Old 12-03-2001, 10:32 PM   #676
Oasis2001's Avatar
Send a message via ICQ to Oasis2001
So Adrian are you using 2 degrees of toein on the rear and 2 degrees of toeout on the front as standard. This meaning more steering and more rear grip. Is anyone trying the car just bog standard as the Axis 2?
Oasis2001 is offline   Reply With Quote
Old 12-04-2001, 03:44 AM   #677
Send a message via ICQ to MattW
Chris, Yes i am running the pivots as Axis2. I tried it with the 2 and 2 setting, but was much quicker with the older setting. With 2 and 2 the car felt very easy to drive and stable, but that is not a good way to have the car set on the track that i was running on at the time (indoors). When i get out on tarmac this weekend, i will probably try it again.
MattW is offline   Reply With Quote
Old 12-04-2001, 03:56 AM   #678
The Teacher's Avatar
Trader Rating: 47 (100%+)
The Teacher has just been schooled, thanks AdrianM.
I will start testing Wednesday and that toe in/out issue is one of the first things I will be testing after I find my base setup.
The Teacher is offline   Reply With Quote
Old 12-04-2001, 03:57 AM   #679
Oasis2001's Avatar
Matt- Yeah iyt seems that a twitchy, hard car to drive is a faster car. Whenever my car has been stable and docile it is slow. When its twitchy and im driving well its blinding fast.
Maybe trying the 2 on the front only to improve steering could be a simple solutions for that quick aggressive car.
Old 12-04-2001, 10:14 AM   #680
AdrianM's Avatar
U2297 Threaded Shock Bodies
U2469 Mission One Way
I have only run once since the car came out. I did run inboard toe front and rear and my car had tremendous steering and response.
Adrian Martinez
Old 12-04-2001, 10:34 AM   #681
Oasis2001's Avatar
What sort of track Adrian?
I believe I will be one of the first to try the Mission in hot weather as I live in Melbourne Australia.
Will keep you guys posted. I suspect setups will be similar to the Axis 2, but the inboard options will allow more steering response as you state
Old 12-04-2001, 12:22 PM   #682
Send a message via AIM to pilot
Hello. Is there realy that much of a difference between the graphite and the s1 chassis? Is the graphite that much stiffer, that it is worth getting.
Can someone show me a picture of the s1 car, because i have only seen graphite versions on the net.
thanks for the help
matej
pilot is offline   Reply With Quote
Old 12-04-2001, 04:10 PM   #683
Chris, Agreed. I should know a little moer when i run it on tarmac this weekend. It's a track where i had a good A2 set-up.
Old 12-04-2001, 04:13 PM   #684
Dragonxmx's Avatar
Default My Mission
My Mission has landed!
Purplonium baby!!!
I'm going to get a lobster bib so I don't have to worry about drooling all over it when I build it. Still there is a final trip from the hobby shop to the Dirt Trix shop for the Mission.
Dragonxmx is offline   Reply With Quote
Old 12-04-2001, 04:40 PM   #685
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Adrian are you and PW planning on making it to the Novak race at Trackside this January if so is any one else planning on making it??? This race is one of the bigger races on rubber tires for touring cars of the year. It looks like all or most of Associated's crew will be there and Paul L. from losi I'm not to sure who else is planning on making it. I know that me and Brian J are planning on doing as much racing up there as we can before the race and get dialed in.
To anyone else that wants to race one of the toughest and the best touring car race in the country they should check this race out for more info check out www.Trackside.com for more info.
I raced my mission on carpet with rubber tires this weekend and was impressed with the car alot just need to find a better tire choice hopefully the fresh stuff will be in this weekend.
Kevin K is offline   Reply With Quote
Old 12-04-2001, 05:54 PM   #686
AdrianM's Avatar
KevinK-We are planning on going to the S&N race. PW and McMahon will go for sure. I'm not sure if I can go just yet.
How about you guys coming to our neck of the woods for our biggest race of the year, The Snowbird Nationals? Last year race was UNREAL!
www.snowbirdnationals.com
All of the top drivers from AE, Losi, Yokomo and Schumacher will be there.
Oasis-Carpet, I run asphalt for the 1st time this weekend.
Adrian Martinez
Old 12-04-2001, 07:33 PM   #687
Kevin K's Avatar
Adrian you should try to make this race its the best place to race Scotty is one heck of a guy and really puts on a show and the racers are top self lots of fast guys. Thats good that PW and McMahon will be here. I dont know for sure if I can make it to the Snowbirds or not I have to see if I can get the time off of work. Also it depends on where and when the carpet nats are this year. If they are at Minregg like I hear I will be going there and not to the Snowbirds but if they are in Cali, I wont go there and then try to make it to the Snowbirds. But only time will tell.....I know Brian J is planning on making the Snowbirds for sure.
Old 12-04-2001, 08:51 PM   #688
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
congrats to dragonxmx. you da man paul.
seaball is offline   Reply With Quote
Old 12-04-2001, 09:49 PM   #689
AdrianM i'm running axis 1 on carpet w/foams. dbl purple frt and purple rr, 100wt 2hole front silver sprgs, 80wy 2hole rear yellow sprgs, 7.5 caster, i have a off power slow speed push. would less caster help this?
hobbyman is offline   Reply With Quote
Old 12-05-2001, 12:30 AM   #690
Dragonxmx's Avatar
Default Sleep
Thanks Seaball,
I haven't slept since October! LOL
Of course I have a special project...
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
