
Old 09-29-2004, 10:27 AM   #7427
RCGaryK's Avatar
Try the Temmu chassis too. I have seen Nick Stampfel's car on carpet with this chassis and it works really well. I did notice that the flex that helped it on asphalt seemed to hinder it a bit on asphalt, but the car was still pretty good. just see the issues I had last night up in the thread.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 09-29-2004, 10:29 AM   #7428
AdrianM's Avatar
If you are running on carpet stiffer is better. On asphalt you are going to have a rough time with a really stiff car. Thats why the Xray guys are so inconsistant. Suspension setup is crucial with a stiff car. On Asphalt the really fast Xray guys are running stock 2.5mm chassis and flexy top decks. Hara won the nats with a 2mm carbon chassis on his Pro 4. He said the car was faster with the 2mm than the stock 2.5mm chassis becuase it flexed more.
The Teemu chassis works very well on asphalt. Its stiffer than stock but over all the car still works very well.
Adrian Martinez
Old 09-29-2004, 10:49 AM   #7429
Well like i said in my original post i will keep working on it. My Biggest problem other than the flexing of the chassis is that the steering was so erratic, it would almost spin out everytime on a left turn only. On the flexing i torn the whole car down and reset it and the chassis was straight, went out and ran for a coupl minutes, came back in and the chassis tweak was back. i then loosened up the top deck and retightened it. flex was gone. I even tried running it with the upperdeck a little loose, but that didn't work. This car is brand new never raced or has never wrecked. i don't understand how this tweak keeps coming back.
Old 09-29-2004, 11:16 AM   #7430
ottoman's Avatar
This may sound too simple but... when I first ran the MI2 with the stock chassis I also had a tweak and the chassis hung lower on the batt side.... after closer inspection I found that my batts didnt fit the fiberglass battery plate very well and the center cells actually pushed the center of the chassis down instead of fitting into the plate.... a little work with a file to increase the end clearance and everything came back to normal. Just a thought
ottoman is offline   Reply With Quote
Old 09-29-2004, 11:19 AM   #7431
coastaltony's Avatar
ottoman, good tip!
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 09-29-2004, 11:23 AM   #7432
TeamButter's Avatar
Send a message via AIM to TeamButter
Inconsistent? U sure about that?
Xray / BMI Racing / KO Propo / Team Epic / Parma-PSE / High Velocity Racing / TeamButter / P3 Graphics / MDI Racing
TeamButter is offline   Reply With Quote
Old 09-29-2004, 11:23 AM   #7433
AdrianM's Avatar
Schumacher MI2 - Are you hitting anything in those 2 minute runs. I cant see how a car can be flat at the beginning of a run and tweaked later without really wacking something on the track.
Adrian Martinez
Old 09-29-2004, 11:37 AM   #7434
AdrianM's Avatar
Butter - Yes, Inconsistent. But the worlds are in 4 weeks and I dont want to help Xray go faster so I'll shut up now...lol!
Adrian Martinez
Old 09-29-2004, 11:46 AM   #7435
adrian - the car has hit nothing
Old 09-29-2004, 11:47 AM   #7436
TeamButter's Avatar
We'll see I guess...
Old 09-29-2004, 11:47 AM   #7437
mo
mo's Avatar
Maybe it's a Tumor...
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 09-29-2004, 11:47 AM   #7438
I know that different TCs have different characteristics depending if you are using a mod motor and screaming through a turn vs a stock motor that has a lot of braking.
With the Mi2, is stiffer always better on carpet no matter if you are running Stock, 19T or Mod? Rubber vs Foam Tires?
Also, if you have a tight track vs a sweeping one, do you still want to run stiff?
I have the carpet towers but the standard CF chassis and I am having a bit of a push (running stock and 19T) and was wondering if its because of the flex. I am looking for a little more roll. Have not tried the spacers yet and I don't have the newer rear hubs yet. I was trying to avoid getting another chassis (low on cash at the moment because I needed repairs on my 1:1 car
LeadFoot is offline   Reply With Quote
Old 09-29-2004, 12:18 PM   #7439
RCGaryK's Avatar
It's Not a Tummah! Not a Tummah!
HorizonHobby.Com
Old 09-29-2004, 12:42 PM   #7440
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
PW, do you guys have a good Rubber carpet starting setup ?
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
