Old 09-13-2004, 10:05 PM   #7126
Trader Rating: 28 (100%+)
Default Welcome aboard!
You will love racing this car. I am sure Don V. has showed you what the car can do! You are just like Stlnlst.....a past Losi zero,turned Schumacher hero! Have fun bro!
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 09-13-2004, 10:08 PM   #7127
Originally posted by HarshGuy
Touche!!!! ...Santa Cruz, isn't that were chicks braide their armpit hair?
Hey now! They mix a little hemp into that armpit hair so cut them some slack!
Team I'm Over It
Old 09-13-2004, 10:13 PM   #7128
Oasis's Avatar
Trader Rating: 36 (100%+)
Like it would matter to Harsh.. Do you guys run the sway bars,Front and rear? Or not at all.
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 09-13-2004, 10:49 PM   #7129
STLNLST's Avatar
Trader Rating: 19 (100%+)
I always run my sway bars front and rear. The car just feels better (to me ) with them hooked up.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 09-13-2004, 10:55 PM   #7130
STLNLST's Avatar
racenut- I was a zero???
jkerr0043- Congrats and welcome aboard. You're running the region 12 race right??? That's just one more threat in what ever class you're running.
Old 09-14-2004, 12:19 AM   #7131
edseb's Avatar
Jkerr:
Congrats on the Schumacher. Make sure you screw in the pins straight in the front hubs. Read some of these pages, you'll see what I mean. Anyway, I've had some glitching with mine, but the car is easy to get planted.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 09-14-2004, 02:20 AM   #7132
Oasis's Avatar
Glitching..Is that a problem with the Mi2..??
Old 09-14-2004, 04:30 AM   #7133
Trader Rating: 74 (100%+)
Default carpet setup
Originally posted by mini-dub
PW - Can you post a link or something when you get that guys (sorry I forgot his name ) foam tire setup? I plan on basically building the car with most the stock parts, then switching them for aftermarket to see if I like it better or worse. Andrew also said he has some foam tire setups.
leadfoot - I'm pretty sure Paul is using Associated springs, but I could be wrong... PW? I think the main reason people are running other companies springs is because most people are running the Tamiya shocks. And the Schue springs don't fit those. Also the Schue springs don't have as many tuning options as lots of others. When I switched from my stock schumacher springs (when I didn't have my Tamiya shocks) to some associated springs it made my car much much better. My lap times probably improved by 5 seconds because the car didnt traction roll and stuff every lap.
-WR
Start with this,
Frt, no riser plate, make a brace for the front mount out of the riser plaste.
Carpet frt tower
50 wt oil, 3 hole
Springs vary
tie rods mount to center hole on servo saver
Second hole in from outer on twr
middle upper hole for camber
-2 deg camber, 0 toe
wheel base middle
STEEL drive shaft
Bud frt bumper
and large foam bumper
Stock sway
1mm droop
Rear
Narrow rear belt
50wt , 3 hole pistons
one hole in from outer on top of Carpet tower
upper middle hole for camber
No riser plate, raised 1mm for the mounts
lower innermost hole on the hub for camber, raised rh on the outside
-1.5 toe in,
No sway
0 droop
20t pulley
122 64p RW spur, with gear adapter
I would really recommend getting a few things:
Alloy arm nounts for the rear.
Alloy rear hub carriers. These both allow greater tunning for the rear, you'll see what I mean when you get them.....
Steel driveshafts are a must, F&r
keep the stock 4 degree castor blocks, just stock up on them
hard suspension arms are cool, but just as able to break.
My car has :
alloy arm mounts
alloy rear hubs
alloy 4 degree castor block
alloy 20t layshaft gears
TIR shock mounts
alloy gear adaptor
RW 122t 64p spur
CNC frt and rear diff pullies
ceramic bearings
titanium pins
TRF shocks
Carpet towers
Dirt Trix Bumper
,,,,,, I think that is all. Let me know how it works for you.
Oh yeah gearing, 120-122t spur with 32-40 pinion, ranges on the motor and battery
Serpent USA www.serpentamerica.com, Maclan , Xpert, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, Rawspeed RC www.rawspeedrc.com, JSpec Stickers
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 09-14-2004, 06:01 AM   #7134
Super Moderator
Trader Rating: 17 (100%+)
damn raul layin it down you go boy LOL
Tekno | BLOK | JConcepts | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Old 09-14-2004, 06:42 AM   #7135
Jon Kerr's Avatar
Thanks guys.
Jon Kerr is offline   Reply With Quote
Old 09-14-2004, 07:46 AM   #7136
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
jkerr,
Welcome Aboard, I am sure you will like the car as much as we do.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 09-14-2004, 08:05 AM   #7137
mini-dub: Thank you for the reply!
jkerr0043: Cool! I followed your posts on the XXX-S thread, glad to see you on the Shuie Team
Raul Garcia: That is great! I don't know if that is what you had tried to send me in PDF format but that is what I was looking for. Thanks!
LeadFoot is offline   Reply With Quote
Old 09-14-2004, 08:26 AM   #7138
Super Moderator
maybe one day I'll get my invite for the team ***hint hint***
Old 09-14-2004, 08:55 AM   #7139
Trader Rating: 57 (100%+)
Default hello
I also wanted to take the time to introduce myself. Im a new Team Schumacher driver, primarily racing in Arkansas, Missouri, Oklahoma, and Texas. I also would like to thank Paul for the opprotunity to run for Schumacher. I look forward to sharing tips and setups to help get us all up to speed with the car. Look forward to racing with some of you guys at the '05 Snowbirds. Jkerr welcome to the team.
gporta77 is offline   Reply With Quote
Old 09-14-2004, 09:00 AM   #7140
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
You guys got yourself a great driver in Gabe. Super fast and super nice. I know we are proud to have him with us at Brahma.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
