Old 09-28-2004, 11:05 AM   #7366
mo
mo's Avatar
Here is a pic of my car with the Teemu Chassis on it. I think the car is actually more stable with the Teemu chassis, even though it is supposed to make it more aggressive. I think it is because it is a little stiffer and the weight is more centered.
mb racer, I think aluminum bones would bend too easy, especially with a spool or 1way.
Randy, you need to get the Schumacher packaged CVD's so they come with the bones that accept the blades. You can also buy the steel bones seperately from Schumacher.
Adrian, are those parts in now or later this week? I need to put an order in for a couple things that got torn up on the R12 this weekend. A body clip wedged itself in and around my belts and rear pully this weekend during one of the qualifyiers. The car stopped really quickley!
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 09-28-2004, 11:08 AM   #7367
mo
mo's Avatar
Originally posted by HarshGuy
Geeze ...the thread should be renamed to "Mo Corner"
You miss your Mi2, don't you?
Old 09-28-2004, 11:14 AM   #7368
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Adrian, I have been running the HPI black bar on the rear of my car, is thier an equivelant to that bar in the new set ?
Jon, I had an insert pop out on older Ti bone, the new ones seem to hold up better.
Adrain, is there a part number for just the Ti bone ?
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 09-28-2004, 11:16 AM   #7369
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I like the fixed batteries in the Teemu chassis. Is it any thicker than stock?
Old 09-28-2004, 11:20 AM   #7370
mo
mo's Avatar
Yes, it its 2.5mm and the stock chassis is 2mm.
Old 09-28-2004, 11:33 AM   #7371
AdrianM's Avatar
Mo - Everything I posted is in stock now.
The U2728 Sway Bars are Silver - 1.2mm or .047" and Black - 1.5mm or .059". You also get 4 alloy bar end ball studs 4 links and 8 sway bar mounts.
U2727 is the Stock Yellow bar - 1.7mm or .067"
Adrian Martinez
Old 09-28-2004, 11:44 AM   #7372
I'll definately like it then, I've always tried to run the stiffest chassis avalible.
Old 09-28-2004, 12:34 PM   #7373
Nice car mo
Chazz
Chazz is offline   Reply With Quote
Old 09-28-2004, 01:05 PM   #7374
mo
mo's Avatar
Thanks Chazz, it's even better now that I've got my Keyence Rapida in it.
Old 09-28-2004, 01:21 PM   #7375
Anyone interested in my NIP stock shocks and chassis, UPS just dropped off the car.
Old 09-28-2004, 01:29 PM   #7376
Default OPtion parts MI2
I saw everyone using an other bumper and that was an pdub racing one. When i buy one do i need any other parts to install it?
I was also looking for other parts to improve my MI2.
I am waiting for the new shocks and i have now:
Alloy front/rear hubs
alloy castor
rear alloy pivot block
alloy 20t pulley
front/rear steel driveshafts
one way
I am also looking for titanium driveshafts but i want just the axles is that possible?
At the last race i saw that my car weights 1575 so i thought wow that's a lot. Can you give me some tips to lose weight?
Thanks for all of your help.
Arjen
Arjen is offline   Reply With Quote
Old 09-28-2004, 02:27 PM   #7377
TimPotter's Avatar
Arjen, the Pdub bumper is a direct fit, no other parts needed.
Old 09-28-2004, 02:52 PM   #7378
Randy
You may want to hold off on the teemu chassis because BMI is working on a chassis, topdeck and shock towers for the Mi2.
dway100 is offline   Reply With Quote
Old 09-28-2004, 02:57 PM   #7379
Originally posted by dway100
Randy
If it turns out they are better, I'll just get em as well.. I like factory equipment though, it always fits best.
Old 09-28-2004, 03:27 PM   #7380
TimPotter's Avatar
I chatted with Jason on his ideas for the Mi2 chassis, and just like his other products, I am sure they will be stout. It is nice to see aftermarket companies jumping on the Schumacher Train
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
