Old 09-15-2004, 09:42 PM   #7186
Send a message via AIM to Adam Hartzell
PW- Thanks, but I have the same problem there too. Oh well, not a big deal. I was just curious as to what everyone was using on asphalt. I'll just start with what Hector gave me.
Adam Hartzell is offline   Reply With Quote
Old 09-16-2004, 09:48 AM   #7187
speedxl's Avatar
R/C Tech Charter Subscriber
Adam its pretty much PW'S setup with a couple changes for my style of driving.
PW's is great starting point!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 09-16-2004, 07:05 PM   #7188
Trader Rating: 74 (100%+)
Default Tamiya shocks
Originally posted by jkerr0043
PW- I got my car last night. I've got a set of Tamiya shocks I'm going to put on it. What towers are you guys running with the Tamiya shocks and do you have to limit them at all?
I agree with Paul, no limits, 63 mm long, but I used the trick alloy cups, and the stock ends, with the TRF nitride suspension balls. The upper mounts fit the small plastic ball into the hole, it works mint!.
I finally figured out how to setup the alloy rear hubs, like I already stated PW, overn engineered, but sweet at the same time. Tommorow I will do some testing!TTYL.
Serpent USA www.serpentamerica.com, Maclan , Xpert, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, JSpec custom stickers and apparel.
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 09-16-2004, 11:05 PM   #7189
Oasis's Avatar
Trader Rating: 36 (100%+)
Man,Xrc cars ramboed the Mi2 pretty hard in the Oct. mag. Pretty much said it was a POS,Had a problem with the front end chattering under power..do all Mi2's do this?? Or did they have a problem with theirs.But from what it sounded..I bought the wrong car..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 09-17-2004, 12:06 AM   #7190
STLNLST's Avatar
Trader Rating: 17 (100%+)
xxxkat- Just run the car and go from there. You won't be dis-satisfied. The car responds well to set up's and is very easy to work on. Put it this way....you bought a pro 4 even though I know you heard about all of the gear problems it had. What works for one may not work for the other. All of the guys out here have been doing well with the car. In fact we are going to have a mini Schumacher nationals this saturday in santa cruz. Racenut, Dujuan, Mo, and myself are looking to put it down in the 19 turn class and gas........................
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 09-17-2004, 05:04 AM   #7191
Default ?
Do you believe everything you read? Oh, yeah I am selling the Statue of Liberty on Ebay, it closes auction in 20 minutes, check it out.
My point is this, RUN the car, then make your OWN assessment of the car, handling, and changes to be made. You will not be dissapointed. Give a chance, we all have.
Old 09-17-2004, 07:14 AM   #7192
Oasis's Avatar
Yea,your right..But on the Pro4 i bought one of the first ones..I found out the hard way about the gears.. But Xrc did hit it right on the money when they tested the shaft cars(I think I still have every one of the cars they tested..I would have to look)But I'm still wondering about the front end chatter..But I just missed the Ebay auction.. I think I could have won..went for cheap..
Old 09-17-2004, 07:49 AM   #7193
Super Moderator
Paul or Adrian can you email me a setup to start with...only have a Diff ready, no spool or oneway. forgot, for carpet.
robert.barry@burrowco.com
Tekno | JConcepts | RRP | LutzRC | BOOM RC
Bob Barry is offline   Reply With Quote
Old 09-17-2004, 08:09 AM   #7194
Trader Rating: 28 (100%+)
xxxkat,
Like everyone has pointed out,you can't judge the kit on the basis of what a magazine says.Its{article} really pointed towards the less informed.Which I know you are not.They marked schumacher factory support as lower then then the other manufacturers....When I read that,I started to laugh.We all know thats a load of crap.Made me think of all the rest of what they wrote.
Run the car.Through the PDub setup on it for starters and go from there.You will love it.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 09-17-2004, 10:19 AM   #7195
koabich's Avatar
Send a message via Yahoo to koabich
Originally posted by racenut123
xxxkat,
Having run the Mi2 and the Mission in the past, I still read this thread. I have to say regarding the magazine article, I could not dissagree with you guys more. Based on your logic to not take the magazines point on the car and to actually drive one yourself seems weird. That means that I would have to buy every car that I am interested in and run it. If I don't like then sell it and loose my butt. You can argue that you could borrow someone's else's Mi2 but them you assume that that person would actually let you drive it, and you assume that the cars is set up to your driving style. Driving a car that is not set up to your driving style is more impactful on the potential consumer than reading a not so good write up on the car.
We all know that when magazines write articles on cars, that the article is mostly opinion. That they never compare apples to apples. They test one car with certain electronics on certain tracks one month and then another month test a different car with different electronics on a different track and then try to compare the two cars.
My point is, it is not possible for a person to drive every car they may want to purchase in order to form an opinion on if they will buy the car or not. It is not possible to always drive a buddies car either and if you do, it is not always set up to that individuals taste.
We have to use the magazine articles as what they are...a point of reference. People who are interested in cars such as the Mi2, X-Ray, 415...etc... are are racers...not people messing around in the street. Readers should use these articles and, based on their experience, filter out all irrelevant information.
I do agree with the poor factory support of Schumacher as well. I have delt with Paul and Adrian on numerous occasions and they were always more than willing to go out of their way to help. But this isn't what the magazine ment. In my area and all other LHS I have been in had zero parts support (even if they sell the cars). You can order the parts directly from Schumacher but it seemed that every time I needed something I had to wait a month for it to get here from England.
Sorry for the long rant...flame away!
koabich is offline   Reply With Quote
Old 09-17-2004, 11:35 AM   #7196
tuil21's Avatar
what parts on the mi2 do i always need to have with me? what parts brake the most?
tuil21 is offline   Reply With Quote
Old 09-17-2004, 11:38 AM   #7197
Oasis's Avatar
koabich,I do have to agree with you on your post.. racenut I do understand your point as well,But what I was getting at is the shootout that Xtreme did is waaaay above what Car Action,or Driver has done,They do make adjustments to the cars,they do run them over a 3 day test period,they do really say why they have an opinion on how the cars handles.The testers just happen to be people who i trust their opinion will not be biased.And after reading the first shootout(shaft drive cars)My opinion was the same(well very close)of the cars in the shootout.And yes I do own all the cars that were tested.Thats why I was wondering about the chatter in the front end.
Old 09-17-2004, 12:03 PM   #7198
ottoman's Avatar
I havent read the article so I cant comment on that but I can on the factory support.
Wether or not your LHS stocks Schumacher parts is not "Factory support" that is LHS support. Schumacher USA stocks most every part you will need and receives shipments from England every week. If you base factory support on parts availability then most cars fall short.... Pro 4 (HPI) isnt very good.... XRAY was hard to get parts when I raced them... Tamiya, I also had problems getting parts. Associted has great parts availability but try to get a knowledgeable person on the phone when you have a technical question.
One of the best parts of running a Schumacher is knowing you can talk to Paul or Adrian and get a straight answer.
ottoman is offline   Reply With Quote
Old 09-17-2004, 12:07 PM   #7199
Oasis's Avatar
Try running a Tech car..you will then know what hard to find parts is really all about..
Old 09-17-2004, 12:31 PM   #7200
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
I would go out on a limb and say. "No other company supports a product like Schumacher USA". What other company can you call and get the "Real info from people that use the product". Paul, Adrian and Troy all race the product, are constantly in contact with other team drivers, and are willing to take the time and stand behind the advise they give.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
