Old 09-03-2004, 09:36 AM   #7006
About the U2782 Teemu chassis - I remember Adrian & the gang saying it has batteries mounted in the inside rear position. I just got some of those chassis's from Schumacher UK last week and they have the batteries in the inside middle position. Are there different versions of this chassis or is one of us mistaken?
olev is offline   Reply With Quote
Old 09-03-2004, 09:39 AM   #7007
mo
mo's Avatar
The did not get put as far back as we originaly thought they would be. I ran this chassis last weekend and it worked great. The countersinking is also done better on these chassis too.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 09-03-2004, 09:44 AM   #7008
Thanks Mo, I have no doubt it works great nonetheless
Carpet season starts on Sunday, we'll see how it goes...
Old 09-03-2004, 10:59 AM   #7009
mo
mo's Avatar
Cool. Carpet starts in October for me. That'll be the first time on carpet with this car for me.
Old 09-03-2004, 11:08 AM   #7010
Regional Moderator
kansasracer's Avatar
OK, so I have been running carpet for about a month with the car and have a tip:
After every race night, take the car apart and defuzz the main layshaft (with the spur and rear pulley on it). I normally wont take my car apart after every race day, but that shaft gathers fuzz at an accelerated rate. I didn't think to take it apart and look at it until after the 3rd race night and had a significant loss in speed (now I know why)
Just some info, but I expect you guys are much more dilligent with the maintenance on your cars than I am
I am watching.....always watching....
kansasracer is offline   Reply With Quote
Old 09-03-2004, 08:04 PM   #7011
Default Carpet Help Needed
[First off, hope everyone is FL is staying safe and is away from the storm]
Hope someone can help me. I have a stock Mi2. I will be running starting in two weeks in a points series. I plan to run stock and 19T.
The track is 50' x 100' with a 100' straight that comes across the front of the drivers stand. The rest of track is twisties.
Anyway, its an Ozite track that is being "professionally" secured to 1/2in exterior grade plywood which is being screwed into asphalt. So this should be very, very hard fast track.
By they way, we are using ROAR rules and the cars will be teched
I have two questions:
1) What is a recommended setup for carpet for stock and 19T
2) What are the recommended speed secret options I should get.
3) What are the recommended shore rating for F/R foams
This will be my first season running TC on carpet.
Since I will most likely be the only Mi2, any help will be appreciated.
LeadFoot is offline   Reply With Quote
Old 09-03-2004, 09:22 PM   #7012
Regional Moderator
LF--
I would help, but I am still searching for a setup.
PW has a good starting point...
Old 09-04-2004, 05:14 AM   #7013
Trader Rating: 74 (100%+)
Default carpet/foam setup
Leadfoot, Kansasrcracer, and others, I cant post my carpet setup, but email me a addy, and I can email my last night setup to you. I am going to get this carpet stuff down very soon. I raced well last night, the car was very stable, and got faster and faster the whole night. Local fast guys turning sub 14 sec laps in 19 turn, me a new car, no setup, and winging it, turned 14.8 sec laps. Pretty dang close, without much time for setup. I agree check the layshaft, and also I kept loosing my flange on the the 20t pulley, I may need a alloy one. Keep you all posted.
Serpent USA www.serpentamerica.com, Maclan , Xpert, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, Rawspeed RC www.rawspeedrc.com, JSpec Stickers
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 09-04-2004, 06:05 AM   #7014
John Tag's Avatar
Trader Rating: 41 (100%+)
Leadfoot where is there a carpet track in conn.? Im always looking for new tracks to visit. THX
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 09-04-2004, 06:37 AM   #7015
John_S's Avatar
does anyone know if the carpet setup in the back of the mi2 manual is a good starting setup? Also does a spool work well on carpet?
John_S is offline   Reply With Quote
Old 09-04-2004, 11:30 AM   #7016
AdrianM's Avatar
The carpet setup in the book is an early rubber tire carpet setup. If you run on Foam we can email you Mike McMahon's setup or we can get you a more current rubber carpet setup.
If you run foam tires diffs are the only way to go. If you run rubber on carpet then its a one way as a first choice then a diff then a spool for special situations depending on grip.
Adrian Martinez
Old 09-04-2004, 11:49 AM   #7017
John_S's Avatar
you got email adrianM
Old 09-04-2004, 12:08 PM   #7018
AdrianM's Avatar
Monday is the US Labor Day holiday. I will get back to you as soon as we get in on Tuesday.
Adrian Martinez
Old 09-04-2004, 12:36 PM   #7019
Default Carpet Racing in CT
John Tag:
http://www.hobbychamber.com -- Hobby Chamber, West Haven, CT near the shoreline. There are directions from NY/NJ on the site
If you are looking for a higher level of competition, check out
http://www.rcmadness.com/ R/C Madness in Enfield, CT. They have two factory backed guys that race there. The only issues (unless things have changed) is that the pit area in the winter is cramped and sparse.
I can tell you that Hobby Chambers is clean, well kept with plenty of pit space.
XRAY, HPI, Associated and Yokomo are your main competition at both locations. Anything else and make sure you bring all your own parts.
Old 09-04-2004, 12:46 PM   #7020
Default Re: Carpet Racing in CT
Originally posted by LeadFoot
John Tag:
Leadfoot, have we met? Why dont you contact me so we can talk, I will pm my home # for you. I will definetely be at Hobby Chamber for the State Champs in October. My Mi2 will be on a mission....
John, you ahve got to check out HC, it is closet to you than SouthShore, but both are premier facilities. I was racing at SS last night. Awesome layout, better bring the driver, not the land missle..
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
