Old 09-28-2004, 11:26 AM   #7351
mo
mo's Avatar
Randy, I have steel CVD's on 1 car and Ti on the other. Both have held up equally well.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 09-28-2004, 11:28 AM   #7352
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I know Donny won't run the Ti ones. He had a few of the inserts throw on him. I haven't run the car enough to see this but I'll keep an eye open. I always liked running steel on the Losi so I may just go to them anyways. I'm just not a fan of plastic drivetrain parts.
Jon Kerr is offline   Reply With Quote
Old 09-28-2004, 11:31 AM   #7353
Jon Kerr's Avatar
Randy, I have a set of steel bones you can use for the front to start out if you want. LMK.
Old 09-28-2004, 11:36 AM   #7354
Default hey jon
how was your practice session last week with the mi2 .. I ran mine sunday and it was pretty good compared to my x-ray.. I could really feel a diffrence between the 2 .. only prob is cvd's .. which one should i run in the front .. I like the plastic in the rear ,, lmk.thanks
Mark Barden .
mb racer is offline   Reply With Quote
Old 09-28-2004, 11:38 AM   #7355
mo
mo's Avatar
Yeah, the Steel will probably be your safest bet in the front.
Old 09-28-2004, 11:41 AM   #7356
AdrianM's Avatar
New Arrivals:
U2797 - Alloy spool with CNC pully
U2798 - Replacement pully for spool
U2728 - Mi2 Speed Secret Sway bar kit 1.2 & 1.5mm front and rear bars, links, mounts.
H1026 - Purple Alloy Stepped ride height gauge
H1028 - Purple Plastic Battery Jig
Back in Stock:
U2742 - Alloy Suspension mounts (2.5deg rear blocks)
U2782 - Teemu Chassis
U2741 - Alloy Rear Hub Carriers
U2708 - Carbon Top Decks
The spool is really light and stronger than the stock outputs.
The sway bars are really important. I've been wanting to put a bit more roll into my car but not with springs.
Soon we will have H1027 - Purple Alloy Droop gauge and car stands in a black foam case.
Adrian Martinez
Old 09-28-2004, 11:41 AM   #7357
Jon Kerr's Avatar
I'm running Ti CVD's all around. Plastic should be fine in the rear but you should put the TI or the steel ones in the front. Are you running a spool? If so, make sure you check the front blades often. They tend to wear quickly when running a spool. You don't want one of those go out and beat the hell out of the outdrive.
Overall the car was good. It was very easy to drive and it was very consistant. The thing I like most about this car is the changes you make do exactly that they're supposed to do. The Losi was odd that way. It seemed to do the opposite of what it should when some changes were made.
Old 09-28-2004, 11:42 AM   #7358
HarshGuy's Avatar
Geeze ...the thread should be renamed to "Mo Corner"
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 09-28-2004, 11:43 AM   #7359
Randy Caster's Avatar
Trader Rating: 45 (100%+)
I tried titanium back on the SD, and wasnt impressed. With MIP steel can you still run the blades?
Old 09-28-2004, 11:44 AM   #7360
thanks MO !! .. Ill give it a try .. what do you think about alum in the front . maybe IRS bones and changing the pin cusions to the shuie pins and blades ??
Mark Barden .
Old 09-28-2004, 11:46 AM   #7361
What is the Teemu chassis? Pics?
Old 09-28-2004, 11:48 AM   #7362
Post
ok Im still working on mine and so far Im impressed with it .. the biggest thing i noticed is it rotates very fast .. took a few packs to get used too .. hope to see you guys soon up the hill .. and just a note up the hill racing is free through dec..thats every sunday..
Mark Barden .
Old 09-28-2004, 11:48 AM   #7363
Jon Kerr's Avatar
The Teemu Chassis is a narrower chassis with different battery location (I beleive) I've got one. I'll let you take a look.
Old 09-28-2004, 11:50 AM   #7364
Id definately like to check it out.
Anyone already run it and can give me an idea of what it does for the handling?
Old 09-28-2004, 11:57 AM   #7365
AdrianM's Avatar
It has a fixed battery position so the tray is gone, chassis is narrower so it has less scraping in corners. The Battery is 2.5mm forward of the rear most batt position on the kit chassis...it works very well.
Adrian Martinez
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
