Old 12-06-2001, 11:01 PM   #706
SpeedTech's Avatar
Hi Guys,
Just want to drop a quick note in here that we are having our Christmas Super Sale going on right now!!! For details, check out our website first page. We are also giving away a car kit for FREE this month.
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 12-07-2001, 05:10 AM   #707
Send a message via ICQ to MattW
Chris, Not sure if you can see much........
MattW is offline   Reply With Quote
Old 12-07-2001, 05:11 AM   #708
and another
Old 12-07-2001, 07:07 AM   #709
Oasis2001's Avatar
Send a message via ICQ to Oasis2001
Thanks Matt. Funny with your stickers. I chose to use the same ones in almost exactly the same spots! My Mission on is a bit higher on the angle, and the website ones are nearer the motor.
As for the wiring mine is identical tot hat just with two holes drilled through the top part of the battery mount. Im starting to think this was a bad idea but it does keep the wires under control
Oasis2001 is offline   Reply With Quote
Old 12-07-2001, 07:15 AM   #710
cornerspeed's Avatar
The battery wires have a place to run under the brace in the center. I can't take credit for noticing this. SpeedRacer16 showed me this. Check it out.
cornerspeed is offline   Reply With Quote
Old 12-07-2001, 07:18 AM   #711
Oasis2001's Avatar
I saw that but found it a bit tight for twop wires. This is 12 gauge wire
Old 12-07-2001, 08:22 AM   #712
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Thanks for all the building tips, keep'em coming. I should be getting mine in a few weeks when I have money.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 12-07-2001, 08:50 AM   #713
Regional Moderator
Darkseid's Avatar
MattW: nice car. Very clean layout.
TLR 22...Tamiya F104...
Old 12-07-2001, 12:15 PM   #714
I know I have already posted this tip, but I believe it is important.
If you assemble the car with the stainless screw set, tap the plastic holes with a 3mm tap. I also counter sunk the holes deeper s o the screw heads don't stick down below.
Old 12-07-2001, 09:30 PM   #715
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Anyone have a good setup for high traction asphalt for the mission ?
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 12-08-2001, 03:23 AM   #716
Oasis2001's Avatar
Spooky - How hot is it in Florida. Im in Melbourne Australia dn its getting hot here. How found the car to be blinding fast in cool conditions but Im now working on warmer weather.
Also my small belt is quite tight. Have any of you guys lossened it up at all. The large belt is very very loose but does not skip.
Old 12-08-2001, 06:41 AM   #717
TimPotter's Avatar
Oasis, whats the story morning glory... sorry
It is about 80 F here, It will be cooling of a little, but not much. Depending on the day, track temp will still be over 100. It is only a couple of degrees warmer then where Adrian is...
http://www.weather.com/weather/local/33436
Old 12-08-2001, 09:21 AM   #718
Regional Moderator
Darkseid's Avatar
cornorspeed: Thats a good point about the counter sinking. I remember that on my original SSt and on my '99pro (both with the S1 composite chassis) the screws sat flush with the chassis plates. But, on the graphite chassis on a Axis I recently got from someone, the screws on the bottom protrude slightly, because the counter sinking isn't deep enough.
Whats up with that? Is the counter sinking not as good on the newer cars as it was on the older ones, or is it just that they don't counter sink the graphite chassis' as deep?
Old 12-08-2001, 03:12 PM   #719
oasis, I wouldn't try loosening the rear belt, as it has to take all of the power from the motor.
Darkseid, Cheers...
Old 12-08-2001, 08:23 PM   #720
Default mission wins
MISSION T.Q. AND WINS MOD TOURING AT THE SNOWBIRDS WARM-UP RACE. HIGH TRACTION INDOOR CARPET.
SET-UP STOCK SET-UP EXCEPT FOR
FRONT SHOCKS ALL THE WAY IN. #2 HOLE PISTON 80WT OIL
SCHUMACHER SILVER SPRING. BOTH CASTER SPACERS MOVED UP FRONT MOVING UPPER ARM BACK. 2DEG. CAMBER. SCHUMACHER THICK FRONT SWAY BAR .
REAR SHOCKS ONE HOLE OUT FROM FRONT. #2HOLE PISTON 80WT OIL. SCHUMACHER SILVER SPRING, NO SWAYBAR. 2DEG. TOE-IN.
8 DOUBLE
CAR WAS AMAZING PLENTY OF STEERING PLENTY OF REAR TRACTION EXCELLENT CORNER SPEED.
brandon is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
