Schumacher Corner
#7396
aww now I feel really special...didnt realise it was only 10 cars....
I have tested previously...on our track, with low bite, I found the raised trans to be beneficial..larger moment, and more grip overall...
I am sure on most other tracks the raised C.O.G is more of a hindrence, I spoke to Phil about it in depth...as I was really sceptical....but I guess for most non treated European tracks, its been beneficial for efficiency and grip.
I can see why it isnt workin in the land of SUGAR...
I will be testing alot of high grip over the next months...so will be going back over it.
#7397
Chassis problem
It seams the more I run my mi2 the more I have to tweak the chassis weight to the left as the right side appears to be flexing with the weight of the batteries. This is killing ground clearance on the right. I have the batteries in the middle and all the way in. It just seems to keep getting worse. Has any one else had this problem?
#7399
Re: Chassis problem
Racer tip....Many racers that use double deck chassis cars store them with the top-plate loose Maybe I should listen to Troy's advice
dway....Give us a call at Schumacher and we will get you the proper pieces if they are missing 813 889 9691
#7400
Re: Re: Chassis problem
Originally posted by PW
Check you battery tray...Loosen the battery tray and then retighten
#7403
Well I raced the car on the rug tonight, left me scratching my head a bit. Initially I hit the track with my asphalt one-way setup on the car...I was always looking to free up the rear end so I figured this would be an ok starting spot. Well, it wasn't. The car had so much front bite I couldn't believe it. I eventually had to pull the one-way and go to a front diff. Here's how I had the car setup:
Front:
Tam Shocks, 50wt oil, 2 hole pistion, Copper AE Front Shocks
Middle hole in carpet shock tower for the upper mount, outside hole on arm
Middle Ackerman hole
No riser plate
No toe
-1.5 deg camber
Kit camber location on tower
Front arms spaced back
kit sway bar
Rear:
40 wt oil, 2 hole, Grey Tamiya spring (20.91lb)
One hole in from all the way out on carpet tower, all the way out on arm
kit riser plate
1.5 deg rear toe inboard
Kit hubs
Camber links mounted middle/top on tower, lower hole on hub
-1.5 deg camber
Arms spaced back
kit sway bar
Takeoff CS27 Premounts front and rear.
Batter mounted inside/forward.
Frewer Stratus
The car was doing 2 things that was funky. It felt like it was diffing out a lot, eventhough both diffs were locked. It also felt like it was dumping over a lot. I started out with 14.82 front and 14.08 rear springs, but they were too soft. My thoughts were to go to 80 wt front and 60 rear oil, swap out to the new alum hubs, and maybe try to get my hands on a spool. I was also thinking about going to Purple front and copper rear springs and taking the rear spacer out or putting the front one back in. Any thoughts?
Oh Randy, along with BMI, another company will also soon have a Mi2 chassis set, but I can't say who yet
Front:
No riser plate
No toe
-1.5 deg camber
kit sway bar
Rear:
kit riser plate
Kit hubs
-1.5 deg camber
Arms spaced back
kit sway bar
Frewer Stratus
#7404
Hey Gary I thought you were going to try carpet /foam, whats this rubber tire stuff I dont think you need to stiffen up the car that much... if I remember last time we ran carpet rubber we had asc. reds up front and I think blues in the rear and going to 3 degree rear toe helped plant the rear.... I know we didnt have any more than 45 wt in the shocks and we ran the front riser plate... you racing this Sunday? Maybe we will bring the rubber car along if you will be there.
#7405
I was planning on running foam, but I got to the track so last minute I decided to run rubber. The car was just...weird. But the good thing was that weach change I made helped make the car better and faster. I won't be running sunday, but maybe next tuesday, then the 8th or 9th at Road Rage. It wasn't that I needed to add rear grip, its that the front just had sooooo much freaking bite. I dunno. But I have things to do to the car over the next week. Just got my Ti screw set I ordered from Speedtech (Thanks Steve!), and I expect my KO VFS-1 and programmer tomorrow. I did try the car with foams after everything was over tonight too. Car turns in...HARD! Sobbotka thought it looked like the car was diffing and dumping too, so it's not just me
#7407
Originally posted by Randy Caster
Thanks Mo.
Thanks Mo.
Night, night...
#7408
Originally posted by XXX-S Bill
Get to bed kiddo!
Night, night...
Get to bed kiddo!
Night, night...
#7409
Front:
Tam Shocks, 50wt oil, 2 hole pistion, Copper AE Front Shocks 80- 90wt oil with two hole pistons
No riser plate
No toe
-1.5 deg camber
Kit camber location on tower try upper inner hole on carpet tower
Front arms spaced back try middle arm
kit sway bar, add .5mm spacer under rear mount of frt arms, to add anti-dive.
Rear:
40 wt oil, 2 hole, Grey Tamiya spring (20.91lb) 90 wt oil
kit riser plate get rid of the riser, add 1mm of spacers under arm mt
Kit hubs
Camber links mounted middle/top on tower, lower hole on hub try inner most lower hole
-1.5 deg camber
Arms spaced back/arms spaced foward
kit sway bar Try a heavier rear bar
Takeoff CS27 Premounts front and rear. GET RID OF RUBBER!!!
Frewer Stratus
Front:
No riser plate
No toe
-1.5 deg camber
Rear:
Kit hubs
-1.5 deg camber
Frewer Stratus
You will see Gary, that I added a few comment into your setup. CHeck it out.
#7410
Hey Gary....The first thing (major) I would change is the Frewer body. That body has WAY to much steering for carpet
Adam...I will think about that once I get to work
