Old 08-25-2004, 08:53 PM   #6946
speedxl's Avatar
R/C Tech Charter Subscriber
ralph your doing great with the xray dont give up!
Mi2 is not the car for you!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is online now   Reply With Quote
Old 08-26-2004, 11:45 AM   #6947
Super Moderator
Trader Rating: 17 (100%+)
Adrian can you back order me a set of the new shocks
Tekno | JConcepts | RRP | LutzRC | BOOM RC
Bob Barry is offline   Reply With Quote
Old 08-26-2004, 12:14 PM   #6948
Send a message via AIM to Adam Hartzell
Me too!!!
Adam Hartzell is offline   Reply With Quote
Old 08-26-2004, 12:26 PM   #6949
cornerspeed's Avatar
I think I have come up with at least a temporary out drive saver for the spools. If you cut the outer race of a diff bearing apart and just slide the inner race of the bearing onto the out drive after the driveshaft/blade has been inserted to the outdrive slot. then a dab of CA to retain it since it is on the end of the outdrive. I ran it this last sunday and they pretty much stayed put. Didn't have any heavy crashes though. I want to try it on the inner part of the out drive up against the bearing. Will make servicing the car easier.
cornerspeed is offline   Reply With Quote
Old 08-26-2004, 02:14 PM   #6950
STLNLST's Avatar
The way that Adrian had us make our spools seems to be pretty good. They have held up in some very bad crashes without any signs of damage. What type of problems are you guys having with the spools?
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 08-26-2004, 02:48 PM   #6951
they been breaking apart in a hard crash and\or spreading apart. it only happens on the right side female out drive. my spools are built to the same specs as Adrian and team does them. these savers at least keep them from spreading apart. more testing in up coming weeks. i have broken about 15 or so in the last 2 or 3 years. been more lately because that is about all i run in the MI2 now
Old 08-26-2004, 02:53 PM   #6952
STLNLST's Avatar
I think if I comment any more I will only end up with a jinx for this weekend.....LOL Are you going to attend the region 12 on road race in October?
Old 08-26-2004, 03:03 PM   #6953
Super Moderator
Yeah i stopped running spools myslef. I honestly saw no benefit on the tracks i run on. our tracks are very tight and for the most part short. I thought driving with a spool was easier but not always faster. From what I understand is you guys all run bigger tracks than we do here in lil ole NJ.
Old 08-26-2004, 03:32 PM   #6954
i plan on racing the region 12 race as long as i dont have to work. i will find out next week
. hope i will be able to. the car is good on that track. they need to slow that track down a little bit though, tighten it up. too wide open.
Old 08-26-2004, 07:51 PM   #6955
STLNLST's Avatar
what set up are you running on that track and what is the tire and insert to have?
Old 08-26-2004, 08:03 PM   #6956
AdrianM's Avatar
I drastically reduce my out drive breakage when I started loosening up my spools 1/4 turn. They will never slip from just running but id you smack a pipe it will slip and save the out drive. Just make sure you stay on top of replacing the blades if you crash.
Adrian Martinez
Old 08-27-2004, 11:35 AM   #6957
speedxl's Avatar
I have done the 1/4 turn deal and even a little looser with out any problems the one thing I suggest guys is have a stash of blades because when those go bad the pin starts chewing at the out drive.
Old 08-27-2004, 12:32 PM   #6958
AdrianM's Avatar
Default New Part
U2797 Ultra Light One Piece Alloy Spool - $39.99 - CNC machined from 6061-T6 aluminum and hard anodized. The units comes with a CNC machined pulley and the whole thing weights just 6g. Since there is no need for a pocket for the thrust bearing the spool's out drives have been internally beefed up.
Adrian Martinez
Old 08-27-2004, 12:44 PM   #6959
speedxl's Avatar
put me 1st on the backorder list there buddy.
Old 08-27-2004, 01:10 PM   #6960
AdrianM's Avatar
Its 6g for the spool part, 17g (0.6oz) for the complete unit...
Adrian Martinez
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
