Old 09-10-2004, 04:34 AM   #7081
Trader Rating: 74 (100%+)
Default pullies
Originally posted by RC Driver Gary
Adrian, nice talking to you today. I forgot to ask about the pulley, but I was 90% sure I knew the answer. 20T not the 17, right? Thanks again.
Gary,
20t pulley is always used. The 17t just sits in the box.
On another note, my goodies are coming in one piece ata atime, but my most important one are here. I want to test the stiction of these so call ceramic bearings. I am going to clean and install my kit bearings, hook up a stock motor, to my LRP pulsar, and test the amp draw with the motor @ 4volts driving the drivetrain(no wheels)., Then, I am going to disassemble the car, replacethe bearings with ceramics, and retest the same . To see what the difference is in amp draw. Hopefully it will be a good difference. We will see.
Adrian, I got my hubs, thanks.
I cant wait to get back to the carpet, to make some real adjustments now.
Serpent USA www.serpentamerica.com, King Max Servos, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 09-10-2004, 07:36 PM   #7082
PaintingRoly's Avatar
Trader Rating: 56 (100%+)
Adrian- have you guys gotten the new rear hubs yet?
follow me @RC3grafix on Instagram for pictures of my paint work.
PaintingRoly is offline   Reply With Quote
Old 09-10-2004, 10:19 PM   #7083
PW
PW's Avatar
Send a message via AIM to PW
PW, what ESC profile did you use on your 19T car at Portland? Your car had some major rip, where my car with the same speedo has always felt flat
I was using the Modified profile since I was using my mod car in both classes. I did the plus+ (on positive side) minus- (on negative side) cut on the brushes, Orion Viper springs, and geared to the moon (5.72)
Yes, 20t pulley.
Roly....Yes, the new hubs are in
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 09-11-2004, 09:58 AM   #7084
Oasis's Avatar
Trader Rating: 36 (100%+)
Just got mine yesterday,Should I get the new rear hubs?
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 09-11-2004, 10:04 AM   #7085
PW
PW's Avatar
kat....The stock hubs produce the most traction and work great for tracks with med to low-bite traction (Speedworld). The alloy hubs are great for fine tuning on higher-bite tracks when your looking to free the car up for more cornerspeed. Get with MO and check out his stock Mi2 setup.
Paul Wynn
Old 09-11-2004, 10:12 AM   #7086
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Yo PW- I've been meaning to give you a shout for your excellent 19t performances of late- way to go bro!!!
I got to hang with Pimp in Atlanta a couple weeks ago and really enjoyed racing with him. He's quite a racer and tuner. I've personally seen him improve in both tuning and driving skills over the last year or so- great guy.
Aight- holla at uz guys later
BigDogRacing is offline   Reply With Quote
Old 09-11-2004, 10:31 AM   #7087
xxxkat- Mo let me run his back up car for a few weeks before I bought my car and I had to the chance to run both the alloy hubs and the standard hubs and you definitly want to start with the standard hubs because this car has more steering then what ever you are running right now. Start with the box stock setup and after you have had a chance to run the car for a few weeks put on the Paul Wynn setup from the Roar Nats. The only things that I would say you need to get for the car right off the bat would be the carpet towers and the buds bumper. Billy has the carpet towers and the tc3 buds bumper also. You can come over and see how Stlnlst and I have ours on. You dont need the tamiya shocks either I am running the stock shocks with losi springs and the car is just fine. The tamiya shocks are just easier to build. You only have to wait another month or so anyway for the new schuie shocks anyway. You know that if you cant find Mo or stlnlst to help you out at the track that I am more than happy to help you out. And Matt Howard if you read this I dont want to read any comments for you buddy!!
LSR SPEEDWAY
R1 WURKS
Schelle Racing
MIP Racing
BN Racing
bigdog is offline   Reply With Quote
Old 09-11-2004, 12:55 PM   #7088
Oasis's Avatar
So I take it you run the carpet towers even if you run on asphalt..I'm running a Pro4 and I thought nothing had more steering than that car..
Old 09-11-2004, 01:55 PM   #7089
tuil21's Avatar
what electronics do you guys use with these cars will the novak brushless system work these? btw anyone got one forsale?
tuil21 is offline   Reply With Quote
Old 09-11-2004, 02:40 PM   #7090
PW
PW's Avatar
Thanks Jason, the 19 class was a lot of fun at the Nats
Tuil21....I haven't seen the brushless mounted on the car myself, but I know a few guys have run the Mi2 with the Novak system.
Paul Wynn
Old 09-11-2004, 02:42 PM   #7091
tuil21's Avatar
what parts mostly brake on these things?
Old 09-11-2004, 02:48 PM   #7092
PW
PW's Avatar
Well I would first put on a wider bumper like the P-Dub Racing bumper or any wide bumper from other car makes.
I would have extra front end parts as I would for any TC.
1. Steering block
2. Castor block
3. Arm
4. belts
Paul Wynn
Old 09-11-2004, 03:14 PM   #7093
PW- are you guys going to work monday? and do the new rear hubs take the place of the AE ones.
Old 09-11-2004, 03:46 PM   #7094
PW
PW's Avatar
Sup Roly! I'm not sure, I will wait and see what Ivan does
The alloy hubs replace the AE hub for the most part, unless you are using the lower inner hole on the AE hub.
Paul Wynn
Old 09-11-2004, 05:25 PM   #7095
tuil21's Avatar
hey PW do you sell these cars?
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
